Question about Garden
Where does the tension spring for the drive fix. Apparently there should be somewhere on the gearbox and body for a sp470 mountfield
  • 37 Answers
SOURCE: mountfield sp470
Hi, first you'll have to change the air filter and the spark plug. now, go buy some hi octane gas. drain the old gas and put the fresh gas in. if this don't solve your problem please write again.
Posted on Nov 23, 2008
panilling9
  • 284 Answers
SOURCE: Change the Oil
the easiest way would be to purchase a manually pump up oil change device that draws a vacuum and you put the tube from that device in the oil fill hole and draw it out to its own container
Posted on May 25, 2009
  • 110 Answers
SOURCE: service manual
No such thing exists - but you can get an Operator's Manual for the engine if it's a Briggs & Stratton, direct fron the Briggs web site.
Posted on Sep 22, 2009
mowerman1857
  • 389 Answers
SOURCE: How do I replace primer bulb on mountfield SP470
I believe this mower has a Briggs & Stratton engine, if that is the case:
Look at the base of the primer bulb where it is mounted on the carburetor, you will see an opening on both sides of the plastic that the bulb is mounted in where the locking tabs are.
Take two small screwdrivers, press in on the tabs and pry toward the outside of the housing at the same time to release the tabs and bulb. Pull the entire bulb and mounting ring out as an assembly. Don't worry too much about damaging the ring, a new one should come with the new bulb, in fact, it would be wise to purchase the new bulb prior to beginning so you can see what you are working on
Posted on Nov 03, 2009
Testimonial: "Many thanks for your expert advice, as soon as the weather picks up I will replace said primer bulb. "
huffman49
  • 235 Answers
SOURCE: spark plug type and gap for mountfield sp470 mower
CJ 6 plug with a .032 gap
Posted on Apr 04, 2010
What oil do you put in a sp470 mountfield
Hi use SAE 30 in warmer conditions or SAE 10W-30 for varying condition's improves cold weather starting ... Cheers
Sep 06, 2016 | Garden
How do you replace the piece that the belt an blade are attached to on a mountfield RV 150
you talking about the self propelled model
Repairing Lawnmowers For Profit Part 55 Replace Mountfield Lawnmower Drive...
the blade is a one piece ..you take that off
take off the belt cover
if really stuck .. use a puller for the pully/blade boss
remove the back plate to get to the idler tension pully
there was a tension device or ider pully and spring
for the belt tension
Jul 03, 2016 | Garden
Mountfield sp470 carb problem,
You float in the carb is stuck down. May a hole in float.
May 01, 2014 | Garden
I am looking for a Mountfield HP 470 Lawnmower instruction manual
I have a Mountfield HP 470 Petrol Mower 8 years old and I have started it the for the first time and it runs but seems to be hunting or missing as I cut the lawn.
Mar 24, 2011 | Garden
How do I change a worn Carburettor Gasket and Diaphram on a SP470 B&S Engine on my Mountfield Lawnmower? I'm good at DIY. The engine is hunting and running erratically.
Hunting and erratic operation are signs of air leaks or diminished fuel flow at WOT settings.
If this mower is running a vacu jet style carb with a diaphragm you simply take off the air cleaner, the vent tube, and then the four screws holding the carb on the gas tank and after the carb body can be lifted remove the throttle linkage so you can flip over the carb and pull the main jet and clean the inlet screens.
http://www.psep.biz/store/briggs_stratton_carburetor_kits.htm
Aug 11, 2010 | Briggs & Stratton Garden
Service manual
Sep 16, 2009 | Garden
Change the Oil
May 25, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Mountfield sp470
Nov 20, 2008 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
