Question about Central Computers & Internet
I have a central machine all purpose machine mod t5980 built in 1998 -I would like to get repair/operators manual for it also switch for lath motor
Can you help me
SOURCE: 1998 Husqvarna 265RX Brushcutter Service/Repair Manual
Fixya does not have the manual I'm looking for.
Posted on Nov 27, 2008
Tnsiouxfalls
  • 617 Answers
SOURCE: 93212 manual needed
http://www.harborfreight.com/manuals/93000-93999/93212.pdf
Here you go!
Posted on Jan 29, 2010
kirkking1107
  • 18 Answers
SOURCE: owners manual for a dashin p-4 bench lath
Come on,
If you need an owners manual for ANY lathe, you have no business operating it in the first place.
Don't hurt yourself or others.
Posted on Dec 27, 2011
SOURCE: operating manual for axminster sieg C2A mini-lathe manual
Hello Tom, I have this manual - quite happy to photocopy it for you if needed? Drop me a line to jimlock1@hotmail.com if you like
Posted on Feb 17, 2012
headstrong56
  • 493 Answers
SOURCE: Assembly instructions for a Hafco AL 336 lathe
Posted on Jul 19, 2012
Can't find the window fuse for 2003 caddy cts
Check inside trunk under carpet on rear seat back support.
Nov 12, 2016 | Cars & Trucks
F25 error whirlpool WFC7500VW washer machine
F25 DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down. If a failure occurs during high-speed spin, the door unlocks after 3 minutes.
Possible Causes/Procedure
Verify the shipping system including shipping bolts, spacers and the power cord are removed.
Unplug washer or disconnect power.
Check drive motor tachometer resistance.
It should be approx. 115 ?.
Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
Plug in washer or reconnect power.
Check the MCU by looking for operations of the drive motor.
Check the drive motor for powered rotations.
attachment.php?attachmentid=24900&d=1445218637&thumb=1 Front load washer drive motor with pulley
Tach/sensor is built into the end of the motor.
Appliance Repair Forums
Mar 24, 2016 | Whirlpool Washing Machines
Protect lathe when reversing.
I don't have much knowledge on lathe. Check this thread I found on google. Hope that helps.
Jun 01, 2013 | Jet JML-1014VSI: 10" x 14" Variable Speed...
Blows breaker and groweling noise
It sounds like the motor is bogging down due to bad bearings or something is making the shaft too hard to spin. Make sure all the spindles are free. If its happening under load, make sure the lathe gets up to speed before trying to make any cuts.
Oct 18, 2012 | Ammco Combination Disc/Drum Brake Lathe
Owners manual for a dashin p-4 bench lath
Come on,
Dec 27, 2011 | Tools & Hardware - Others
What is diffrent between lathe machin & cnc machin
A Lathe machine turns a piece to be worked on usually along its longest axis. An operator or machinist manually moves a cutter or other tool against the rotating piece to remove and/or polish the material to a more refined state. Instead of manually, a Lathe can be controlled by computer with the speed of rotation and positioning of the cutter or other tool being done according to a program or set of numeric data in which case the Lathe would then be a CNC machine. A CNC machine can refer to any computer controlled machine which uses a set of numeric data to determine its operation which can be cutting, drilling, milling, etc.
For a more comprehensive description go to Wekipedia for Lathe at http://en.wikipedia.org/wiki/Lathe
and for CNC at http://en.wikipedia.org/wiki/Numerical_control
Jan 31, 2011 | Computers & Internet
I am having an old HERBERT No4 CAPSTAN LATHE machine.I dont have the manual .pls send me the site address from where i can download it free. Thanx, moncy philip
Hi ,
Following are the machines for which essential spares beingpresently supplied and reconditioned/repair being undertaken.
Email: lakshmi.hrr@gmail.com
I HERBERT LATHES:
II CENTRAL LATHES
III Grinders
Note: Machines of other reputed manufacturesare also being undertaken for reconditioning and repairs.
Aug 05, 2010 | Computers & Internet
F6 codes mod#MFW9700SQ0 jonathan
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after three minutes. Possible Causes / Procedure
1. Verify the shipping system including shipping bolts, spacers and cables are removed. 2. Unplug washer or disconnect power. 3. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU). 4. Plug in washer or reconnect power. 5. Check the MCU by looking for operations of the drive motor. 6. Check the drive motor for powered rotations.
Jun 18, 2009 | Maytag EPIC MFW9700S Front Load Washer
No suction on the EC-T5980
Check the inlet by the brush roll, it may be clogged.
Dec 09, 2007 | Sharp Twin Energy EC-T5980 Bagged Upright...
Computers & Internet Logo
27 people viewed this question
Top Central Computers & Internet Experts
 Mikey
Mikey
ray gallant
Are you a Central Computer and Internet Expert? Answer questions, earn points and help others
