Question about Westinghouse Televison & Video
HOW DO I GET OUT OF DIAGNOSTIC MODE ON WESTINGHOUSE TV
    Master:
  • 923 Answers
Unplug it for a minute, then plug it back in!
Posted on Apr 20, 2017
How do I get OUT of diagnostic main menu on Westinghouse tv
This guys may guide you for free - http://bit.ly/2oONirp
Apr 20, 2017 | Westinghouse Televison & Video
Have a westinghouse lcd tv 50inch model ew50t5kw and would like to know before changing any parts or boards what causes a blue screen no sound or picture
  1. Frank: Verizon. com says try this: Change your VCR's Channel to 3 or 4. Most blue screen issues are caused by the VCR not being set to Channel 3 or 4. If changing the VCR's channel (using the channel buttons on the VCR or from the VCR remote control) did not change your TV screen, go to step 2.
  2. Make sure your TV is not in Video mode. There are three possible ways to change your TV's mode using your TV remote control: 1) Press a Mode button, toggle through the options and select TV, 2) Press a Video button to change your TV's mode from Video to TV or 3) Press Menu, locate Mode or Audio/Video setup and select TV from one of the options. If you are not sure how to change your TV's mode, see your TV's user guide for more information.
  3. Check to make sure your set-top box is plugged in and turned on.
  4. Check to see if other TVs (connected to different outlets) have a blue screen. If they do, contact the Verizon Fiber Solutions Center.
May 21, 2015 | Westinghouse Televison & Video
CAN WESTINGHOUSE 55 INC TV CAN BE PROGRAMED WITH DIRECTV REMOTE
Setup Instructions
  1. Set the "Mode Switch" to TV.
  2. Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  3. Enter the 5 digit Code 10451
Dec 27, 2014 | Westinghouse Televison & Video
I have a 22" Westinghouse
Change the settings on your HDMI output to 720 progressive for resolution. The tv likely cannot handle the 1080 resolution, or the tv can only use interlaced (1080i or 720i) format.
Aug 21, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
(19 inch LCD Westinghouse tv).....Lost my remote and I can't get the video mode on. It only shows DVI and D-SUB. Also I bought a universal controller that can't change channel or view menu nor put...
Hello Madali657, you can obtain a remote by calling Westinghouse customer support team at 1-800-701-0680 and selecting the spare parts options or you can send me an email request with the model # and serial # to westytech@westinghousedigital.com and I will make sure you get a new remote for your TV.
May 24, 2011 | Westinghouse 19" Widescreen Flat Panel LCD...
Westinghouse - 60" Class / 1080p / 120Hz / LCD
There is a method called a Power Scan this method allows you to search for all possible codes. Try this until you reach a code that carries all of the functions desired. If the TV mode button starts flashing rapidly during this process you have exhausted all possible codes.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Apr 17, 2011 | Westinghouse 16093 Remote Control
I can get my dishnetwork remote to program for the volume nor to turn it on or off help me please the model #w32001
We would be happy to help you with that.
Step 1:
Press and hold the TV button until all mode button back lights come on, then release.
Step 2:
Use the number buttons to enter the device code corresponding to your Westinghouse TV. Potential codes for White Westinghouse are: 500, 719, 664, 555, 674, 659, 670, 672, 641 and 573. Then press the pound (#) button. If the code entered is valid for the remote, the mode light flashes three times. Your DISH Network remote should be able to control your TV. Thanks for being a valued DISH Network customer.
Phillip Chang
DISH Network Customer Service Representative
Jan 20, 2011 | Westinghouse W32001 20 in. HD-Ready LCD...
Westinghouse model tx-47f430s lcd tv wil not turn on
This is known as SLEEP MODE problem.
Simple solutions:
1. Get a power surge protector / strip.
2. Plug your TV power cord to the power surge.
3.Then turn-on your TV using the remote control. Just in case it won't go all the way to normal state.
4. Turn-off the switch of your power surge like 5 times with an interval of 3-5 seconds.
5. Then repeat step 3 and 4.
6. These step is done to over-ride the sleep mode.
Roan
Feb 16, 2010 | Westinghouse TX-47F430S 47 in. LCD TV
TX-42F430S Lock up on power up
I have a similar problem with my TX-42F430S; Mine freezes when changing from Comp 1 to Comp 2. unpluging and waiting was the only fix. Just recently my TV just started turning off(after about 30min of watching) and the led will flash blue. I need to unplug for about 10min before it works again. Getting frustrated and I have contacted Westinghouse to send for repair. only had the TV for 3 months; connect to Roger Explorer HD box.
Nov 02, 2007 | Westinghouse TX-42F430S Television
Televison & Video Logo
57 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
