Question about Ryobi Garden
Ryobi 6.5 hp Mower stops running after about 5 minutes. How do I fix?
  • Ryobi Master
  • 11,713 Answers
Replace the gas cap. its vacuum locked and starving for fuel most likely
Posted on Apr 20, 2017
Changed filter, oil, full of gas checked gas flow everything is good , when I start m lawn mower it runs , when I engage my pto and start mowing for about 5 minutes it just quits
if this is got the 27 hp kohler engine, I know exactly whats wrong with it , due to grass and engine oil building up in a short time under cylinder heads , it actually makes a tight ball of grass and stuff there !! this holds the engine heat and ruins the ign module that's just above it there , I put two on in one season ( tractor runs 6-10 hrs day 6 days a week ) I finally gave up I bought a Kawasaki 27 hp twin and installed it , now its run for two seasons and no problems
engaging the pto has nothing to do with it , it would cut off if you just drove it around for 15 minutes
Sep 15, 2015 | Toro 52" 27hp Z Master Zero Turn Lawn...
Works for a while and then stops
To rule out a fuel tank breather issue, just slacken off the filler cap so as air can enter the tank, if it carries on running replace with a new filler cap
May 14, 2012 | Garden
I HAVE A CRAFTMAN LAWN MOWER 6 HP SELF PROP RUN FOR 2 OR 3 MINUTES ONLY I CHANGE THE OIL GASOLINE AND S/PLUG CAN YOU HELP ME TO FIX IT?
It sounds like you have a bad Ignition Coil (Module). This is how they act when they start going bad. When they get warm, they quit. Some will last up to 20 minutes before they shut down. You can sometimes find a used one pretty cheap at a small engine shop.
Jim
Aug 07, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
I just had my mower out and it ran on the first run in 3 weeks
I typically do 6 things in this situation:
1. Verify that the gas tank is full and closed
2. Verify that the oil is filled to the "full line"
3. Remove and inspect air filter clean/replace if necessary
4. Remove and inspect spark plug clean/replace as neccesary
5. Apply warm air to engine block via hair dryer at the spark plug for 5 minutes and attempt to restart
6. If that doesn't work allow the mower to "rest" for 30 minutes and repeat step 5.
Oct 26, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Sep 20, 2009 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Describe your Poulan "" Push
Please change your are filter,or clean it, I hope this helps you and thank you
Sep 10, 2009 | Poulan "" Push Mower
Mower stops running after I've been mowing for about 30 minutes. I changed the spark plug and fuel filter. It seemed to work and I was mowing the lawn then it just started acting like it was running out of...
Mower stops running after mowing about 5 minutes. acting like it was running out of gas unitl eventually stops. I wait 10 minutes and then it restarts, runs good, then erratic...then quits again?
Aug 23, 2009 | Garden
I have a ryobi lawn mower with a 6.5 hp motor. it
I am working on one now. Customer said "it doesn't run". Ok. So, after oil/spark plug/air filter replacement...it didn't have any gas getting to the carb. Took off the bowl, and on this 2005 lawnmower, the inside of ALL of the carb was covered with a white/chalky film. Looked like tiny rust barnacles over ANY metal surface available. Silty white stuff in bowl. Blasted it all w/carb cleaner. Still couldn't get primer to work, but after I sprayed a bit o' starter in the cylinder, it started well & kept running. Until I let the bar down. Needs a new carb. Will see what the customer wants.
Jun 30, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor
This sounds too easy of a solution but I had a like ptroblem with my Craftsman. I loosed the gas cap a bit and the rough running and stalling stopped. he vent on the gas cap that contains a turn over interrupt valve was plugged causing the gas not to flow. I took the cap apart and cleaned out the vent hole though cleaning the holewith a paper clip would have worked as well. Anyway..it fixed my problem. I think my dirty hands of deris deposited the matera in the vent hole when filling with gas.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
42 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
