Question about Mitsubishi Televison & Video
Mitsubishi Model WD-73833 lamp shatters
I replaced the lamp on my Mitsubishi Model WD-73833. Ran for about 3 hours. Within a couple minutes maximum after turning off the TV, there was a noticeable popping sound. The lamp shattered. Replaced it again and got exact same scenario. Ran for about 3 hours, turned it off, popping sound, and the 2nd new lamp also shattered at least this time only the inside, not the lens face itself. I do get sound when the TV is turned on until it turns itself off again.
milmar
  • 50 Answers
SOURCE: Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Posted on Aug 11, 2008
rob52078
  • 40 Answers
SOURCE: When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Posted on Mar 13, 2009
  • 4 Answers
SOURCE: TV turns off by itself
Check the interlock switch on the rear lamp cover. Sounds like the cover might not be seating completely, allowing this safety switch to shut the TV off. When you remove the cover, it's just to the left of the big black plastic ventilation guide for the lamp, and it's a little tiny blue lever that moves up and down. Make sure the wires going to this switch are OK (not pulled out or 'hanging by a thread').
Posted on Jun 26, 2009
ladywinn
  • 5138 Answers
SOURCE: Replaced lamp Mitsubishi WD-52531 worked for one day
Ballast Board may be Bad it is what turn Lamp on Call Encompass for parts 1-800-638-3328 or look for one on E-Bay they have good deals on Parts.Also CK Fan to Lamp it maybe defective .Call Mats for Fan 1-800-628-1118 they have lamps also.
Posted on Sep 27, 2009
SOURCE: WL-82913 Lamp fails and TV turns off every hour or so
We have the same problem. A 14,000 dollar TV that you cant even get a lamp for. I 'm thinking of a class action lawsuit. This is ********!!!!!!!!!!!!!!!!!!!! Please respond if your interested
Posted on Jul 29, 2010
I turn on my Mitsubishi WD-73833 TV and it turns itself off
Lessing of brightness on a DLP set is a sign of imminent bulb failure.
A new bulb is in order.
Nov 23, 2013 | Mitsubishi WD-73833 73" HDTV
TV is warming up slowly
Based on model number indicated and fact it is not shutting down it most likely is the lamp reaching the end of its 2000 hour life.
Original lamps from Mitsubishi last longer than "generic" ones that often have half the life and are not as bright.
Jun 11, 2012 | Mitsubishi WD-60735 Projection Television
I have a wd-73833 when i turn on the tv the front blue lights come on after a minute the tv turns itself off, there is no picture
I would check your lamp 1st. Do you have a lamp light flashing on the front of your set after TV shuts down? That is a message to let you know what might be wrong.
Apr 05, 2011 | Mitsubishi WD-73833 73" HDTV
Bright white spots on mitsubishi wd-73833 I just replaced the lamp and now these bright white spots have started to appear!
This unit uses a DLP (digital light processor) chip and if this starts to fail then you will get spots appearing on the screen. The DLP chip will need to be replaced.
Mar 24, 2011 | Mitsubishi WD-73833 73" HDTV
My TV picture is starting to have a noticable flicker. Could be the lamps going out? If so how are they changed? Is this something I can do?
Take the TV apart. Have the lamps ready and use gloves to put the lamps in place. Never touch the lamps with bare hands because sodium will degrade the quartz lamps.
Aug 26, 2010 | Mitsubishi WD-73833 73" HDTV
My mitsubishi wd-62526 red light is on for lamp and there is no picture
this indicates a bad lamp. your owners manual has instructions for replacing. there will be a lamp door on the back or behind the speaker grille. if the lamp is shattered or bulged/white it is bad. if the lamp looks good, you may have bad capacitors on your power supply.
May 26, 2010 | Mitsubishi WD-62526 Projection TV
It turns on and it has sound but no picture and then after 5 minute it shut off
Lamp or Lamp Fan is defective call Encompass Parts 1-800-638-3328 For Lamp Call Fox1-800-227-5369
Keep in mind If Lamp is ok and the Lamp Fan stops running then Lamp will shut off to keep from damaging Lamp
Dec 21, 2009 | Mitsubishi WD-73833 73" HDTV
Great sound no picture
lamp needs to be replaced.
Apr 16, 2009 | Mitsubishi WD-73833 73" HDTV
Sound But No Picture Shuts it's self Off
Hello... About the only thing that can cause this symptom is a bad lamp. Most of the time, you can look at the lamp and tell if it's bad. If it's not shattered, it might have an odd bulge at the base of the reflector, or a gray circle on the clear tube at the bottom. I hope this helps!
Nov 24, 2017 | Mitsubishi Diamond WD-65831 65" Projection...
Open Questions:
Televison & Video Logo
23 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
