Question about GE Audio Players & Recorders
Ccscamp4 audio, One of the zones, one of the pair of speakers has very low volume
One of the speakers has normal sound, other is very low volume. It's like using balance on a tuner and putting 90% of sound to one speaker. Part of GE smart hue audio system, Other 3 zones are working correctly.
Open SKy
  • 620 Answers
SOURCE: Polk Audio Speakers
hi Hubbell2008
And Happy Holidays
well, as you can see depending on your audio card, and output power, and sound settings on control panel, if is all up, or down.
you can try that first. But if not work is and Audio Card, type of power output, ....in that case you can change your audio card, if an onboard audio, place a PCI and will be ok, Creative labs models makes diff.
Posted on Dec 04, 2007
SOURCE: speakers playing low
open the disc tray and press setup and the speaker volume option will activate and also turn off the night mode for louder sound
Posted on Apr 22, 2008
SOURCE: Logitech x530 hissing noise
I had the same problem for the longest time with my set of Logitech 540 5.1 speakers. Turns out the solution was pretty simple. All I did was open the Master Volume controller and mute the Microphone. Hissing went to zero. Sound is great now.
Posted on Nov 23, 2008
SOURCE: Denon AVR-2105
If the Cd is wired digitally, it will only play through the main zone, because the Denon cannot convert down to RCA to cater for the zone 2. If you plug RCAs from Cd to Denon, Main zone will STILL play from digital, and RCA connection will allow zone 2 to play Cd from RCA input....same with dvd, Satellite Blah blah... no stress, any nasty RCA will do if you want to try before you splash out on really costly cables...perhaps you can help me...want to run AVR 2105 with 2 speakers in zone 2, manual says cant do it - only ably to surround back or biamp...dont want either, dont have stereo yet to try it out...did you have any trouble with that?
Posted on Dec 03, 2008
  • 119 Answers
SOURCE: I just got a pair of Logitech LS21 2.1 speakers
Depending on the software that runs the sound card (you can find it in the control panel), the ports may be configured differently than they used to be. Check in the control panel and see if there is way to adjust the "plugs" and what they mean. Some of the sound cards allow you to change your mic to a sub and your input to an output!
Posted on Jul 07, 2009
I have a magnavox astro-sonic console the right speakers work at full strength but the left is muffled and when the volume is turned all the wat up it produces low sound.
Check the balance or fader control and turn it to the left channel and if that doesn't provide quality volume from the left try swapping the speakers.
If there is no improvement there is an amplifier fault...
Dec 11, 2017 | Magnavox Audio Players & Recorders
Left front main speaker level drops after being on for a few hours
Volume Potensiometer may need dismantle and clean with special solvent
Jul 05, 2008 | Yamaha RX-V2700 Receiver
Recommendations for replacement 6 inch speakers with the Jensen AWM 968? They are for my rv, and are the only speakers in it. Thanks in advance for any help!
In-car entertainment systems, especially the types chosen for camper vans, etc., are often capable of quite high power outputs and usually need speakers capable of being driven at those high power outputs without damage.
The trouble is, such speakers usually don't sound so good at the very low volume settings needed for evening and late night use in a campsite environment to avoid annoyance to neighbours.
It is a big problem choosing speakers that sound good at low volume and yet can withstand the higher volume needed to overcome the wind and road noise of driving. There have been many technological advances in speaker design and a hi-fi specialist will undoubtedly be able to make suitable recommendations that are resistant to damp conditions, long-lasting and with cones free enough for good reproduction at ultra low volumes but robust enough to withstand high power outputs and such drive units are likely to be fairly expensive.
For myself I would choose to use a dual speaker system with a multi-speaker system comprising several low-powered speakers strategically placed for low volume use and a fairly standard high-powered system for normal use and a selector switch.
Aug 01, 2016 | Jensen Car Audio & Video
Receiver channel volume not identical
Remote controls normally do not adjust stereo volume levels independently, and I will assume that the problem is present on ALL input settings (tuner, CD, etc.). Check "balance" control settings, speakers and speaker wires for possible problems. Balance control at 12:00? Inspecting speaker wires and speakers do not reveal problems? Have you swapped speakers to see if problem reverses? Try this "process of elimination" and hopefully you'll ID the problem.
Mar 23, 2015 | Yamaha Remote Control RXV496RDS...
Kenwood A722L no sound and volume led blinking
This could be due to a faulty speaker relay (if your unit uses one). Normally, the unit will "wait" a couple of seconds after you turn the unit on. Then you will hear a "click" and the sound will begin coming through the speakers. If the relay is faulty, it would cause the problem you describe.
Aug 01, 2014 | Kenwood Audio Players & Recorders
Audiosource amp 100 on lower volumes right speaker louder than left speaker 2.1 setup
The problem is not due to how the circuitry is configured; the problem is due to failure of some element in the right channel amplification circuit. This will require detailed troubleshooting to correct.
Dec 07, 2013 | Audio Players & Recorders
Hey yesterday brought Samsung HT-550 home theater . my rear speaker voice is too low . i do settings & high the volume to +6 Db, but still same problem volume is too low . what is best EQ ? any...
The front speakers are the base against which you adjust everything else.
Adjust the front rear balance for 0dB.
Readjust the rest of the speakers using the test tones. Normal audio may not have a lot going on back there.
Mar 31, 2011 | Samsung HTC550 Theater System
I've plugged in my speakers and the woofer but only the left speaker will play sound and its almost a whisper
Try to check for sound manager to check balance is on for both sides (left right) and wave balance is normal value. To call master volume just duble click system tray volume icon (next to clock) and check it.
Aug 03, 2009 | Logitech Z-340 Computer Speakers
No Sound
go to standby hold m-log button tell menu comes on display press up on volume control tell amplifier comes on display pess left on volume control tell display says amp on. the built in amp on the stereo turns of and on to provide better sound quality to the pre-amp out puts
Oct 03, 2008 | Kenwood KDC-X590 CD Player
Fluctuation in sound output on Cambridge Soundworks 5.1 speakers
Hi Paulus
A lot brand of speakers, like Sound Blasters, Logitech, Cambridge, has this (strange) kind of volume problem, sometimes, is the resistor, in the volume control, sometimes in the modulator for the board on the sound speakers, Subwofer.
I use a general tip is let the volume in one setting and don't move in the intermediate low volume say....9 .
from other thing, be change the speakers.
Nov 25, 2007 | Cambridge Soundworks Movie Works 108...
24 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
