Question about Xerox Office Equipment & Supplies
How can i fix the message 'chick consumables -replace the drum cartrige 'and code J4-1000 on xerox workcenter M118?
fotobean
  • 103 Answers
SOURCE: Our xerox M118 showing an
Hello, Your Xerox has two cartridges - one is the drum cartridge and the other is a toner cartridge. Please check the following I've researched from your user guide:
Replacing the Drum Cartridge
The drum cartridge is a customer replaceable unit. After approximately 55,000 copies/
prints, the machine will display a warning message before the drum reaches the end of
life. Order a replacement cartridge now to insure continuous operation.
Country Part Number for the drum cartridge replacement
All countries 13R589
Removing the Old Drum Cartridge
1. Pull the front cover towards you to open it.
2. Open Tray 5 (bypass tray) if necessary, and then open Cover A while lifting up
the release lever.
3. Lift up the colored lever, and slide the drum cartridge out until you can lift the
handle on top of the cartridge.
4. Hold the handle and remove the cartridge from the machine.
NOTE: When replacing the drum cartridge, make sure that the new cartridge is the
correct one specified for the machine.
Recycling the Drum Cartridge
The drum cartridge is designed to be re-manufactured. To recycle used drum
cartridges, return them to Xerox in the original packaging. Return labels are included
with each new cartridge.
Inserting the New Drum Cartridge
1. Remove the new drum cartridge from the box.
2. Undo the sealing tape and carefully pull out in the direction of the arrow to
remove the black protective sheet from the cartridge.
3. Place the cartridge in position and, using the handle, slide it into the
machine until it clicks.
4. Pull out the cartridge tape completely without breaking it.
5. Push the cartridge again so that it is correctly placed.
6. Close Cover A until it latches and then close Tray 5 (bypass tray).
7. Close the front cover.
Hope this helps. Good luck.
Posted on Dec 11, 2008
  • 17 Answers
SOURCE: Xerox Work Center 657 Will Not Recieve, After Replacing Drum
Check to see if when he reset the fax reverted back to receive only as a default.
  1. Press [Menu] (the Up arrow key), and press [3], [1], [0], then press [1].
  2. Select the Answer Mode:
    • Press [1] to select Auto answer, then skip to step 3.
    • Press [2] to select Manual answer, the press [Stop] to return to the Standby mode.
  3. If you select the Auto answer feature, use the numeric keypad to enter the number of times (must be 2 digits, 01-10) the phone must ring before the machine answers, then press [Enter].
    NOTE: When the machine is set to Auto answer and the set number of rings occurs, the machine answers with a fax signal tone and enters the Auto Receive mode.
  4. Press [Stop] to return to the Standby mode.
Posted on Apr 03, 2010
SOURCE: Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Posted on Jan 24, 2011
  • 2072 Answers
SOURCE: WorkCenter M118 it stop sending
Solution : Make Sure the SMTP (Mail) Server is an Open Relay Server or Uses POP-Before-SMTP Authentication The mail server being used must be an Open Relay server or use POP before SMTP authentication. If the mail server being used requires SMTP authentication, the scan to e-mail process will fail. The WorkCentre is unable to access the mail server when SMTP authentication is required. Contact your Internet Service Provider (ISP) or System Administrator for additional information.
NOTE: The WorkCentre was designed to send e-mail through internal corporate mail servers. In most cases, if using your Internet Service Provider (ISP) mail server, the scan to e-mail process will fail because most ISP mail servers require SMTP authentication to send mail. Contact your ISP for additional information.
Posted on Feb 24, 2011
Kylen Wiggin
  • 35 Answers
SOURCE: where can I get printer driver for Xerox
The M118 is a PostScript printer, which is an older (but fully functional!) protocol that allows Windows to print the correct fonts and typesetting.
In order to use this device as a printer, you will need to have the PostScript module installed in the printer, and then install the printer drivers.
Drivers can be found at this link, and support documentation at this link. The two particular support documents you'll want to review are the User Guide and the PostScript User Guide.
Hope this is helpful!
Posted on May 09, 2011
How to reset xerox m118 drum counter
Hi Laurynas Straksas,
What very frequently happens with those machines is this. On the drum cartridge, there is a green cover in front. Behind that cover there is a series of gears, one has a flag like tab sticking out. That tab is the drum reset, what it does is makes one swipe past the drum reset switch when you install it and that resets the drum life by swiping a switch one time. That flag has fallen and did not swipe your switch, you can do one of 2 things. You can have whoever you purchased the drum from replace the cartridge, or you can pop off that green cover and manipulate that flag to an Up and to the up position and replace the cover and install the drum in the machine, once the machine runs it will swipe the switch and reset the drum count, turning off the light and allowing your machine to run. Once you take the green cover off you will easily see what I am talking about, Flag will be down, work it until you get it in the up position. That will do it.
Aug 26, 2014 | Xerox WorkCentre M118 Black and White...
Hi, I have a solution to your problem click on the link below which will direct you to a step-by-step guide to fix your problem!
Xerox Workcentre 123 128 Reset Drum Life Free
Where can I get printer driver for Xerox WorkCenter M118, I'm using Win 7
May 09, 2011 | Xerox WorkCenter M118 All-In-One Laser...
NOT PRINTING IN WINDOWS 7
update your driver download the compatible driver for window 7
http://www.support.xerox.com/support/workcentre-m118-m118i/downloads/enus.html?operatingSystem=win7
Apr 19, 2011 | Xerox WorkCenter M118 All-In-One Laser...
I need a driver for this printer with OS windows 7 32-64 bits will u help me
download driver from "http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=WCM118_WCM118I&Xlang=en_us&Xcntry=USA"
Aug 18, 2010 | Xerox WorkCenter M118 All-In-One Laser...
Our xerox M118 showing an error"replace drum cartridge'can any one help me?Plizzz
the release lever.
Dec 11, 2008 | Xerox WorkCentre M118 Black and White...
Printer makes a ticking sound and would not print
The front and left cover interlock switchs are bad.
The spring inside the switches get weak and are marginally making contact.
Not good enough contact to close, so it sits there and clicks and clicks and clicks.
One or both of those switches need replaced.
Jan 18, 2008 | Xerox WorkCenter M118 All-In-One Laser...
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
