Shampooe is leaving streaks - Office Equipment & Supplies
4 Suggested Answers
  • 174 Answers
SOURCE: when shampooing the clean water comes out
Sounds like the brush is not turning. Could be the belt or jammed
Posted on Aug 06, 2009
Vac Belts
  • 701 Answers
SOURCE: Kirby G4 causes black streaking when shampooing carpet
Replace the belt it is probably worn. You can get a replacement here:
Kirby G4 Belt
Posted on Dec 06, 2009
small6363
  • 18409 Answers
SOURCE: kirby shampooer is leaving streaks and shampoo comes out in a small streak
go to this link for instruction on how to use shampooer
http://www.goodvac.com/Articles.asp?ID=153
Posted on Nov 12, 2012
Is the Kirby shampooed supposed to pick up the water after shampooing
No. Shampooing is supposed to crystallize the dirt so you can vacuum it out. It is easy to leave to much soap residue.
Sep 05, 2017 | Kirby Vacuums
How do I get the Shampoo solution tub unclogged so it mixes with the water to clean my carpets.
You can try adding hot water, but your best bet is to remove the tank and hose and flush them well with hot water to clean them out.
Jan 02, 2015 | Bissell Brushroll Proheat 2X 8920 9200...
Kirby G4 Belt
Dec 06, 2009 | Kirby G4 Bagged Upright Vacuum
Why does my epson stylus 1400 leave streaks in the print?
The tracking wheels (spiked wheels) can pick up ink and lay it back down. They can also accumulate debris that collect ink and put it down in the form of streaks. This is especially true if you use dusty or moist papers (or frosting sheets).
Oct 11, 2009 | Epson Stylus 1400 InkJet Photo Printer
What causes the toner to leave color streaks on the paper? It's leaving red streaks and I've replaced the magenta & black developers....but could it be the PCU causing the problem?
The developers almost never streak. I would be looking at your PCUs. Developers have a tendency to leave voids and dust the paper. PCUs tend to streak as the cleaning blade and charge roller wears out.
Jan 24, 2009 | Ricoh Aficio CL7200 Laser Printer
Kirby Vacuum Shampoo Attachment
If your trying to shampoo your carpets but the water flow is to weak and it trickles through the spout to the carpet leaving small puddles
This problem often occurs when the foam filter is not replaced after rinsing or ends up in the shampoo hose at an angle preventing foaming. If you take the small shampoo hose of the shampoo tank the filter should be on the tank, if not, it may have come off and be in the hose. If it’s not there locate it, likely in the area where you last cleaned the shampooer or in the box, and put it back on the tank. While this should be cleaned after each use, care should be taken to replace it and not lose it.
The problem may also occur if you don’t actually add the Kirby Dry Foam Shampoo to the water or if you use some thin else.
Take care to also clean and replace the air filter after rinsing. It is located under the shampoo tank where the tank fits onto the vacuum.
Phil-T
Sep 07, 2007 | Vacuums
23 people viewed this question
jasbo
jasbo
