My washer will not spin the clothes. Only 6 months old.
SOURCE: lopsided during spin
This can be caused by a brake that has failed. Try to spin inner tub with washer off. It should NOT turn. If it turns the brake is bad and is allowing the tub to spin when agitating. This causes clthes to bunch up.
SOURCE: kenmore elite washer top loading 6 years old clothes still wet after spin cylce
Click on 'washing machines', then brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. Possible your filter is clogged after these years.
And dont forget to rate me on this great site.
SOURCE: replacing spin belt whirlpool clothes washer
hi thanks for the question this problem can be a lid switch also if the lid switch is bad , it wont send powerdown to the wig wag solenoid . the spin solenoid is mounted on top of transmission , when plunger on solenoid is activated it drops the clutch and spins , if the solenoid is bad then it wont activate the solenoid , to test to see if you have a bad solenoid disconnect power , on the solenoid you see 4 wires just the red on the left and yellow on right reverse these 2 wires plug in washer . select spin .activate washer if the washer starts to wash on spin the solenoid is ok then i would change the lid switch thanks fr the question THE APPLIANCE DOC
SOURCE: UL Code
Solved the unbalanced problem - open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't flap about and scotch the lid to keep it from falling back down on you. Now, look around - see all that rust? The rust has fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles. Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. I used automotive wheel bearing grease with graphite in it. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around. Now, shake your head in disgust that after only 2 years there is so much rust that you wonder if it will make it another year before falling apart, close the lid, and try another load. That totally solved my off-balance problem where even a single handkerchief would give the UL error. It is still a finicky machine, but at least once again works like it did when new.
