Question about The Audio Players & Recorders
I have successfully synced my 2 Charge 3 speakers. but when i turn the sound up or down one of the speakers shuts off then returns to playing in about 5 to ten seconds. Can this problem be cured?
I have noticed that when i go to my bluetooth connections both speakers are identified as Charge3. could that be the problem?
  • 14 Answers
SOURCE: Overload
try turning the unit off in standby mode then hold down the enter button and then the power button for about 10m seconds that should reset the unit depending on how new the unit is it sometimes has a digital saftey setting but i doubt that would cause it to do what you are saying
Posted on Apr 02, 2008
Benimur
  • 6966 Answers
SOURCE: vga pinout schema for samsung 753dfx
Apparently what you need are the wiring for the VGA cable itself. They would differ from manufacturer to manufacturer since it is not a Samsung item. Would the schematic and/or Service Manual of the Samsung chassis AN17K (753DFX, 76DF, 753V, 753S, 76V or 76E) help? if so, pls try here, here or here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 16, 2008
polarcycle
  • 1392 Answers
SOURCE: starts and runs 3-5 seconds and shuts down
Sounds like your security system is shutting the car down. You should be able to leave the key on for 15 minutes and it will reset itself. Make sure you are using factory keys, and they are in good condition.
Posted on May 28, 2009
benwabnick
  • 2404 Answers
SOURCE: Gameboy not charging
Sounds like the cells inside of the battery are weak and can't hold the charge. If possible, try a known good working battery and then charge it up. If the charge holds and you can run the battery off of it for a while then you know the original battery is bad.
If you try a known good battery and the charge still doesn't hold then it could be the main board inside of the GBA is bad and you would need to get another system unless the one you have happens to still be under warranty.
You can also try a know good ac adapter at that point as well to make sure your adapter isnt flaky but if you can turn on your gba with just the adapter hooked up then more then likely the adapter is good.
Posted on Jun 27, 2009
SOURCE: Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Posted on Aug 06, 2009
Any way to Factory Reset a JBL Charge 2 ?
Yes, follow this sequence:
1. Turn the device on
2. Press the call (phone icon) and the volume up (+) button at the same time and keep them pressed. After a few seconds the speaker will shut down.
3. Release the buttons.
4. Turn the speaker back on. It will automatically enter into search mode... And there you are, memory wiped up.
Good luck.
Sep 19, 2015 | JBL Charge 2 Portable Bluetooth Speaker |-...
My pioneer sx 203 stopped working. It no longer powers up. It was playing fine then I turned the volume up from 3 to 5 and it totally shut down. Doesn't work at all now.
If it shuts down after turning up you have a speaker and or speaker wire issue, Try disconnectiong all speakers and see if it shuts down then, If it shuts down with no speakers connected then you do have a receiver problem
Feb 18, 2015 | Pioneer Audio Players & Recorders
In regard to my Marantz AV Surround Receiver, Model number SR5005, I cannot get the Zone2 speakers to play. I have followed all the instructions, and nothing works. Does anyone know what I need to do...
have the same model. just got it to work. but, struggling with one part. here's the scoop. 1. Plug your second zone speakers into the SURR BACK/AMP ASSIGN speaker outputs on the unit. 2. You need to "amp assign" the speakers to zone 2 by pressing AMP, MENU, select SPEAKER SETUP, AMP ASSIGN and scroll to ZONE 2 - this will force the sound to the speakers that you plugged in. 3 - Turn on Zone 2 (press Z2, press ON button on remote). Use the UP/DOWN arrows to select the input for Zone 2. I've only been successful in selecting USB and plugging my iphone in for zone 2. For some reason, I cannot get the SAT (cable box) to play in both zone 1 and zone 2 at the same time. But, I can get SAT in zone 1 and USB in zone 2. Hope that helps. Let me know if you can solve my issue...
Apr 13, 2011 | Marantz SR5005 Receiver
IT AS FROZEN
Hi,Use the below instruction.
Flip the MP3 player's "Hold" switch to "Off" if the switch is on. Depending on the MP3 player you own, this switch is likely located at the side or top of the player. Once the switch is off, try to turn the player on.
Let the battery of the MP3 player die. A frozen MP3 player is technically still running, and thus the battery for that player is being drained. Wait until the battery is fully dead before moving to Step 3.
Charge the MP3 player using either a computer (that's turned on) or an electronic MP3 charger. Charging the player's battery may "jolt" the player out of its frozen state. Connect the player to the computer or charger via the player's USB cable. Charge the player for 30 minutes before attempting to turn it on.
Sync the player with the appropriate software program (for example, Windows Media Player) for the MP3 player. Connect the player to the computer as described in the previous step. Open the software program and click the "Sync" tab at the top or side of the program. If necessary, click "Start Sync" underneath the tab. The name of the player appears under the "Sync" tab if the player has synced successfully. Try turning the player on once it has synced with the program.
Press the small "Reset" button on the MP3 player. This hard reset shuts the player down completely. Use a pin, tack or thin nail to press down the very small "Reset" button on the side or back of the MP3 player to reset the player. Then, try to turn the player on.
Tips & Warnings
Take the player to an electronics store if none of the steps above unfreeze the player, as there is likely a serious problem with the MP3 player's hard drive.
Also take out the batteries, if holding the play button for like 5 minutes doesn't work.
Hope that helped.
Have a nice day..
Feb 23, 2011 | Audio Players & Recorders
My Bose Companion 3 coputer speakers are 2 years
i hav the same problem but all three shut off ,and i have to shut off and turn on again
Jul 29, 2010 | Bose Companion 3 Computer Speakers
When I plug my Onkyo receiver in it turns on and off on its own in intrevals of about one second. Is this a bad power supply or something else?
follow these steps:
*disconnect everything from the unit (treat it as if you just got it out of the box) no speaker wires no cables.
* turn on the unit and max the volume (w/o anything connected)
*if the unit shuts off during step 2 you need to send it in for service (go to onkyousa.com for the nearest service center)
*if it didn't shut off during step 2 you need to play the tuner and connect one speaker at a time.
EXAMPLE: connect your left speaker and then play the FM and then max the volume for about 2 seconds then turn it down.
if you were successful in maxing out the volume on the left speaker continue with the other speakers until you isolate w/c speaker is causing the issue. if your gonna ask why the FM...its because its a direct playing source but you can still use a cd player or a tape deck to try it out.
take note: if your receiver shuts down on a speaker that you have connected make sure to have that speaker checked or better yet replace it.
May 03, 2009 | Onkyo TX-8511 Receiver
A8N SLI Deluxe Sound device/driver not working.
Have you tried using microsoft system restore to roll back your computer to when your friend did the dirty deed? To use it, go to start> all programs> accessories> system tools> system restore. If it hasn't been too long since you got it back, you might be able to recover your system very easily using system restore, but do it right now, because the longer you wait, the more likely it is that the repair record has disappeared.
Mar 26, 2009 | ASUS A8N-SLI Deluxe Motherboard
I pod nano
My ipod nano won't play music just through my headphones- it also plays through speaker and it makes the music sound like you are in a tunnel. How do I turn off the external speaker?
Jun 16, 2008 | Audio Players & Recorders
No sound.
Disconnect speakers one by one and reset the unit each time. If the speaker is blown, or the wires are frayed, it will shut down the internal amp. Also check the fuse in the back of the radio first, it should be near the wire harness. Power cycle the unit as well, unplug it from the power source, plug it back in. Hope this helps.
Aug 16, 2007 | Clarion M475 CD Player
24 people viewed this question
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
kbrowndo4u
Level 1 Expert
chrisheman
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
