I have a mira-cool air cooler/heater that is new but has no manual. I can not get the cooler to work. Can you tell me how to set it up?
fridgetech
  • 473 Answers
SOURCE: wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Posted on Oct 07, 2007
  • 20 Answers
SOURCE: Remington PTAC Heater/Cooler
you may have a bad heat sequencer
Posted on Jan 11, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: LG split system heater cooler. the heater is not working and fan outside is working
I would check to see if the tech accidently left his jumpers on the unit to keep it running while adding freon. I know it sounds like a simple thing. But all techs have done it at one time or another and that will cause this problem. Due to the fact that you just had freon added there is not a reason anywhere that would cause you no heat unless something was hit when this was being done then something electrical fried
Posted on May 28, 2009
  • 81 Answers
SOURCE: LG split system cooler/ heater heater not working
This could be a problem with the interconnecting wiring or a control board problem with either the indoor or outdoor unit. I would have these issues looked out.
Hope this helps
Mat
Posted on Jul 16, 2009
  • 161 Answers
SOURCE: Heater blows cool air instead of warm air
check your coolant level if it is low top it off. if it is full you may need to change your thermostat to get the temp back to normal. for the heat check the heater control valve to make sure it isn't stuck (heater control valve should be located against fire wall connected to heater hose.
Posted on Dec 07, 2009
How do use my mira-cool portable cooler/heater no instructions or manuals
My mira- cool blows out hot air when I turn on cooler, do I need to fill container with water in the back
Dec 21, 2014 | Heating & Cooling
Oil in radiator
Hi
you didn't say what the car is or any other information.
I can tell you generally, oil in radiator means: engine oil cooler, transmission oil cooler, cracked engine head or cracked engine block. about the heating problem, the heater matrix is blocked with oil, the coolant in not going trough. you need to flash the cooling system including the heater matrix.
good luck
Feb 23, 2014 | Cars & Trucks
NEED MANUAL FOR A Mira-Cool model MRCACL.
When I turn on for cooler, only hot air comes out, do I need to add water to the back tray?
Oct 03, 2013 | Heating & Cooling
The Can anyone tell me what might be wrong with my a/c? It doesn't cool anymore?
please check the a/c nob whether it is on heater(red) or cooler(blue) if it is on blue then check the direction of ur blower like towards the front glasses, to ur feet etc. set it and then try your a/c. i hope it might helped u
Aug 19, 2012 | 2002 Chrysler Town & Country
I have a new MIRA-COOL how do I work it?
I wish I could solve this problem. My son just gave me a Mira-Cool heating/cooling portable system today. Anxious to see how it works, got it out of the box and the 4 water cooler containers were in there and a cap or something that goes somewhere but no instructions. DUH!. I have it on heat now. Just to be safe, I filled the water container in the back but that's as far as I can go. I'd never figure out how to work the cooling system, when it comes time, because I can't open anything but the water container. The label of the box says see Package 1 for instructions. My son is checking into it because he said he thought all they received was the 1 package. Anyone with answers, please e-mail me @ bevhath@carolina.rr.com.
Thanks much! Beverly Hathcock
Aug 09, 2010 | Heating & Cooling
Our Bonaire Evap Cooler stopped after power failure
Turn the power of to both the heater and the cooler. Turn the power back on to the heater and the cooler at the same time then reset codes on controller.
Feb 07, 2010 | Mastercool 67471 Evaporative Cooler Air...
Heater works, but only on Emergency Mode
It sounds like you have a "setback thermostat" A control intended to increase efficiency by allowing the fan to run for an adjustable amount of time after the heater turns off, whether the heater is electric or part of a heat pump. If the "setback" time is too long, the element will cool off and the fan will blow cold air. Try and locate the instructions for the thermostat and see if the "fan run time after heat turn off" is adjustable and reduce it by half. Most emergency heat circuits bypass control circuits (its an emergency, you know), and require manual control.
Jan 11, 2010 | Heating & Cooling
May 28, 2009 | LG LSC091PMA Split System Air Conditioner
Jan 11, 2009 | Heating & Cooling
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
