Question about Briggs Garden
My Murray 20hp Briggs and Straton runs with choke on but stops when choke is turned off
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Briggs Master
  • 864 Answers
Carburetor needs to be taken apart and cleaned real good with carb cleaner. try to change the fuel filter first.
Posted on Apr 22, 2017
Where are all vacuum lines
What are you working on? Details please.
Jul 29, 2016 | Briggs & Stratton Starter Scott's Equip...
I have an older craftsman snow blower 10 hp. It starts ok with full choke, runs ok half choke, backfires with no choke-run position.
It's too lean; not enough fuel mixed with the air. Look for the main mixture screw--it should be a large screw with a spring under it on the carburetor. Run the engine until it's warm.
With the engine running, turn the screw outward (lefty-loosey) about 1/8 turn slowly and see if it improves. Slowly turn the screw back and forth until it runs best with the choke completely off. Then set it 1/8 turn richer (turn screw outward 1/8 turn) than the best position.
Reason for doing this: Conditions change, even the barometric pressure. Small engines run okay if they are a little rich but not if they are a little lean.
Mar 03, 2015 | Garden
Why wont my 19.5 briggs and straton engine only run with full choke?
you have a dirty carberator you need to rebuild it dealer 40.00
Oct 02, 2014 | Briggs & Stratton Garden
I have a murray push mower 6-22271 briggs straton 4 hp. it start and then stalls . filter clean. choke fully closed when control is in full forwrd run/choke position. I pour gas in the throat and pull...
Your carburetor needs cleaned. It is dirty/has debris in it. If it has a bowl that is. If it has a diaphram (carburetor mounted on the fuel tank), replace the diaphram. They go bad.
I hope this helps get you going.
Jul 28, 2011 | Garden
Crafstman 22hp briggs and straton engine, I've changed spark plugs, air filter...when engine runs it does so unevenly and at times backfires. What can I do to solve the problem?
Don't use the choke, turn the lean all the way to the right and back off 1 and a half turn, its running too rich, usually find this screw under bowl on carb, don't mess with the other screws, take air breather off and let breath without choking, if you have to use the choke after this start with just a little.
Jul 02, 2010 | Briggs Stratton 020273 Elite Series...
Briggs 20HP Intek sputters under load
reset the valves to specifications by gaping them all to .008 thousands The vibration will continuely make the gap wider causing this problem to get worst. Gap the valves is recommeded every other year
Jun 14, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a craftsman 20hp Briggs motor, it turns over but wont start.
Make sure it is choking the engine like it should. If it is not choked it wont start for several minutes.
Sep 28, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Briggs and Stratton 20hp twin cylinder runs only with full choke
Had one on my saw mill had this problem as well Try pulling bowl off bottom of carby as the float can get **** with old fuel especially ethanol fuels as they attract water bowl is normally held on with one center screw on bottom of carby. Note always turn fuel off and let engine run out of fuel as this stops goop from building up in carby
Sep 04, 2009 | Briggs & Stratton Briggs Stratton Intek V...
MTD lawn tractor. 16 hp twin briggs straton
THIS SOUNDS LIKE A THROTTLE CABLE LINKAGE PROBLEM.WITH THE HOOD OPEN AND MOTOR RUNNING RUN YOUR THOTTLE UP AND DOWN WHILE LOOKING @ THE LEFT SIDE OF THE MOTOR TO SEE IF THE CABLE IS FROZEN IN PLACE OR BROKE OR DISCONNECTED .HOPE THIS HELPS
Jul 15, 2009 | Mtd Garden
Murray 20 hp
probally trash in the carb or fuel filter partially clogged. try replacing the fuel filter if no go the carb will need disassembled and cleaned.
Jul 14, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
Top Briggs Garden Experts
Mike
Renee Knafel-Bullock
Are you a Briggs Garden Expert? Answer questions, earn points and help others
