Question about Roper Washing Machines
My washer will not spin the clothes.My Roper
My Roper washer is 6 months old and will not spin the clothes
    Sergeant:
  • 239 Answers
Under warranty. call warranty company
Posted on May 08, 2017
Amigaman
  • 248 Answers
SOURCE: lopsided during spin
  This can be caused by a brake that has failed.  Try to spin inner tub with washer off.  It should NOT turn.  If it turns the brake is bad and is allowing the tub to spin when agitating.  This causes clthes to bunch up.
Posted on Oct 31, 2007
jsrock516
  • 5911 Answers
SOURCE: Kemore washer MD#24902200
This problem can be attributed to any one of the following items:
1. Worn Clutch/Brake assembly.
2. Gearcase (transmission) starting to go bad.
3. Basket Drive assembly worn or loose.
The more common problem is a worn clutch assembly, but you can't always be sure. If the gearcase fails, a common tell tale sign is a light colored oil leaking from it. You will notice puddles under the washer and/or spray pattern marks along the interior walls of the casing. Sometimes these two problems are interrelated as oil leaking from the gearcase can cause the clutch or brake to slip.
The following link explains how to replace the gearcase assembly:
http://www.fixya.com/support/r699497-replacing_gearcase
I'm not saying you have a bad gearcase at this point, but include this link because it gives information on how to remove the clutch/brake assembly. If you go to searspartdirect.com and type in your model number as "110.24902200" there are some very helpful drawings under the "Brake/Clutch/Gearcase/Motor/Pump" heading. The gearcase is listed as item 9, the entire clutch/brake assembly is listed as item 5. The Basket Drive is listed as item 1.
This problem can often be hard to diagnose as any one of these components mentioned can cause a slow spin problem. I would recommend you remove the outer casing and do a visual inspection of the gearcase and clutch assembly (under the wash tub), first. Let me know what you find. I hope this gives you some guidance.
PS A basket drive failure will require you to remove the wash tub to replace. Since the basket drive penetrates through the bottom of the wash tub, it is recommended that you also replace the wash tub seal. Let me know what your preliminary findings are before we touch on this topic.
Posted on Aug 28, 2008
SOURCE: UL Code
Solved the unbalanced problem - open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't flap about and scotch the lid to keep it from falling back down on you. Now, look around - see all that rust?  The rust has fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles.  Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. I used automotive wheel bearing grease with graphite in it. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around.  Now, shake your head in disgust that after only 2 years there is so much rust that you wonder if it will make it another year before falling apart, close the lid, and try another load.  That totally solved my off-balance problem where even a single handkerchief would give the UL error. It is still a finicky machine, but at least once again works like it did when new.
Posted on Jan 06, 2009
appldoctom
  • 311 Answers
SOURCE: Agitator Noise of Roper RTW4305VQ
yes this noise is normal.its the dog ears ratcheting in the agitator
Posted on Jan 25, 2009
rjk219
SOURCE: Our Roper washer will wash the clothes, but it will
washer roper 8280871
oil leaks wont spin fast
Posted on Aug 02, 2009
How to get Roper Washer to drain & spin? My Roper washing machine is only a few months old and now it won't spin out or drain water at any level. I even tried just rinse & drain. Model #...
since it is only a few months old, it must be under warranty. So try that first before touching any repair job lest you void the warranty.
Jul 30, 2014 | Roper Washing Machines
My 4 year old roper washer leaves grease on clothes. On spin cycle the machine makes a screaching noise, and the clothes don't spin dry.
Possible that the belt is slipping and also there is some issue with the agitator as the gaps within seems to bring up the dirt or grease mix to the clothes.
So it is important to remove the panel and check the play on the belt, replace if the play is high and check if the agitator bearings are worn out. If so the agitator assembly must be taken out and checked.
Dec 09, 2011 | Washing Machines
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
Roper rtw434osq0 not spinning/draining water
Set the timer to spin manually and turn it on.
Does it spin?
If not,
Your lid switch is bad and must be replaced.
If yes it does spin.
The timer is bad.
Mar 12, 2009 | Roper RAX4233PQ Top Load Washer
Jan 19, 2009 | Roper RAS8244KQ Top Load Washer
Kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
Dec 06, 2008 | Roper RAB2121KW Top Load Washer
Clothes are too wet
the belt is bit losse, try to tighten it a bit and try again
Dec 04, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
