Question about Tower Dryers
My tower fan doesn't blow air Everything else works so its not the motor Why is this?
  • 923 Answers
Does the fan motor run? You did not say! Did you know that fans don't blow air, even if running, if the fan unit is in a vacuum? There is no air to blow in that situation. So, is any air available to the fan? Is there any air intake location that is clogged or blocked?
Posted on Apr 20, 2017
Lasko fan wont blow air
Sounds like the fan motor is the problem
Aug 31, 2016 | Lasko 48" Xtra Air Tower Fan with Air...
Tower fan stf-31s not blowing
The blades are probably covered in dust. Mine does this when it needs cleaning
Aug 06, 2016 | Tower Dryers
How do I clean a Bonaire oscillating tower fan btf4002
The easiest way to to use pressurized air. Buy a can or use compressed air.
May 23, 2014 | Bionaire Slopeflow 40" Tower Fan with...
Fan comes on but will not blow cold air
This fan has a blower motor which will eventually fail.
The fan will still oscillate , but the blower motor will burn out. The motor thermal fuse will fail , lower bearing failure and armature burn out. No replacement motor less than fan price so, when it goes buy a better longer lasting fan.
Sep 30, 2010 | Lasko 2515 Tower Fan
It turn on , revolve but no air comes out
I am having the same problem. Did you ever fix your fan?
Aug 29, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
How to dissamble to clean aloha breeze tower fan model 87001
I just used an air air compressor with a soft rubber tip and went at my two tower fans outside. It took maybe 10 minutes shooting air in from many different points but both fans now work as good as new. If it's been a couple of seasons like mine you'll be amazed at how much blows out.
May 14, 2010 | Tower Aloha Breeze Fan
Lasko ionizer tower fan works but does not blow air
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} I had a similar fan which quit. I could sometimes get it to start spinning by banging on it. Finally took it apart. Lots of small screws, all small phillips. As I suspected, the "thrust bearing," which supports the rotating components, had become "stiff." I thought that it would be a non-friction (ball bearing), but it is only a bushing, with washers supporting the shaft. With the motor opened up, I greased the bearing with petroleum jelly, and reassembled everything. It is spinning very quietly now. Final comment - this is probably more work than the average fix-it person would want to take on, but it is doable. It took about two hours, start to finish. I could do it in less than one hour now that I know how to do it.
Aug 01, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
My lasko tower fan gets power n wont blow air
The bearings on the motor are dry and need oil. It's really not made to be oiled, but you may be able to take it apart and get some oil to the bearings if you want to mess with it.
Jul 22, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
Blows only cold air
No, sorry there is no simple solution to this. At this point the only thing you can do is send it in for a replacement. Just call 1-800-295-4448
Dec 03, 2007 | Tower Aloha Breeze Fan
Dryers Logo
42 people viewed this question
Top Tower Dryers Experts
Jay Finke
Jay Finke
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Tower Dryer Expert? Answer questions, earn points and help others
