Question about Toshiba Computers & Internet
Toshiba net book work load up keeps flashing toshiba
jan mczeal
  • 632 Answers
SOURCE: Toshiba SD-6000 dvd player tray will not open.
The tray is blocked or the drive motor is stucked. Unplug and open the player's casing and check for any obstructions and remove it. It might be a disc or something. Check the motor if it's trying to spin. if not, disconnect it and connect it to a 12-volt supply or lower. If it spins then there's a problem with it's supply. Otherwise the motor should be replaced.
Posted on Aug 07, 2009
  • 84 Answers
SOURCE: toshiba L40 won't switch on just keeps flashing help?
Check the battery, it is possible that they connection to the unit is either loose, severed or not working, Worst case scenerio the mobo is gone. Also remove the hard drive and or the memory to see if you get any graphics. either or could be stopping the boot process
Posted on Mar 31, 2010
Testimonial: "THANKS ALOT "
tagmonkey2k
  • 117 Answers
SOURCE: I have startup problem with my Toshiba A205-S4587
Have you tried tapping the F8 key when you boot up your laptop to get to the safe mode menu where you can then either select the last known good configuration or load safe mode. If this doesn't work try getting to a dos prompt and run chkdsk /f to check for hard drive errors. If all else fails you could reload the operating system from the original disc but you'll lose all of your files or you could try the recovery discs that came with the laptop but sometimes that results in the same thing. There are other options such as ultimatebootcd or taking the drive out and putting it into a USB HDD docking station to recover your files before formatting and reloading the o/s. Good luck.
Posted on Sep 30, 2010
  • 59 Answers
SOURCE: i have toshiba satellite L30-113
Hi, 1)Go to the below link. http://www.toshiba-india.com/laptop/DriversDetails.aspx 2)Under Product List, select Notebook Computers 3)Under series , select Satellite 4)Under Model select L30 5)Choose the type of OS 6)Under category select Display to download the VGA driver. 7)Good Luck
Posted on Nov 29, 2010
taran_2005
  • 10515 Answers
SOURCE: toshiba 42" flat panel tv.
Kindly provide few more details :-
1. Make and model of the TV?
2. How old the unit is?
3. If the power light is blinking I need you to count the amount of blinks between a pause please so it could be 4 blinks pause 4 blinks as an example?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 28, 2010
Error 0x00000709 when installing driver for Toshiba T8560
Here is what fixed it for us:
#1: cmd prompt (run as administrator)
#2: NET STOP SPOOLER (Keep window open)
#3: navigate to %SYSTEMROOT%\SYSTEM32\SPOOL\PRINTERS
#4: Delete all files in this directory
#5: Back to CMD Prompt window
#6: NET START SPOOLER
That should work.
Mar 23, 2015 | Toshiba Computers & Internet
I have locked myself out of my own computer and toshiba system
Go to the link below and download Ophcrack and install it to a bootable flash drive. It's FREE and works great. Boot from the flash drive and let it do it's magic. You'll have your password shortly:
http://ophcrack.sourceforge.net/download.php?type=ophcrack
Sep 03, 2012 | Toshiba Computers & Internet
Can i download a recovery disk for toshiba sattlite m105-s3041 for free?
It is rare that you can find that particular .iso as a download, but you can call Toshiba at 1-800-457-7777 and request a disk and they will mail you one. There's typically a fee, but it's not much.
Or.....
To access the Toshiba recovery partition, power off the laptop. Hold down the 0 (zero) key and turn the laptop on. Keep holding down the zero key until the TOSHIBA logo appears, where you should start tapping the zero key repeatedly. Stop if the unit beeps or when the TOSHIBA logo disappears. The screen should flash ** HDD RECOVERY MODE ** for a split second, then load the Toshiba recovery program right from the hard drive.
May 27, 2012 | Toshiba Computers & Internet
Is it possible to buy a spare parts of toshiba net book model nb505?
Yes it is. But not from the manifactor but from a supply house online.
Apr 17, 2011 | Toshiba Computers & Internet
I have toshiba satellite L30-113 note book i wan vga drivers to down load from net. I have tried but coudn"t get
Nov 29, 2010 | Computers & Internet
What is the step by step for reformatting of laptop computer-brand toshiba
To access the Toshiba recovery partition hold down the 0 (zero) key while you turn on the laptop. Keep holding down the zero key until the TOSHIBA logo appears, where you should start tapping the zero key repeatedly. Stop if the unit beeps or when the TOSHIBA logo disappears. The screen should flash ** HDD RECOVERY MODE ** for a split second, then load the Toshiba recovery program right from the hard drive.
Once the wizard shows up it will guide you through the recovery.
Note that this erases all data, and reloads all factory default software. Be sure to back up all your important personal data beforehand!
Jul 31, 2010 | Computers & Internet
Toshiba L40 won't switch on just keeps flashing help?
Mar 31, 2010 | Toshiba Satellite L45-S7423 Notebook
I just bought a Toshiba NB205 net book with built in web cam and ever since I?ve had it the computer says ?one of your USB devices is not working or cannot be recognized?
Is that particular message, is it referring to your web cam? If yes, download the driver from the support website of Toshiba and reinstall it on your computer. Here's the link. I searched it for you. http://cdgenp01.csd.toshiba.com/content/support/downloads/driver_camera_chicony_TC40025100G.exe Download the file, save it on your desktop then run it. Another solution is to reformat your hard disc or run system recovery.
Dec 14, 2009 | Toshiba NB205-N310/BN Netbook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
