Our color changing wall mounted fireplace won't turn on
4 Suggested Answers
SkinWill
  • 148 Answers
SOURCE: wall mount for 52in tv ?
Here is a mount rated for your size TV http://www.bhphotovideo.com/c/product/518312-REG/Bentley_PLAW_6000FB_PLAW_6000FB_32_60_Flat_Panel.html
Also, be VERY careful mounting ANY plasma above a fireplace. Plasma sets are typically convection cooled to avoid the noise of fans. The heat from a fireplace will GREATLY reduce the life of the set. When people I know insist on putting a set above a fireplace I usually insist they install a cooling fan with ducting that will vent fresh air to the set. If you are concerned about the temp of your set simply consult the owners manual for operating temperature and measure the air above the fireplace yourself. BHphotovideo.com typically has good prices on mounts along with amazon. most other places like bestbuy or circuitcity will stick you on the price of the mount because they make their money from accessories. Also, why did your last set die? plasmas are typically rateed for 10+ years, did yours over heat and start to change colors?
Posted on May 17, 2008
jamesmarcum2
  • 79 Answers
SOURCE: fire wont flicker on my electric fireplace
most of those electric fireplaces have a band of paper with holes in it that rotates around a light bulb this gives the illusion that the fire is flickering the motors that rotate that band of paper go out all the time its just a little electric motor you might be able to get one from the manufacture
Posted on Dec 07, 2012
  • 3698 Answers
SOURCE: Prolectrix electric wall mounted fireplace. BG-04
Clean apart and clean. Oil fan motor.
Posted on Jun 23, 2014
When turning on my bravia 32 is all black and then lines in color appear and then black again
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 22, 2014 | Sony Bravia KDL-46HX729 LED Internet TV...
Sanyo tv was moved from over fireplace and mounted to the wall and since then the color has been off. How can I fix this?
Use the buttons on the device or the remote control to access the settings and adjust the tones to your wishes
Nov 13, 2014 | Televison & Video
Purchased a Great World Ltd electric fireplace at BigLots. Model is either SWEO71 or SWE071. The flame and dimmer features are not working. Just put it together and mounted on wall, turned on, and
don't know this model, but does it have a light bulb inside? if so change it. they are often red or orange, but any will do to test it
Sep 13, 2014 | Heating & Cooling
Can you give me some advice on, how to mount a 46in tv above my non working fireplace mantle?
You would have to use a mounting bracket specifically designed for the type of installation you describe and it certainly would have to be fastened into the studs behind the sheetrock. A TV of that size will be heavy to lift and install in the bracket
Mar 04, 2013 | Universal Bedroom Mounting Bracket For...
What thermostat will work for my gas fireplace?modelwh060396b 07/2006 has remote want a wall mount
A search for that model number did not yield any results. A brand name would help.
That said, if your gas fireplace has a milivolt valve with "TH" and "TP/TH" terminals on the side (for hooking up a remote, thermostat, or switch), then you can use a universal wireless wall system.
You can find wireless wall systems for gas fireplaces HERE.
Dec 23, 2012 | Heating & Cooling
We purchased a home with an electric start/gas fireplace...no owners manual...we turned on the gas with the key, flipped the switches on the wall and the fireplace unit...we see the ignitor clicking and a...
Not for sure what you have, but if you just purchased the house, there might be air in the gas lines. If it sat vacant and the gas was off, or if they has swapped meters/worked on gas lines? Try cycling the fireplace several times. Or look around for a small door opening or if it's mounted to the exterior wall, look outside for the supply line in. If you do find a valve in the closed position, be aware of the fact that it may be off due to a reason, and you may want a plumber/fire place tech to service it.
Oct 19, 2017 | Leisure HOMEPRIDE Electric Fireplace...
Right after they were apprx one yr old they started clicking
The metal chimney is expanding and contracting ... turn up the mood music or start the fire sooner so it will be hot when you are ready to enjoy the atmosphere.
May 10, 2010 | Dimplex Copper Wall Mount Electric...
WILL BE BUYING LCD TV IN NEAR FUTURE, BUT NEED TO MOUNT IN ON WALL WITH FIREPLACE, SEVERAL FEET ABOVE EYE LEVEL. CAN DO?
Absolutly, I have wall mounted a few dozen above fireplaces in the past 5 years; I can even send you over some pictures and suggestions come time for the install.
What is the wall material? Brick mantel or drywall with wood studs?
Although a TV looks attractive about a fireplace you have to consider that it is fatiguing to watch from such a high height. The optimal average height for a TV is 45" to centre (depending on furniture). If you exceed that by a few feet watching a lot of TV is awkward.
The advantage is it combines the focal point of the room, and instead of having a picture about a fire place, your TV becomes the work of art and can be used as a digital picture frame.
Jan 01, 2010 | Samsung LN52A850 52 in. LCD HDTV
I have a Town & Country fire place with a MAESTRO Control System which includes a wall control and hand held remote. There is a red light flashing on the bottom of the wall control under what appears...
Hi
behind the wall control there are 4 AA batteries that need to be replaced. you have to remove the wall control plate with a screwdriver and the batteries are tucked into the wall behind the wall switch.
ps - my husband is an electrician and he wired the fireplace but forgot that there were batteries behind there! it was me who asked for the screwdriver. ha!!
Dec 25, 2009 | Grilling
Wall mount for 52in tv ?
May 17, 2008 | Televison & Video
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
