Question about Panasonic Televison & Video
Hi, could you tell me how to set up my zeppelin air as a speaker for my Panasonic viera tv?
SOURCE: Panasonic viera
1.You may have the magnet of a speaker too close to the TV.
2.Turn off other electrical devices in the house one at a time.
3.Faulty cable.
Puzzler.
Posted on Oct 31, 2007
SOURCE: cant get my viera linked panasonic to play through surround sound
I had the same problem, so i contacted panasonic, I am including the email they sent me.
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Posted on Dec 17, 2008
SOURCE: SET UP VIERA LINK PANASONIC PT960
The first question you need to answer would be, "Does your TV support Viera Link?" Most newer Panasonic TVs and other A/V devices support it, but it's hit or miss (usually miss) with other brands. I know Onkyo is one brand that has stepped up and offered Viera Link support on some of its devices, but I'm not sure about others. If your LG brand TV doesn't support Viera Link, you are out of luck and you'll have to rely on seperate remotes for the TV and home theater. If your TV does support Viera Link, the next question would be, "Are you using HDMI to connect the devices?" Viera Link can only communicate over HDMI (not component video, S-video, coaxial, composite, digital optical audio, etc.) If either of the aforementioned questions were answered "no", you can still connect your devices and use them normally, but you won't get the benefit of Viera Link communication between the devices. In that case you will likely have to keep using separate remotes.
Posted on Jan 09, 2009
SOURCE: Connection problems with Panasonic Viera Cast
I have had the same problem with my Panny DMR-BS850 which was resolved by changing the ethernet cable I was using which had only 4 contacts on each plug end for one which has 8 contacts. I tried all variations & combinations of IP & DNS before buying the new cable from my local pc store (£10 for 10m cable) and was relieved when setting the system to auto connect it worked within 3 mins. I think the slight delay was the router setting up a new address for the new hardware it detected.
My new cable states on it "Verified For Gigabit Ethernet" and is Cat 5e rated and I was assured that it will carry data for runs up to 95m long, which is contrary to the Panasonic support agent who told me to shorten my initial 5m cable to prevent signal degradation.
Give it a try.. it might just work.
Posted on Jul 21, 2009
djchillsnyc
  • 152 Answers
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Posted on Oct 14, 2009
I am getting no sound out of my Panasonic Viera TH-50PX80U Plasma TV
Are the speakers' cables connected correctly? (p. 37) Is "Sound Mute" active? (p. 13) Is the volume set to the minimum? Is "Speaker output" set to "Off"? (p. 22) Change "SAP" settings. (p. 16) Check "HDMI 1 in", "HDMI 2 in" or "HDMI 3 in" settings. (p. 22)
Hope this helps, page# refer to your manual.
Feb 14, 2015 | Panasonic Viera TH-50PX80U Plasma TV
How do i set my home theatre as the default speakers on my viera led/lcd tv. When i turn off the tv and my JBL SB350 soundbar it resumes to tv speakers when i turn it on again?
Page 104 of the manual. It's through the Viera link settings. I have a similar TV. It's a little convoluted.
Through Viera link you set sound selection to Home Cinema and it mutes your TV speakers when your external speakers are on. I use that now now with a similar sound box (Zvox). It works fine. That doesn't work with the playbar...
enable hotel mode by pressing, at the same time, the down volume button on the side of your tv and the 'tv' button on the remote 3 times. A menu will pop up where you can set max volume to 0.
Jan 01, 2015 | Panasonic VIERA Televison & Video
How to set up the colour on my Panasonic Viera TV
http://service.us.panasonic.com/OPERMANPDF/TH42PZ80U.PDF
Here is a copy of your users manual, it tells you how to adjust the color on the TV, Magnets do not affect Plasma TV's. If your picture looks bad you might have a defective or failing part if you just need to turn the red up or down or make the picture more blue or green the users manual tells you how to adjust it.
Sep 10, 2014 | Panasonic Viera TH-42PZ80U Plasma TV
On panasonic viera tx 32 Lx where can I turn off TV speakers sotahat I can play sound through denon sound system
When you plug in to the aux audio jack, that cuts out the speakers automatically. There is no switch.
Jan 11, 2014 | Panasonic Viera TX-32LX70 32 in. LCD TV
DOES PANASONIC 42" VIERA TH-L42U5S" BROADCAST VIDEO FILES FROM FLASH DRIVE? WHEN I CONNECT MY USB DRIVE TO THE TV, THE VIDEO FILES COULD NOT BE RECOGNIZED BY TV, JUST MUSIC AND PICTURES CAN BE VIEWED....
No this TV does not process video files from USB. To improve sound quality reset the sound settings to midrange on all settings. Too much bass causes the sound to be muddy, especially on vocals
Feb 01, 2018 | Panasonic 42" Viera U5 Series LCD HDTV -...
Panasonic Viera 42 LCD tv, no sound from speakers
Go into menu of the TV and go to the setup for sound and pich internal speakers.
Dec 26, 2012 | Panasonic 42" Viera U5 Series LCD HDTV -...
I have a zeppelin air. when i set it up on my mac every other day it looses its blue tooth connection and i have to go thru the set up all over again any sugestions???
The same problem. No sound im my zeppelin air bought this month. In dock or via air play with iPhone4 or AppleTV. Firmware already updated. Any idea how to fix it?
Dec 07, 2011 | B&W Bowers and Wilkins Zeppelin iPod Music...
For internet apps (like Netflix and Youtube), the sound will only come out of the TV speakers rather than the receiver and external speakers. When I click "Viera Link", it indicates the TV...
Must go into the tv Menu go to OPTION go down and pick VARIABLE setting for output for extrenal speaker system.It should not setup on Menu OPTION setting on FIX setting,tv will used tv speakers system only.
Aug 27, 2011 | Panasonic VIERA TH-65PV500 65 in. Plasma...
My volume just shut down on me. how do I turn it
go into menu of tv make sure speakers are turned on--if you are using a cable box turn the cable box volume up-let me know if this helps you-djstvrepair@comcast.net
Sep 04, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic viera
3.Faulty cable.
Puzzler.
Oct 19, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Televison & Video Logo
24 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
