How do I Divide polynomial using TI-Nspire - Office Equipment & Supplies
SOURCE: TI-nspire will not turn on
Yes we changed out the batteries on now the TI-84 will not turn on HELP
Posted on Nov 25, 2009
  • 8068 Answers
SOURCE: TI-Nspire 84 Plus keypad problem
Remove the TI84 Keyboard, insert the TI-Nspire keyboard and try to reset the calculator with a starightened paper clip.Calculator has a reset button on the back.
Posted on Feb 01, 2010
  • 24 Answers
SOURCE: I have issues turning on my TI-Nspire using TI-84 Plus SE keypad
i would say use the normal key pad or send it in to T.I to fix.
Posted on Mar 12, 2010
  • 12 Answers
SOURCE: I downgraded my TI-Nspire's OS
I had this same problem myself and I had to look everywhere to find a solution. You will have to remove the current OS from your device. Heres how.
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=101985&nUsePub=NO&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZGC81E19298A9321E38D51491551F331C8CCDA6801E50CC672F84B3EFDF0F6ACEF9DD42026E6C2FF1F9579670CF87CEAF79D
I couldnt use option 2 for some reason and had to use option 4 (complete format, luckily I had backed the files up earlier) but once it was reformatted the device showed up in the software and told me to update the OS. From here you just install the latest OS as you would normally.
The problem with what you and I did is that previous OS versions (1.7 in my case) dont support the keypad, you may be able to use the older version with a different keypad but I'm not sure.
Anyway, I hope you can fix it, good luck.
Posted on Jan 08, 2011
  • 52 Answers
SOURCE: Divide Polynomial by a Binomial
I think this link will be helpful.http://www.sparknotes.com/math/algebra2/polynomials/section2.rhtml
Posted on May 03, 2011
TI nspire wont divide
Press CTRL-Enter to get a decimal result
Sep 20, 2012 | Texas Instruments TI-Nspire Graphic...
When trying to divide two complex numbers in a+bi format, some of my students get the Data Type error message. I don't know why or how to help them. Can you help? Each complex number was enclosed in...
Here is screen capture of a similar calculation, performed on TI Nspire with TI 84 plus keyboard.To type in the imaginary unit use key sequence [2nd][dot], do not use [ALPHA][X^2] for the letter i.
Jun 08, 2011 | Texas Instruments TI-84 Plus Calculator
Where is the application for polynomial solver
In scratchpad, you click menu, then go to algebra. It will be in that menu.
Sep 17, 2010 | Texas Instruments TI-Nspire Graphic...
Mar 12, 2010 | Texas Instruments TI-Nspire Graphic...
How do you get the exact value of axis intercepts of a polynomial function, when it is sketched and the given intercepts are presented as approximate values?
Use 2nd Table Set keys after you type your function into y=
Change your independent variable to ask if you know that y=0 and you are trying to find x
Change Dependent Variable to ask if it's y that you are trying to find
Then go to table and seek answers
Mar 02, 2010 | Texas Instruments TI-Nspire Graphic...
Ti 84 nspire,replaced batteries and now it says "operating system not found,install OS" Of course my son has a finals exam tomorrow..help!!
Hi
A. Download the TINspire OS from education.ti.com
Use the Ti-Nspire computer link to reload the OS onto the calculator.
  1. Remove the Ti84 keyboard and insert the Ti-Nspire keyboard.
  2. Make sure the battery are good.
  3. Connect the TI-Nspire device (with the Nspire keypad) to the computer using the USB Standard A to Mini B cable
  4. Run the Ti-Nspire computer link software.
  5. The select device dialog should appear, and detect the device.
  6. With the mouse cursor, select the OS, drag it and drop it on the main window (file browser window) of the TI-Nspire computer link software.
  7. Alternatively, click the menu Tools and select Install OS. A Select file window opens.Use the browse button to point to the OS and click Open/OK
B Installing from another Ti-Nspire ( not a TI-Nspire CAS) if availabe)
  1. Connect the two devices using the USB Mini A to Mini B cable
  2. The end marked A should be inserted into the sending unit, while the end marked B should be inserted into the receiving unit.
  3. Both units must be turned ON
  4. On the sending unit, access the document chooser by pressing [Home](the house icon).
  5. Once in the document chooser, press [Menu] and choose 9:Send OS…
Hope it helps.
Thank you for rating the solution.
Dec 11, 2009 | Texas Instruments TI-84 Plus Calculator
My TI Nspie CAS calculator is restarting frequently
If you remove battery door, the TINspire CAS cannot be turned ON.
You may try to reset the unit by pressing the reset button on the back of the unit. If that does not solve the problem, you may try to reinstall or update the OS.
Anyway, here is what the Texas Instruments Knowledge Base has to say about reinstalling the OS. Hope it helps.
What steps are required to reinstall the TI-Nspire family operating system?
To reload the device’s OS using a computer with TI-Nspire Computer Link:
• Connect the TI-Nspire device (with the Nspire keypad) to the computer using the USB Standard A to Mini B cable.
• Open the TI-Nspire Computer Link software. The select device dialog should appear, and detect the device.
• Either drag the OS file (available in the ‘downloads’ area at education.ti.com) onto the TI-Nspire File Browser portion of the window, or click Tools -> Install OS.
To reload the device’s OS using another TI-Nspire or TI-Nspire CAS device:
• Connect the two devices using the USB Mini A to Mini B cable. The end marked A should be inserted into the sending unit, while the end marked B should be inserted into the receiving unit.
• On the sending unit, access the document chooser by pressing [Home] [7]. Once in the document chooser, press [Menu] and choose 9:Send OS…
NOTE: Users can only send an OS to a unit of the same model. Users cannot send an OS from a TI-Nspire to a TI-Nspire CAS.
Please see the TI-Nspire guidebooks for additional information.
Oct 08, 2009 | Texas Instruments TI-Nspire Graphic...
I have a TI-nspire CAS calculator. When it is switched on it begins loading and then comes up with System Error. What do I do?
You should ( a suggestion) reset the OS by pressing the button on the back of the unit.
If that does not work, you may consider reinstalling the OS. The procedure as described in the TI Knowledge Base is as follows.
Hope that helps.
May 08, 2009 | Texas Instruments TI-Nspire Graphic...
Deleted OS
Here is what the Texas Instruments Knowledge Base has to say about reinstalling the OS. Please read it till the end.
Mar 23, 2009 | Texas Instruments TI-Nspire Graphic...
Can keypads only for the ti-nspire be purchased?
http://epsstore.ti.com/OA_HTML/ibeCCtpItmDspRte.jsp?section=11092&item=76072&JServSessionIdrootdlek22=umke2gv3m1.n6LzoN8M/AzOnMTOogTxpQOUtxCLbx0Ka0--
Dec 12, 2008 | Texas Instruments TI-Nspire Graphic...
20 people viewed this question
k24674
jasbo
jasbo
