Question about KitchenAid Refrigerators
Kitchenaid kfis25xvms9 the door display is dark and now it's not making ice - the ice compartment is warm. Is this caused by a defective control board or something more?
  • 958 Answers
SOURCE: Kitchenaid refrigerator not working
it would not be likely to stuck in defrost mode but my guess would be the compressor is not running. overheated or the condenser is full of dirt. as you said , you can hear fan running, is it inside the ref or outside?..or both?..if that is the case, then it is on freezing mode because the fans would not run on defrost mode..i hope i was able to help..
Posted on Jul 05, 2008
  • 306 Answers
SOURCE: ice build up under rolling tray in freezer
Yes you are right there is a drain tube in the middle of the coils. You need to remove the back panel and you will see the coils of the evaporator (freezer) and right underneath you will see drain tube. Now more then likely it is plugged with ice so take some regular table salt and two or three teaspoons on the top of the tube opening will break it loose and start draining. Take some regular tap water and pour down just to flush the tube and inspect the bottom collection pan under the fridge and see how much water is coming out. Be sure to have unit turned off when you do this cause the fan will run inside the freezer compartment other wise. Hope this helps you. ken
Posted on Jan 11, 2009
mark_37388
  • 100 Answers
SOURCE: kitchenaid ice maker not making ice
first check the tube running to the ice maker where the water flows in see if it is frozen if not take the cover off the ice maker front and see if the little tabs in the middle of the gear is broken there are two one might be broken off
Posted on Mar 30, 2009
aasc
  • 1606 Answers
SOURCE: KitchenAid Fridge, Ice maker not working - red light blinking
Replace the icemaker . The laser receiver (on right side ) is supposed to blink twice then pause then twice repeatedly .Normal. Also clean the coils under fridge .
Posted on Aug 02, 2009
SOURCE: KitchenAid Superba KSCS25FKSS00 SideXSide Refrigerator
Manufacturer recall on door because the wiring was cut by use. Replaced free by certified repairman.
Posted on Sep 20, 2010
Model KFIS25XVMS9. Why doesn't it make ice?
sounds like the ice maker is the problem not the inlet .
Oct 15, 2015 | KitchenAid Refrigerators
Why does air conditioner blows cold air out of 2 vents and 2 vents blow warm ?
Some cars have two temperature controls one for the passengers compartment and one for the drivers compartment . You may have one turned to warm or the control for one may be defective On these cars with dual controls you have 2 Blend doors one of the blend doors may be defective.
Aug 05, 2014 | 2003 Buick Century
How do i prevent ice cubes from freezing in the bin
It is happening because the air getting into refrigerator through the small gap between the door so please
Change the refrigerator's rubber seal
Jul 26, 2014 | KitchenAid Refrigerators
No water to icemaker Kitchenaid french door KFIS25XVMS9
There is several reasons that could cause this. First if your ice maker has a switch turn it off for about 15 seconds then turn it back on then the push the ice control paddle in 3 times. This should start the "harvest", reach up under the ice maker it should start to fell warm to hot which is good. Soon the kick out fingers will start to rotate. If it all is working well it will kick out the ice, then fill with water. If this all works but no water, then it could be a bad water fill solenoid valve, kink in the water line, water filter, frozen supply line. Let me tell you this is at times will have you scratching your head, so have fun.
Jul 23, 2014 | KitchenAid Refrigerators
I have a kitchenaid french door KFIS25XVMS9. The ice maker has stopped working.
If ice build up in the supply pipe sounds as water fill valve is dripping
May 22, 2014 | Refrigerators
Underside of ice bin freezes up built up with frosty ice, dispenses no ice. numerous times we have defrosted with blow dryer, removed, cleaned bin, replaced; cleaned out ice that was built up in lower part...
W10224328 Dispenser Door Spring
The chute door is the reason your ice bin is freezing up and also the chute door being open draws warm moist air inside your freezer compartment causing massive amounts of frost and keeps the compressor runing all the time between defrost. You really n eed to get the chute door fixed. What is the correct model number? For the model KSRX25FT dispenser parts click HERE The chute door spring may be broken but you will not know untill you open the dispenser housing. I'm here should you post the correct model number or have questions, Sea Breeze
Oct 17, 2013 | KitchenAid Architect ® Series II KSRX25FT
Problems with KitchenAid KEMC308 Electric Double Oven DISPLAY
either the touchpad ur pushin or the control board behind is has a bad connection or one of them is defective......u will prob need service some of those u must pull out to acess the componets, not a cheap repair if one of those, usaually at least a couple hundred dollars per part
Feb 05, 2010 | KitchenAid KEMC308 Electric Double Oven
Aug 02, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ours kitchenaid icemaker has stopped making ice. It makes a few very slowley. It has clogged up in the box a few times and we have taken it out and cleaned it out of the frozen pieces. Do we need a part?
hello. i can assist you.
If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Check the freezer temperature. If should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker mold thermostat. Make sure that it's cycling properly.
Jul 02, 2009 | KitchenAid 22.0 cu. ft. Side-By-Side...
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
