My Maxima washer HW8000AWO makes pounding noises at certain revs as it spins, but is quieter at other revs. The load is balanced but it still makes the pounding noises. What is causing this?
  • 67 Answers
SOURCE: Pounding noise after wash and final spin
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    if this helps please give a fix ya vote
  • Posted on Jul 14, 2008
    docjohn174
    • 943 Answers
    SOURCE: washer makes loud knocking noise
    HI thanks for your question. you could have something stuck in one of the holes, in the tub, or something caught in the pump, check those 2 . if need more assistance , get back to me. thanks the appliance doc
    Posted on Oct 11, 2008
    • 240 Answers
    SOURCE: washer sounds like off balance during spin
    old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
    Posted on Mar 14, 2009
    57 varieties
    • 1653 Answers
    SOURCE: making a loud noise when on the spin cycle and not balanced
    It could be a drum spring has broken or stretched too far, there is too much of a heavy load in the drum, or the bearing needs replacing.
    Posted on Sep 11, 2009
    heatman101
    • 43501 Answers
    SOURCE: My washer is out of balance when spinning.
    Your problem is probably much more than the washer being out of balance. The front load washers have shock absorbers that hold them from moving all over the place. These have a habit of breaking. Then the drum hammers and sounds like things are flying apart. Pull the bottom front off and check the shocks. Typically the rings where the pins go throuhg are where they will break. Sometimes at first they look okay and you have to grab them and move them to see that they are broken.
    I hope that this will help you to solve your problem!
    Thanks for using Fixya!!
    Heatman101
    Posted on Nov 30, 2009
    Testimonial: "Thank you. I think this sounds like exactly the problem I'm having."
    Whirlpool design 2000 is imbalanced eery load - moves around violently, makes pounding noises.
    Thanks for choosing FixYa and welcome. You need to check the suspension of the washer and make sure everything is intact. Now, if the washer is thumping during spinning, this is probably the motor drive or the spin bearing. This would cause a lot of noise. Your washer will act up if it is not balanced right. Check the floor and make sure it is level. If that checks out, look into the motor drive and bearings. The motor drive controls the spinning.
    Apr 28, 2011 | Whirlpool Washing Machines
    Drum is loose when it spins it make a horrible noise pounding
    When my washer did that, I found that the shocks that hold the tub were bad...
    Check out this tip I wrote about the noise and vibration that front loadwashers can make..
    Washer Problems Washer noise when spinning
    heatman101
    Nov 18, 2010 | Kenmore Elite 45986 Front Load Washer
    The "floating drum makes out of round knocking noise in spin cycl
    On the bottom of the washer tub is a "balance block?" that the bolt has loosened on. Have GE come repair it. We just had it happen to us as well. If you don't get it repaired it will cause more damage to the washer and then it won't be covered under the warrenty.
    Jun 01, 2010 | GE Profile WPRE6150KWT Colossal Capacity...
    Make loud noise during spin cycle
    Washer may be out of balance, Move closes around in washer and restart
    Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
    Making a loud noise when on the spin cycle and not balanced
    Sep 11, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
  • Jul 14, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Spin Cycle
    Remove the bottom panel, it is held on by two screws, and make sure the foam block and shipping brackets are removed. My installer left them in.
    Sep 05, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
    GE Washer WPSQ4160T
    TRY REMOVING FRONT OF WASHER YOU WILL SEE 4 SHOCK LIKE PISTONS TAY GET DRY AND MAKE GRINDING NOISE OR SQUEEKS LUBERCATE ALL REAR HARD TO GET AT MAKE SURE YOU GET TOP AND BOTTOM (RAY)
    Dec 07, 2006 | GE WBSE2090A Top Load Washer
    Washing Machines Logo
    23 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
