Question about Health & Beauty
How do I change my scale to pounds - Health & Beauty
    Novelist:
  • 165 Answers
Go to your device settings, and look for your Aria scale. There should be an "edit" option next to the Scale Unit. Set it there.
Posted on Apr 22, 2017
3 Suggested Answers
SOURCE: setting is in metric instead of pounds
On my model, there is a button on the bottom that slides back and forth to choose the wanted setting. My scale is about 5 years old.
Posted on Nov 21, 2008
SOURCE: Programming scale to display in pounds
It's not the scale board. Its an undocumented program setting. Change as follows (you will need programming scan codes from NCR document downloads)
Reset Tag
Programming Tag
Hex 3
Hex 0
Hex 2 (or Hex 1 for Kg)
Then it will request a calibration procedure (Done)
Posted on Aug 04, 2012
Salter scales weighing more than double the weight
Sounds silly but check the scales for a Kilogram or Pounds switch. its usually under the scales and is a sliding switch. It should tell you on the display if you are weighing in pounds or kilos.
Sep 15, 2014 | Health & Beauty
Tn425 sharper image bathroom scale how to change from kg to pounds?
There is a small finger slider switch underneath the scale, setting the scale to either pounds or kilograms.
May 07, 2014 | Terraillon TFX70 Sharper Image Body...
Can not change from Kg to Lbs
Flip over the scale, on the back there is a black button, slide it to pounds.
Apr 02, 2010 | Taylor 5599 440 Pound Tempered Glass Body...
How do I change the scale to read pounds instead of kilograms?
Turn over the scale, on the bottom, there should be a little black switch that you can use to select between lbs and kilograms.
Oct 25, 2009 | Taylor 5599 440 Pound Tempered Glass Body...
Somehow my tanita ultimate scale has been switched from pounds to stones. How can I get it back to pounds?
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Mar 15, 2009 | Health & Beauty
Scales show weight in kg. How to get them to show lbs.
Mar 13, 2009 | Tanita 2204 Body Fat Scale
Metric instead of pounds
You didn't mention brand name or model number, so not sure about your specific case. However, on my scale, there is a switch or button near the battery compartment. It allows you to change the measurement between stones, pounds and kilograms.
Jan 01, 2009 | Health & Beauty
Setting is in metric instead of pounds
Nov 10, 2008 | Tanita Digital Body Fat Scale with 2...
Health & Beauty Logo
37 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
