Where do I find where I enter code numbers, Hate this new site
Need new remote
If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability. The first thing you have to do is, to confirm the number of digits in the setup codes to your TV brand. There are 4 digit, 5 digit, 3 digit and even 2 digit codes. You can make it sure by entering '0s' at the code enter window the TV dispays, and asks codes. Enter 'Zeros', and count how many zeros can be enterd. That number will be the number of digit of setup code, the TV/Device need. If you can enter 5 zeros, the number of digit in the set-up code to your TV is a '5' digit one, if only 2 zeros can be enterd, the number of digits in the set-up code to your TV should be a 2 digit one, and so on.. If you wish to get more details about this, try the sites linked here.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 20, 2014 | Vizio Televison & Video
Vinverth dvd player
If you wish to get more codes and other details check:
Jan 18, 2014 | Televison & Video
Universal home theater 5.1
http://electrohelponline.blogspot.com/ & http://electro-medical.blogspot.com/ Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 06, 2014 | Televison & Video
I need a new remote for my TV
If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability. The first thing you have to do is, to confirm the number of digits in the setup codes to your TV brand. There are 4 digit, 5 digit, 3 digit and even 2 digit codes. You can make it sure by entering '0s' at the code enter window the TV dispays, and asks codes. Enter 'Zeros', and count how many zeros can be enterd. That number will be the number of digit of setup code, the TV/Device need. If you can enter 5 zeros, the number of digit in the set-up code to your TV is a '5' digit one, if only 2 zeros can be enterd, the number of digits in the set-up code to your TV should be a 2 digit one, and so on.. If you wish to get more details about this, try the sites linked here. http://electrohelponline.blogspot.com/ & http://electro-medical.blogspot.com/ Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Sanyo lcd24xr10f
Jan 04, 2014 | Televison & Video
Bryant plus 80 heat exchager is cracked, i'm looking for a replacement heat exchanger
Hate to tell you but heat exchangers are hard to match up. Unless it is relatively new then in most cases they have a warranty of 10 years. So you will have to replace furnace. You might be able to find a used furnace or go to web site and enter model number of your Bryant to get replacement.
Oct 23, 2010 | Heating & Cooling
I am trying to use the 11c and do not know how to enter the values to get an answer. For example how do you do 1 2 = ? Is there a site where I can download the instruction manual since I hate to buy...
That depends on what you want to do with the 1 and the 2. If you want to add them together, for example, you would press
1 ENTER 2 +
If you wanted to multiply them together, you would press
1 ENTER 2 *
It's not free, but you can order the HP-11C manual from
http://www.hpmuseum.org/software/swcd.htm
There's also a fairly good tutorial on RPN there at
http://www.hpmuseum.org/rpn.htm
Sep 09, 2010 | HP 12c Calculator
I forget my N73 mobile lock code, how i am tracing
Hi
try this site
http://www.unlockme.co.uk/master.php
after visiting on this site you have to enter your phone's imei no. in the textbox which are given on that page
after entering your imei no. click on get master code button then you will find your master code
after getting the master code go to menu > settings > security and go to the lack code change option and enter this master code as your code after this press ok and then set your new lock code
May 15, 2010 | Cell Phones
2001 mountaineer It has a touchpad lock on the outside on the driver door. How can I get this working and programmed?
If you don't have the original factory code you'll need to contact Ford/Mercury customer service through their web site and provide the VIN for the vehicle. Once you have the original code, you can program your own number by following these steps:
1. Enter the factory set code.
2. Within 5 seconds press the 1-2 key
3. Enter your personal 5-digit code. Each number mus be entered within 5 seconds of each other.
4. Doors will lock and then unlock to confirm that your new code has been entered and accepted.
NOTES:
1. The factory code will still work even after you have entered your new personal code.
2. Entering a new personal code will erase the previous personal code.
BillB
Jan 18, 2010 | 2001 Mercury Mountaineer
Parental block
You can try these codes 2211 or 3308 if they do not work you will need to reset the unit. You will need to unplug it for 45 minutes that will reset the TV to factory settings. Then the pass codes I provided should work.
Sep 16, 2007 | Televison & Video
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
