Why my press and hold screen lock doesn't work
Control locked
Press and hold the stop button for 5 seconds.
Feb 17, 2013 | GE Profile Spacemaker XL 1800 36"...
No matter what button I press, it says 'locked' on the TV screen. How do I unlock it?
Try holding down the Menu button on the remote for at least 5 seconds, the child lock is on, If this doesn't work go to samsung website and find your user manual and follow the procedure they suggest.
Mar 06, 2012 | Samsung Televison & Video
Child lock is on , how do I get unlocked . Not sure how it got locked
Try pressing and holding the 'lock' button for 5 or more seconds. if that doesn't work, you can look up your particular owners manual online on Google with the manufacturer make and model no. but I think that will work
Aug 30, 2011 | Dishwashers
Un lock child lock 10d52 seimins washer dryer
to deactivate the child lock, set program to Easy-Care and hold option down arrow for 5 seconds. If still it does not get unlocked then Try pressing "dry" & "spin" together for 10 seconds or until the CL disappears. Also try pressing "end of cycle" for over 5 seconds. If this doesn't work then try pressing "options & select" till the light goes off. Also try and press ECO and rapid buttons together for more than 10 seconds.
Jun 26, 2011 | Washing Machines
The lady I work for has a Siemans washing machine, Sevie? IQ 1633 and does not know how to deactivate the child lock, also ther are a few silver buttond down the side of the main screen, she has no idea...
See your manual to reset the child lock. If you see the child lock button, press and hold it for 3-5 seconds and it should beep to reset.
If that doesn't work then unplug the unit for 30 seconds and try it again.
Jun 07, 2011 | Siemens WIQ1633 Front Load Washer
,i have my load but it is always says check operator services everytime i try to send a message
If the message "Check Operator Services" appears on the screen of your mobile when you attempt to make a call/sms, you should:
Check if there's a number 2 on the left hand corner of your screen.
If so, press and hold the # (hash) key until you see the message "Change the Phone Line?".
Press OK. The message "Line 1 selected" should then appear and the number 2 will disappear.
Attempt to make a call.
Note: Line 2 is an option on Nokia mobiles that's selected by holding down the hash key and pressing OK. Vodafone doesn't support this feature. You can prevent accidental changing of lines by activating your keypad lock. On some handsets, you can do this by pressing "Menu" then "*" to lock the keypad. "Menu" then "*" will unlock.
May 05, 2011 | Apple iPhone 3G Black Smartphone
How much to fix ipod touch screen and where
Good morning, afternoon, evening or night; whatever time of day you receive this. You want to know how much to fix the touch screen and where to fix it? I want this solution to benefit you as much as possible. Having to pay for someone to fix your iPod touch screen should be your last result. I'm tell you some options you can try that may save you a few dollars and having someone to fix the iPod touch screen. I don't if this is the problem, but the touch screen may be locked. Automatically, the iPod touch locks when there has been no activity for a certain amount of time. To unlock the touch screen, press and hold the Home button or the On/Off/Sleep/Wake button which is located at the top of your device, and then drag the slider. If you want to set the amount of time before Auto-Lock activates, press Settings, General, Auto-Lock; then set your preferred time. If that doesn't fix the problem, you can try a system reset. To do this, press and hold the Home and On/Off/Sleep/Wake buttons together for approximately 10 seconds until the Apple logo appears on your screen. If this doesn't work, you can take your iPod Touch to your local Apple Retail store and have an Apple technician work on it for you. There will be a fee for diagnostic services. You can also contact Apple Technical Support or Online Service Assistant. For more contact information, go to this website ( I hope the problem is just a screen lock up and if you have to get a repair or replacement, it won't burn a hole in your pocket. Thank you for choosing FixYa as your one-stop solution spot for your problems and requests. Have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
Apr 26, 2011 | Apple iPod touch
When i try to adjust the monitor controls message comes up OSD locked, how do I unlock it
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Oct 24, 2010 | Computers & Internet
When I hold down remote lock or unlock button to set, horn doesn'
Setting can be accesed through the radio to change options. Follor the owners manual.
Feb 25, 2010 | 2005 Chevrolet Malibu
Ipod lock
put the ipod in disk mode and see if it comes up on itunes.
Press and Hold the Menu and Center Buttons until the ipod apple logo come on the screen. The quickly switch your fingers to the Play/Pause and Center Buttons and hold until a check mark appears on the screen. Connect to iTunes and restore
If this doesn;t work let me know i can help you try something else
Jun 02, 2009 | Apple iPod nano
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
