Question about Car Audio & Video
Browning 1911 380 magazine 112055192 - Car Audio & Video
Tip
Water for fuel HHO
A water-fuelled car is a automobile that is claimed to use water as its fuel or produces fuel from water onboard, with no other energy input. Water-fuelled cars have been mentioned in newspapers, popular science magazines, local news coverage, and the internet (YouTube); at least some of the claims were found to be tied to investment frauds. This article focuses on vehicles which purport to extract their energy directly from water, a process which would violate the first and/or second law of thermodynamics
In addition to claims of cars that run exclusively on water, there have also been claims that burning hydrogen or oxyhydrogen in addition to petrol or diesel fuel increases mileage. Around 1970, Yull Brown developed technology which allegedly allows cars to burn fuel more efficiently while improving emissions. In Brown's design, a hydrogen oxygen mixture (so-called "Brown's Gas") is generated by the electrolysis of water, and then fed into the engine through the air intake system. Whether the system actually improves emissions or fuel efficiency is debated. Similarly, Hydrogen Technology Applications claims to be able increase fuel efficiency by bubbling "Aquyen" into the fuel tank.
A number of websites exist promoting the use of oxyhydrogen (often called "HHO"), selling plans for do-it-yourself electrolysers or entire kits with the promise of large improvements in fuel efficiency. According to a spokesman for the American Automobile Association, "All of these devices look like they could probably work for you, but let me tell you they don't."
on Sep 16, 2008 | 2001 Volkswagen Jetta TDI
Tip
Water 4 fuel HHO
on Sep 16, 2008 | 2002 Chevrolet Blazer
No indication this is a "Hi Power". How can I tell and what is the difference if so?
The Hi Power name alludes to the 13-round magazine capacity, almost twice that of contemporary designs such as the Luger or Colt M1911. The model is often referred to as an HP (for "Hi-Power" or "High-Power")[4] or as a GP (for the French term, "Grande Puissance"). The terms P-35 and HP-35 are also used, based on the introduction of the model in 1935. It is most often called the "Hi Power", even in Belgium. Other names include BAP (Browning Automatic Pistl), particularly in Irish Army service, or BHP (Browning High-Power).
Apr 22, 2016 | Optics
Tip
Water for fuel HHO
A number of websites exist promoting the use of oxyhydrogen (often called "HHO"), selling plans for do-it-yourself electrolysers or entire kits with the promise of large improvements in fuel efficiency. According to a spokesman for the American Automobile Association, "All of these devices look like they could probably work for you, but let me tell you they don't."[
on Sep 16, 2008 | 2003 Toyota Corolla
I have a 1991 Chrysler new yorker fifth avenue, I'm trying to convert the radio to a Kenwood... I've been searching for a Diagram and none of them have the colors that are on my car...
New Yorker and Fifth Ave have different colors for RR speaker neg. Does either of these match up?
1991 Chrysler New Yorker Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 3 1/2?
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Yellow
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
1991 Chrysler Fifth Avenue Car Radio Wiring Schematic
Right Rear Speaker Negative Wire (-): Brown/Yellow
Oct 03, 2010 | Chrysler Fifth Avenue Cars & Trucks
Browning Hi-Power slide freezing
this problem may be related to the magazine . try another one and see if it still happens. The nagazine spring may be too weak to get the last round up high enough to feed into the chamber before the slide comes ahead
Aug 14, 2009 | Sport & Outdoor - Others
Oven proof ???
Hi yes all stone ware is oven proof so you should have no problems using them just remember they stay hotter to the touch for longer than other oven products they stay hotter for longer once their out of the oven let me know if you need further assistance ok
Mar 19, 2008 | Crock Pots & Slow Cookers
Sony CD interchanger CDX - T69 (how to reset?)
This would invalidate the warranty and you may break it but I have just had to do one:
1. Remove 4 black screws
2. Unclick the front panel - yes it is clicked on but may appear to be screwed
3. Take off black lid
4. Pop the cradled player from the 4 dampers and unhook from the 2 springs
5. Remove the ribbon connector - do this by slipping/clicking the brown holder very slightly and then the ribbon comes out easily
6. Now using a suitable tool push the stuck CD back into the magazine
7. Click the magazine out - there is a white piece of plastic what when moved does the eject.
8. Do the above in reverse.
The trick to get the grey horizontal/vertical discs back on is to set them passed horizontal one notch on and click them on at the end - turning one notch anti-clockwise to lock them.
Feb 09, 2008 | Sony CDX-T69 6-Disc CD Changer
Car Audio & Video Logo
26 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
