How do I get a single plastic MOEN tap back on the stem ?
I removed it to clean, now it won't go back on !
  • 923 Answers
Can you be any more clear about your problem, such as a detailed description? Responders are not mind readers, you know!
Posted on Apr 20, 2017
Testimonial: "Itis a single plastic MOEN shower tap. Removed to clean, now it will not got back on the post.."
Moen kitchen faucet 87440 single handle model
remove stem, turn it half a turn in either direction (180deg.) replace stem and your good to go
Dec 01, 2012 | Moen 87440 Single Handle Kitchen Faucet...
I have taken the holdign retainer out of my moen 87440 but can't get the stem out please help
the stem is part of a cartrige its either brass or plastic covered with about 6 " O " rings. it gets corroded in place. moen sells a cartrige puller. see a plumbing supply house such sa HUGHES SUPPLY or Ferguson or o local plumber.
May 20, 2011 | Moen 87440 Single Handle Kitchen Faucet...
How do you remove a cartiarigde from moen shower body (single handle)
There is a special tool that yo can use to remove an old and stuck moen cartridge and they can found at your hardware store. Now before you remove the cartridge be sure to remove a small brass or copper pin located at the top of the stem. you will see a groove in the stem cover where the pin is located. once the pin is removed hookup the puller and remove stem. sometime you are able just to grab the stem with a pair of pliers and give a good pull and twist to get it out. don't pull to hard to damage the plumbing in the wall. good luck and I hope I was able to help. As always, TURN OFF THE WATER FIRST...
Feb 11, 2011 | Moen & One Handle Tub & Shower Faucet
I have a moen single handle tub and shower faucet took out the clip and pulled but the stem will not come out what esle is holding it
You need to purchase a replacement cartridge before trying to remove a defective Moen cartridge. Always buy genuine Moen. If your valve turns on and off with a pull/push action you need part number 1225B, otherwise you need part number 1222. The 1200 cartridge will work in lieu of the 1225B but is more expensive and no longer used in Moen valves. There is a tool that comes with these cartridges which looks a bit like a white plastic cap.with notches on one end and a square head on the other.
Once the clip has been removed the only thing keeping the cartridge in the vslve is old sticky lubricant. Place the tool over the cartridge end and rotate as necessary until the notches are fully engaged and it no longer rotates. Using pliers or a wrench over the squared end, twist the tool back and forth several times. Remove the tool, and using pliers, pull the old cartridge out. Put the tool on the replacement part and insert it back into the valve. Lightly tap on the squared end to make sure the new part is completely seated, then use the squared end again to turn the cartridge as necessary to align for the clip to be reinstalled.
Nov 06, 2010 | Moen & One Handle Tub & Shower Faucet
Moen Single Handle Shower faucet can't get cylinder out
New moen cartridges for tub/showers come with a handy white plastic tool to aid in old cartridge removal. One end is squared off for a wrench, the other is slotted to place over the old cartridge in the wall after the clip has been removed. Place onto cartridge and use a wrench to turn several times back and forth. Remove , grab the stem with pliers and give a tug. You want either service part #1225B (pull/push to turn on) or #1222 (just turn knob counterclockwise to turn on. Get the replacement before you proceed.
May 06, 2010 | Moen & Bayhill& Single Handle Tub & Shower...
Leaky moen 2 handle faucet
if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
Apr 26, 2010 | Moen Monticello Single-Handle Kitchen...
Moen single stem bathroom basin tap (25 years old). Trying to remove cartridge to grease it or replace it. Have removed handle and retaining clip. Pulled hard but can't shift it. Don't want to break...
You are on the right track. You have to use some force when pulling the stem from the faucet. Your replacement cartridge should have a little black or whit cap. that is inserted on top of the cartridge and by turning the cap will help loosen the whole cartridge
Feb 21, 2010 | Moen & One Handle Tub & Shower Faucet
How do i remove the cartridge from a moen pull out spayer
There is a tool for this job. Its a stem and cartridge puller made for moen fausets.PASCO makes one in my area.Ask a sales rep at a local plumbing supply.The rep should be able to sell you one ,or tell you where to get one.
Dec 11, 2009 | Moen 7437 Chateau Single Hole Kitchen...
Water leaks from around the stem when I lift the water handle. What to do? It doesn't drip from the tap, but from around the stem part - sometimes quite a lot of water. Can I repair this myself? It's a...
ur cartridge needs service or replacement u can turn off water supply remove lever and retaining nuts pull up cartridge and inspect the o rings for debris and or damage if good inspect cartridge for damage if looks check gaskets/o-rings in stem for same add a little vasline around o-rings and reinstall test for leak if leaking still replace all o-rings or if cartridge order and replace
Nov 03, 2009 | Moen 87530 Touch Control Single Handle...
How do I pull a moen single lever kitchen cartridge out that is old and stuck?I removed the horseshoe shaped clip. When I pull the valve stem, it doesn't budge.
there is a little plastic tool that comes with a new use it to turn the cartridge back and forth....breaking the seal that has formed between the rubber on the outside of the cartridge and the inner wall of the valve. After doing that you should be able use a pair of channel locks to pull the cartridge out.
Oct 20, 2009 | Moen & Replacement Cartridge
Washing Machines Logo
Top Washing Machines Experts
