Question about Garden
502.255190 deck belt - Garden
    New Friend:
  • 85 Answers
Apple Certified Experts will answer you for free -
Posted on Apr 20, 2017
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
Belt is to long, is there a deck adjustment?
Jim, Double check to make sure you have correct belt for the deck and are installing it in the correct configuration as per manual or drawing on deck. Very few lawn tractors have deck belt adjustment, most do not, most deck belts have a spring loaded tensioner to take up the slack.
This could be some of your problem, the tensioner/idler pulley sometimes seize up and must be lubed up till they move freely, or your belt could be loose. Look in your manual or try google searching your make, model #, deck belt adjustment.
How to Change Riding Lawn Mower Deck Belt
Mower belt tensioner repair question to the Garage Gang
lawn mower deck belt routing Google Search
May 20, 2016 | Garden
Can you show me the correct diagram for the drive belt on a 44in Dixon zero turn mower
Hope this helps. Serpentine Blade Drive Belt
1 Lower the mower deck to its lowest position.
2 Route the serpentine blade drive belt (part number 6109) onto the V-pulleys located on the mower deck. One double pulley is located at the front of the deck near the center. The other two pulleys are located near each side of the deck. Route the belt around the outside -- the side toward the outer edge of the mower deck -- of each pulley. For the double pulley near the front of the deck, route the belt around the lower pulley (part number 6058) only. If pulleys are fitted with belt guards, work the belt in between the pulley and shield.
3 Push the idler pulley toward the center of the deck with your hand. The idler pulley (part number 6059) is the fourth pulley on the deck and is located near the rear of the deck. It is the only movable pulley on the deck. Wrap the belt around the side of the pulley nearest the edge of the deck. Release the idler pulley to place tension on the belt. No adjustment is necessary because the serpentine idler spring (part number 6065), located on the idler pulley, adjusts the belt to the correct tension.
May 10, 2016 | Garden
Kubota T 1460 Need belt size for deck and belt going to Engine
kUBOTA FOR T1460 SN 40001 AND UP
K5112-71410 DECK BELT
K5112-51310 ENGINE TO DECK
Cross reference shows both to be 5/8 x 69 Kevlar belts
Apr 17, 2015 | Kubota Garden
How to change engine deck belt on a 2006 Dixie chopper mower
there isn't such a thing... it's either a hydro (motion) belt or the deck drive belt. Dixie's also sometimes had 2 belts for the deck... the drive belt and the blade belt. your model number should be under the seat
Sep 13, 2014 | Garden
Sony dual deck, deck B works fine, deck A won' run the tape but just keeps clicking as it auto-reverses.
Hi amitchell47,
The rubber belts that turns the gears is already worn out. Usually, there are two rubber belts in a cassette deck. You have to replace both belts. I hope everything works out. Good luck.
Jul 25, 2011 | Sony CASSETTE DECK Single Dual Cassette...
What lubricant can be used on the Horizon T92 Treadmill
Go to then click on e-store then look for part and accessories the silicon lubricant to purchase. Follow this procedure before applying lubricant.
1. Inspect belt and deck. The deck should be smooth. The belt should have a consistent feel from side to side (a belt can be worn out without any sensory signs of a problem). If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Continued use of your treadmill may damage expensive electrical components.
2. To inspect the belt and deck visually or to clean underneath the belt before applying lubricant, the belt must have the tension reduced. Loosen the tension roller by following the instructions in your owner’s manual. Do not loosen the bolts in the tension roller too far or the bolts will come out of the roller shaft. This step may not be necessary for your treadmill model or belt and deck condition.
3. Contaminants are the worst enemy of your belt and deck. Some treadmills may have an excessive accumulation of dirt and contaminants. If these are trapped during the belt lube process, significant damage will occur. If contaminant removal is necessary, loosen the belt by following step 2, lay the treadmill on its’ side, and use a nylon brush to loosen contaminants that have accumulated on the inside of the belt. Clean the deck with mineral spirits in a well-ventilated area. Allow the deck to dry before lubing or tightening the belt.
Jul 16, 2010 | Horizon T92 - Treadmill
Speed fluctuates up and down on my pro for ekg treadmill. It does not stay at the set speed.
You may have a belt and deck problem. Test by the following procedure: Without the power on stand on the walking belt push the belt in the direction it normally turns, if the belt is very difficult to turn (on most treadmill) this means that you have high belt/deck friction. To inspect the belt and deck visually loosen the tension roller by following the instructions in your owner’s manual Do not loosen the bolts in the tension roller too far or the bolts will come out of the roller shaft. Inspect belt and deck. The deck should be smooth without any grooves, pits. The belt should have a consistent ridged feel from one side of the belt to the other ,a belt can be worn out without any sensory signs of a problem. If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Visually look at the underside of the belt. It should have a consistent look. Black streaks in the belt are a sign of bottom-layer wear through. If your belt and deck is good a simply apply lubricant and this may resolve the problem Most problem are belt and deck issues.
May 15, 2010 | Exercise & Fitness
Belt diagram
The deck drive belt makes an L shape looping to the the outside deck pulley that has 2 pulleys. The deck drive belt rides on the top set. X = pulley engine x
l l
l l
l l -
l l x x = outside deck pulley
back deck pulley =x
motor to idle to outside
motor to tension to outside back side of belt goes around idler
This is the most common belt to replace
idle pulley (x)
lx tension pulley
/ l_______
the deck running belt left deck (X ________________ ____ x)
Apr 29, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
