Question about Sewing Machines
My embroidery machine tmfxii 1506 head is down. All other 5 heads down. The one head just stopped working
2 Suggested Answers
mary_inthepi
  • 27 Answers
SOURCE: How do you correct/fix a 316 error/main shaft motor error on a Tajima 2 head embroidery machine
I hope this link will help.
http://www.digitsmith.com/tajima-tmfd-g1220-type-2-error-316-a-31639.html
Posted on Sep 29, 2017
My Machine have an error message coming from the screen "BROKEN DESIGN DATA WILL BE DELETED FOR SYSTEM RESTORATION" Whats is the solution for this error?
I will need more information on make and model of embroidery machine this is.... a system reset need to flush out the memory and delete improperly saved or partially loaded embroidery designs.
Cheers,
Embroidery Services
San Diego, CA
Jul 03, 2016 | Sewing Machines
My Brother PE-770 presser foot Q has started making a clacking noise. If I press in on the lever on the back of the foot, the clacking stops. What is causing this loud noise and how do it fix it?
Sounds like something in the machine in the head that makes it go up and down. either wear or something loose. I would have it checked by a Brothers repair shop
Jan 10, 2015 | Brother PE-770 Embroidery Machine
On an Elna 9006 sewing machine I have an error that reads ( stepping motor error) what does that mean.
Time to get this machine a repair shop. Motors in embroidery unit may be bad or headed that way...
Cheers,
Kelly
Embroidery Services
San Diego, CA
Nov 11, 2014 | Sewing Machines
Brother embroidery machine
Hai, What type of your embroidery machine? How many heads and needles? If your machine 4 ,12 or 20 heads and 6 or 9 needle, you can use different color and designs.
Apr 10, 2014 | Brother Sewing Machines
Thread not catching to bobbin
Hai, How many heads in your embroidery machine? As far as you should have brother embroidery machine's maintain and handling is smooth and carefully. Please check the timings. Otherwise ask your machine mechanic.
Mar 19, 2014 | Brother Se400 Computerized Embroidery &...
Hi. I have a commercial one head tajima embroidery machine. I was sewing and realized I had no thread on one bobbin so I stopped the machine. Instead of continuing on, I decided to start all over with a...
Your new embroidery program has to be loaded first. The 2b7 is referring to needing instructions or in other words the embroidery program has to be loaded. Shut the machine down and turn the machine back on and load just as before.
Jul 06, 2017 | Sewing Machines
Tajima embroidery machine troubleshooting
We are having a similar problem with one of our single head Tajima TMEX-C1201 machines. In our case the design runs part of the way, then the head jumps and continues running and ruins the work. Any feedback on this would also be appreciated. Thanks.
Jul 15, 2013 | Sewing Machines
On the infodisplay, I have a blinking icon. I start to embroider and it stops blinking E with a loop around it. It is beside the pressure foot letter.
I think it indicates that the embroidery has reached as far as it can go within the hoop limits. If you have your user guide (I have a Scandinavia 400), in the embroidery section under the function buttons heading (mine has a worm embroidery on display), it talks about the "check size" button (a single button with arrows pointing to all four corners). The explanation is in there.
Feb 22, 2011 | Husqvarna Rose
My touch screen doesn't always work. Sometimes I have to touch all around the square and even then, it won't come on. At times, it stops working when I want to change patterns. It seems to work most of the...
Yes, I have a solution for this problem. Your screen needs to be recalibrated and you can do it yourself. Don't you wish they would just tell you this stuff instead of charging you an arm and a leg? Here's what to do: Before turning on the machine, press the start/stop button, the reverse button, and the needle position button all at once with one hand (one finger on each button). Hold them down and turn on the machine. What will come up is a recalibration screen. You will see the numbers 1-5 with a little plus sign beside them. Find a small blunt object (I used the tip of a mechanical pencil with the lead in instead of out) and while holding the start/stop button, touch the plus sign beside 1-5 in numerical order. Then, turn the machine off and on again in the normal way. This should recalibrate the screen. Pass it along, people! This is something no one should have to pay for!
Nov 03, 2007 | Baby Lock Esante
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
