Question about Universal Televison & Video
I need to change input from av to hdmi without the remote
32inPrive tv, it. S on Av want to switch to hdmi. My universal remote won't do it. How do I do so manually.
    Top Expert:
  • Universal Master
  • 21,538 Answers
You will need a remote controller for this function as it is within the menu system only accessible from the remote control.
Posted on Apr 20, 2017
sandrew
  • 2961 Answers
SOURCE: ps3- hdmi to av
unless there is a switch on the ps3 itself to change to normal tv, you may have to reconnect the ps3 via HDMI and change the screen resolution back to 480p or change the settings in the setup from hdmi to av.
Posted on Aug 24, 2007
  • 22 Answers
SOURCE: Can't access AV Channel on Sony KV-C27TD
If the TV has no RCA inputs, then there is no "AV channel" option for it on any remote, just channel selection.
The purpose of a RCA to SCART converter (aka RF modulator) is to convert one of your channels to an A/V input. They operate (standard) on either channel 3 or 4 as selected by a switch on the converter.
If your converter is unpowered, it's entirely possible that the signal coming out is not good enough to overpower your antenna signal. In this case, you may need a powered unit (such as this one http://www.bestbuy.com/site/olspage.jsp?skuId=5806345&productCategoryId=abcat0107025&type=product&tab=7&id=1067388827858#productdetail) which can actively "shut off" the antenna input when signal is received from the auxiliary device.
Posted on Nov 13, 2007
SOURCE: How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.98fe8a9.jpg
Posted on Jan 19, 2008
SOURCE: changing the channel to av without a remote
I dont know if you tv has this sertting but click menu usally 4 times and it will bring u to a page wich might say channel or something else and u can chane the channel by using the volume buttoms this worked for me and i can put it onto av1 av2 av3 and av4
Posted on Jan 03, 2009
SOURCE: Universal remote works for basics but won't change input
need remote codes to program remote for toshia tv and a philips tv
Posted on Feb 08, 2009
Need to get my tv (model LG) ack on to av mode. no remote control
If you want to select its inputs, you must have its original remote control. No universal remote control will go.
Dec 12, 2013 | LG Televison & Video
How do i change to av on my hitachi c2143s without a remote
As there is no Menu button on its front panel, you must have a remote control to select inputs.
Nov 07, 2012 | Hitachi C29-RF80 29" TV
I have a 47" Visio 1080p. Tv is always set at hdmi
AV inputs are for standard analog video which is 480i. HDMI and Component inputs are the high definition inputs that run at either 1080i or 1080p You won't ever get 1080i or p through AV inputs.
Oct 22, 2012 | Televison & Video
I broke my remote and i need to change my tv to av and ther is no botton on my tv that says av is it posiable to change it to av?
Hello
Without remote control you can't change its mode to AV. Buy one "Atlas OCAP 5-device remote control; by Universal Electronics. Emerson is listed to very short numbers of universal remotes, and this is one amoung them. The codes will be with the attached manual, and you can choose if from it. OK.
Jun 10, 2011 | Emerson EWF2703 27" TV
INPUT MODE WITHOUT REMOTE
Hi
If you cannot reach the AV input mode by scrolling through the channel up down, nor is there is a source or TV/AV button on the set it self, then the news is bad I am sorry. You will need the remote to get AV inputs on this set.
You can get a new remote for the set from here for $1995. Plus postage. Note that it has the TV/AV button.
Happy to answer any questions you may have.
regards robotek
Apr 13, 2010 | Orion STV2763 27" TV
you might try going to channel 00
If you cannot just dial the number 00, go to channel 2 and then channel down.
Does not always work, but without the model number of the TV it is hard to advise further
Mar 12, 2009 | Televison & Video
Rich,
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
cheers,
mark
Jan 31, 2009 | Toshiba 32A33 32" TV
I can't get the channel select to go to av input or video input
A universal remote in most cases can not switch this TV into the AV mode...you can but a orignal replacment remote for your TV At www.remotes.com and then you can use all the functions again!
That will fix ya!
Please rate my response!
Thank You!
Jan 17, 2009 | RCA 32V430T 32" TV
How do i switch to my av mode without a remote
try going to channel 00, or look for the "aux" or "input" button on the tv. if anything you can get a universal remote control.
Sep 15, 2008 | Sanyo DS13204 TV
Feb 18, 2007 | Samsung CXJ1964 19 in. TV/VCR Combo
Televison & Video Logo
24 people viewed this question
Top Universal Televison & Video Experts
JOHN TOPLISS
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
