Question about Exercise & Fitness
I need a new motor because the motor is heating and I much cost
For a Tempo Fitness 632T Motor JOHNSON 2.25HP no: DC90V / 2.25HP SCA 502033JM05-015
captainjeffq
  • 52 Answers
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Posted on Apr 13, 2009
  • 77 Answers
SOURCE: 140hp johnson seahorse tilt will raise the motor
it needs fluid added. had a 70 johnson do the same, I saw no leaks but it was low on fluid, put some in and have had noproblems yet.
Posted on Jun 21, 2009
  • 6 Answers
SOURCE: 1974 johnson outboard motor 25hp stalls when hiting high end
Not familiar with that specific motor but had similar vintage smaller HP Johnsons. From my experience it sounds like it could be that the high speed carb adjustment is too lean. What I would try is running the backing off the high speed screw 1/4 turn to 3/4 turn, then test. If works better, screw back in in 1/8 turn increments until the problem recurs, then back out 1/4 turn and leave it there.
Posted on Jun 30, 2009
SOURCE: Replacement electric motor for Bissell Pro Heat 2x Select carpet
bissell proheat i can spray solution from the handle but it has no suction help
Posted on Jul 12, 2009
SOURCE: Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Posted on Jul 25, 2009
Replaced incline motor on treadmill was stuck on incline 12 put new motor in and it went right back to incline 12 and stayed there what now? I spent 160 on this new motor and getting the same results
Hi There,
This person installed a new lift motor and had the same issue, so another new lift will do the same. What make/model of treadmill?
Lift commands come from the console to the lower board. Precor and some others use a Triac circuit to provide 120vAC for up or down, these parts can fail on the lower and cause this problem. Johnson Brands like Matrix, Vision, Horizon, Merit and others, use a relay set for up and down also commanded by the upper board.
I have seen upper boards cause this very problem. Contact jatinah@rocketmail.com for more help if needed. Good Luck
Apr 16, 2017 | Exercise & Fitness
Error message E1 on tempo 632t treadmill - what is it and how can I fix it ?
Hi There,
Tempo....check this lower control board for a small potentiometer or little square cube with a screwdriver slot in the top. Adjust this pot CW to 3/4 full turn and retry. Check feedback sensor(s). Does the belt move and then error and stop, or never start? These lower boards do fail and you can contact jatinah@rocketmail.com for more help if needed. Good Luck
Apr 11, 2017 | Exercise & Fitness
My treadmill has gotten stuck in the highest incline position??
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 21, 2016 | Tempo Fitness Model No. 632T
I have a johnson fitness that shows Maintenance reminder and after it writes Error 1, what can i do? please help me. thanks alot.
adjust the speed sensor , see the diagram, clean it , and tight the plug or connector very well, and test it and replace if necessary
2) measure the input voltage for motor, if there are the motor need repair, see my personal TIPS
3) test the output voltage board, for input voltage motor, if there are NOT the board is faulty, see the b. diagram attached..
God bless you
Oct 12, 2012 | Life Fitness Exercise & Fitness
Humming sound in dc motor
Test the input voltage motor, if there are voltage, the motor need repair or replace.
2) Test the output voltage board, for input voltage motor, if there are NOT the board, is faulty, see the block diagram. God bless you
May 08, 2012 | Horizon Fitness Tempo Fitness Treadmill...
Need owners manual for a tempo 632T treadmill
Says to lube belt did that but still saying lube belt. Won't run when the safety key is put in
Feb 20, 2012 | Life Fitness Exercise & Fitness
Treadmill owners manual for a tempo 632T treadmill
how do i lube my treadmill. it is now asking me to do this and stops, continually.
Feb 11, 2012 | Exercise & Fitness
Treadmill (Vision Fitness T8500) turns on, motor doesn't run...
open motor shroud and inspect all connection on the motor control board see if all LED 's are lit except that light up when incline motor is moving up or down. then check the two connector coming from the drive motor to the board sometime over time the two connector will have a cold soldier I would move them to see any excessive movements of the pins then hit start and see if there is any belt movement. Last but not least unplug unit and check the motor brushes if they are less than 3/8 in in length replace them. Call them @ 1-800-335-4348 they under their parent corp. Johnson fitness.
Feb 28, 2010 | Exercise & Fitness
Squeals on startup for about 1 minute then goes
Remove motor shroud and inspect the drive belt VF is imfamous for squealing drive belts better to call them and order a new belt here is their # 1-800-335 4348 Vision is now under there parent corp. name Johnson
Feb 01, 2010 | Dmm Vision Fitness T9500 Treadmill
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
