Question about Maytag Freezers
Ice clumps up in ice bucket - Maytag Freezers
  • 864 Answers
That will happen if the ice is not used for a while especially in humid weather.
Posted on Jul 24, 2009
The ice level arm catches on the ice bucket when trying to pull out the top freezer tray
Hello Danny;
My name is Peter. I am a retired field service refrigeration technician.
This is just a bad design.
The only thing you can do is raise the lever arm to the shut off position.
Or, you can reform the lever arm so it clears the bucket. In this case you have to manually control the ice maker otherwise the ice bucket will over fill.
Your ice maker will harvest ice cubes 8 to 10 times within a 24 hour period.
Nov 30, 2014 | Freezers
Maytag MSD2651KES delivers crushed ice but no cubed
There is an metal arm that extends out behind the ice bucket that moves up and down when you press the cubed/crushed ice buttons. You need to take the ice bucket out and check the hardware. It's possible that some ice has managed to form in the unit and are blocking the motion. Remove any ice and check if the arm moves freely when you press the buttons on the refrigerator. Similarly, you should check if there is ice blocking the forward and back motion of the plunger in the freezer that bar sits on. This plunger is right next to the auger motor.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MSD2651KES/3048/0165000/W0703730/00013 has a picture of the ice bucket parts.
Dec 06, 2013 | Freezers
My maytag MFI2569YEB ice cubes are melting around the coil in the tray. What could be wrong?
if you are talking about the bucket the cubes go into, most likely you do not use a lot of ice. the ice isn't melting, it's evaporating. usually winds up in a big clump at the bottom.
Oct 31, 2013 | Maytag Freezers
Where is the ice maker reset button on a Samsung RS265TDRS?
This ice maker is on the door, so
remove ice bucket
move your fingers up under the ice maker tray guard on the left side until you find a button
you may have to press this several times, perhaps hold down firmly until you see some action
then quickly replace bucket & close door
Sep 06, 2013 | Samsung RS265TDRS 25.5CuFt Side-by-Side...
Our subzero freezer has a new problem. The cubes
Ice cubes WILL BE slightly moist when they land in the ice bucket. they've just been slightly melted in order to eject from the ice maker. Stop playing with the settings, for starters. put them back to normal, i.e., middle setting, place thermometer in center of freezer, and if you can, one in center of fresh food. monitor after 24 hours, and for the next three days thereafter. freezer temps should be in the -5 - +5°F, sometimes up to 10°, fresh food should be 35-40, sometimes up to 44°at the normal settings. If you are not having temperature issues, see if you notice any frozen drips of water on the underside of icemaker, indicating a possible crack in the ice maker mold, or a faulty water valve. You didnt include your model and serial number, so not knowing the path of the ice shoot, some go out the freezer door, some slide over and get dispensed from the fresh food side. Its possible you may have a problem instead with the flapping door that opens to allow ice cubes to be dispensed, or similar type mechanism. If this door does not seat completely when its closed, it will leak warm air directly into the ice bucket, which would make them slightly moist, also too, this warm air can cause frost and ice to buildup near the warm air source...look for any unusual forms of ice and or frost leading up from the flapping door to the ice bucket. Also look for any gaps in the door gasket when closed, this warm air leak can also cause similar problems, but its most likely with the ice door. could be the door, the spring, the solenoid, or something else i wouldn't know without personal refrigerator inspection.
Mar 27, 2010 | Freezers
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
Ice Maker
the LED's are optics they sense the level of the ice in the bucket on the door under the icemaker is 2 1/4" screws you can remove the IM and the white cover put a small jumper in the pins T and H this will cycle the IM the door and optices will need to be closed (or best to tape them so you can leave the door open the IM should cycle if nt check the power at the N and L pins see if you have 120vs then we can go from there
Apr 08, 2008 | Freezers
Open Questions:
Freezers Logo
Top Maytag Freezers Experts
John Tripp
John Tripp
christian nielsen
Ismael Rodriguez...
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
