Question about Coffee Makers & Espresso Machines
It is a perculayor, no door no button brand new won't brew
    Top Expert:
  • 24,341 Answers
Send it back for a free replacement.
Posted on Apr 20, 2017
Brand new Cuisinart SS-10 single seven coffeemaker was set up to brew and when brew button was pushed it turned off and won’t turn on again.
As long as you read the instructions from cover to cover twice, if it doesn't work, pack it up and take it back.
Jan 23, 2018 | Cuisinart Coffee Makers & Espresso...
The reset button popped and now won't reset.
Circuitboard problem. Needs replacement.
Nov 02, 2012 | Keurig B200 Brewing System
Saeco Royal Digital Plus - I cannot insert the brew unit into the machine
Hi Remove the dredge drawer. Open the right side door. On the left side and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly. The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not just push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door, insert the dredge drawer and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door, pull out the dredge drawer and insert the brew group. Done PS: If it still won't go in you might have a broken brew drive. The gear in the back of the machine where the brew unit goes has 2 large teeth. They should be in the 10:00 and 12:00 position. If they are in the 3:00 and 5:00 or that side you have a broken drive and the gears need to be replaced.
Jul 06, 2011 | Saeco Royal Digital Plus Coffee...
Saeco Vienna - I turned on the coffee machine and instead of the usual whirling of the parts getting into place, it sounds like it is struggling to get into place. I looked inside and the bar is down where...
Hi Its hard to say with what you have said, but if the brew unit was cycling slowly, it may be the board. Close the door and make sure that everything is in but the brew unit. Turn the machine on and see if it cycles the gear in back to the starting point. It may take a few minutes to cycle if its the board. If it returns its the board. I have some boards.
Jun 13, 2011 | Saeco Vienna Espresso Machine
Brew Unit will not go back into place
Hi
You must make sure that the brew unit is ready to reinsert into the machine. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit, (it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door with the drip tray and dredge drawer inserted and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and remove the tray, and dredge drawer, now replace the tray and insert the brew group. If it still won’t go in check the cog in the back of the machine. There are 2 wide teeth that should be at the 10:00 and 12:00 position. If they are at a different position you have a broken drive gear.
Apr 18, 2010 | Spidem Trevi Digital Coffee Maker,...
The brew group does not want to "snap" back into place. Not sure what is misaligned...
Hi
You must make sure that the brew unit is ready to reinsert into the machine. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,( it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door with the drip tray and dreg drawer inserted and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and remove the tray, and dreg drawer, now replace the tray and insert the brew group. If it still won’t go in check the cog in the back of the machine. There are 2 wide teeth that should be at the 10:00 and 12:00 position. If they are at a different position you have a broken drive gear.
Oct 16, 2009 | Saeco Spidem Villa
Saeco Vienna delux
The brew group is out of place.
--> --> The brew group cannot be taken out.
--> --> Turn on the machine and close the service door. The brew group will automatically go back into place.
The brew group is out of place -Turn on the machine and close the service door. The brew group will automatically go back into place.
May 07, 2008 | Saeco Vienna Deluxe
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
