I need a 12v power cord for my tv. it works through the stero sys. s/n uj300gd010469. how do I get it
SOURCE: DC 12v Power cord
pass by at the nearest electronic shop and they will provide it for you
Posted on May 17, 2008
  • 11 Answers
SOURCE: missing power cord 12v
go to radio shack get a 12 volt 1500ma power supply with I belive it is a N% plug end but any how 800 ma to 1500 ma should run this and the plug end is standard plug with plus 12 volts on the inner side and negitive on the outer case side look at the back of the TV or the old power supply it sould have info on voltags and amprage, and the plug as to inner voltage and outer voltage on the plug any old time radio shack or electronics shop should be able to help you bring in the flat screen if need be as if you know its 12 volts then It wont mater weather you use a 1000ma 1500ma 12 volt ubnaversale power pack as the tv will only use the current needed so more MA is good the only concrn you have is the right mini barrle plug and the right side of +/- voltage on that mini plug being most use + voltage in the inner most circle and - 12 volts on thje outer
Posted on Jul 03, 2009
micromatikal
  • 2777 Answers
SOURCE: i need the power cord for my tv and it says power
I would start by calling Sanyo and have them confirm what type of power cord you need. Most likely they will give you a free replacement or sell you one at minimal cost.
Give them a call at 619-661-1134
Posted on Sep 10, 2010
caroldon
  • 17130 Answers
SOURCE: I NEED A POWER SUPPLY AND CORD FOR A MAGNAVOX 15'
Either you can get this universal type available inthe market in any electronic spares store or it is easy too make one by yourself if you are familiar with electroncis.
All you need is a mains transformer with secondary voltage at 12 volt and 4 amps capacity, use a bridge rectifier , good storage capacitor of about 4700mfd/25 volts and if possible use a 12 V regulator so that the power is smooth, regulated and protected..
Posted on Sep 24, 2010
I need a power cord for my tv
ANY 3 prong cord will work. These include computer power cords, 12v inverter power cords (brick type), etc.
Thank you!
May 02, 2011 | Protron PLTV-32 Television
My Poloroid LCD TV wont turn on power supply brick light doesnt
The TV needs a fairly stable and well filtered 12V power supply. A jumpstart box is 12V, but is I seriously doubt that it is anywhere near filtered and stable, so most likely you would smoke the TV.
Hooking the TV directly to a 12V battery is just fine, as long as the battery has enough current to run the TV.
Oct 20, 2009 | Polaroid LCD-2000 20 in. Television
I need a 12v cable for Sharp Aquos (car to tv)
click at www.shopjimmy.com they have the power cord for your tv.or go to google and type
power cord .
Aug 18, 2009 | Sharp Aquos LC-19D45U 19 in. LCD TV
Need a replacement power cord for harmon kardon sound sticks II
its not that expensive for a power cord. they are running on 12v so you go and buy a 12v power supply with a jack that fits the speakers or you can just find a power supply at home if you have one that is 12v
Jan 05, 2009 | Audio Players & Recorders
Bmw e30 325i convertiable d reg 1987
If you can not find the problem is, maybe you can wire directly from your fuse box 12v to your radio hot wire, and use your radio switch turn on and off, omit the ignation switch.
May 26, 2008 | 2001 BMW 325
New Power Cord Stopped Working
DO NOT use the HP power adapter that is 19V / 3.95A. That is too much power for the Scanjet, which is expecting 12V DC (and a much lower amperage). It's possible that hooking up this power adapter may further damage the electronics inside the scanner. If the second adapter has stopped working then it is possible that the internal circuit board has damage already and another adapter may not work. If you have access to a multimeter / voltmeter you could check for the 12V coming from the adapter. If you're getting the 12V, then the internal circuit board to the Scanjet is probably defective.
Nov 17, 2007 | HP Scanjet 4470c Flatbed Scanner
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
