How do I jump start the air compressor
SOURCE: 97 Saturn Sc air conditioner not able to recharge
i would verify the ac clutch is still grabbing first as that is a lot cheaper.
SOURCE: my air suspension compressor is
It sounds to me like your compressor got killed. What probably happened is that the airbag got a hole or tiny crack in it so the compressor has to work extra hard because it is like blowing up a balloon with a hole in it. Therefor the airbag killed the compressor. I would recommend going to strutmasters.com and taking a look at our conversion kits. these convert you from the airbag to a powder coated American made steel coil spring that is guaranteed to last the life of the car. I added the link below so you can check it out.
http://www.strutmasters.com/ford-suspension-parts-s/75.htm
I hope I was of some help
Good Luck!!!
SOURCE: 2001 Saturn L200 Air conditioner issue
You need to make sure the freon is correct,by having ac gauges put on the system,if the compressor is running the gauges will tell if there is a problem with the ac system itself,now,it can be the temp door actuator motor that is in the dash,if it is not moving the temp door open,it will need to be replaced.
SOURCE: 04 Saturn Vue AC blows cool air for about one minute then hot air
Above solution is correct, had the same problem with mine and it was the expansion valve.
