Question about Elite Health & Beauty
I have an Jazzy Elite Select and my controller is giving me a code of 1 red 2 yellow and 2 green from left to right. The batteries are charged and free wheeling is off.
The batteries are charged . The flashing never stops. Unit will not move. It gives a beep when you turn it on. The diagnostic manual does not show these codes
4 Suggested Answers
  • 347 Answers
SOURCE: yes i have a jazzy
hi im disabed myself,that why im here,i care.please rat me as in thumbs up 1 to 4 for my answer.if you visit:www.alldatasheet.com type in the correct boxes you product & download the toubleshooter as a PDF File.save it to your Adobe Reader & or print it & put it in a polythene sleeve folder for when needed.you will be happy to know these flashing lights or series of beeps are the what you can use with the troubleshooter to find out he problem for fixing.hope i was of help colin.
Posted on Aug 23, 2010
SOURCE: We have a Sentry safe
http://callitout.com/quotes/index.php/kick-it-to-the-curb/55/sentry-fire-safe-wont-open-its-broken/
Its the most reazonable answer and it worked!!!!!!! dial the code and tap on the handle so it would get lose
Posted on Feb 02, 2011
bud45man
  • 4 Answers
SOURCE: reset button
While replacing the batteries you may have bumped the brake releases. Release both and return them to the operate position. It is also possible to get one or both batteries backwards. This is a 24 volt system so pay close attention to the color codes on the cables. Be careful of shorts.
Posted on Nov 06, 2013
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
Jazzy select gt. batteries are good charger is new when charging the lights go from red to green and repeats, but if i hold the button one red one yellow ? i tested the batteries they are full but joy...
Still your batteries are bad. Had this problem before. If the batteries are more than 1 to 2 years old they need to be replaced. The charger only tells you it can't charge anymore, because the battery is sulfated. The meter on the chair is telling you the batteries are not strong enough to run the chair.
Jul 18, 2017 | Select Health & Beauty
When plugged into charger both lights show green but chair not fully charged
First measure the voltage of the batteries at the charging socket of the joystick.
Sep 28, 2014 | Pride Jazzy Select Elite
Reset button
Nov 06, 2013 | Pride Jazzy 1103 Ultra Standard Power...
I just replaced the batteries in my Jazzy 1170 PLUS. Now my speed control lights blink constantly and the chair is totally unresponsive.I have double checked to be sure the freewheel levers are totally...
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
Feb 13, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
On the Jazzy select what color for charging indicates fully charged, red, green?
scraig Lights on the joystick all lit up to the far right and the green light lit on the charger. Red indicates charging or blinking red indicates error in charger. Hope this helps
Nov 20, 2010 | Pride Mobility Products Jazzy Select
My Jazzy select six sometimes charges sometimes(most of the time) does not. The charger shows red and green when first on then in the morning both are green, but the joystick shows no charge. The...
After charging overnite get a digital voltmeter set it to 200 volts dc and plug the leads into the 2 outter holes in the charger port located under the front of the joystick. If the charger works properly you should read 26-27 volts on the meter. If you are reading 24 volts or less then have the charger checked it should be putting out 27-30 volts or so. I would also have the tech check the batteries under load and check the wiring harness from the joystick to your controller. Hope this helps
Oct 31, 2010 | Pride Jazzy Select 6 Indoor Power...
Health & Beauty Logo
29 people viewed this question
Top Elite Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
Jeff Tilburn
Jeff Tilburn
Are you an Elite Health and Beauty Expert? Answer questions, earn points and help others
