Question about Makita Drills
How do i change the chuck on a hp 1501 - Makita Drills
  • 2,176 Answers
First check to see if there is a chuck retaining screw, if so it is left hand thread, second open the jaws and find a bent handle allen wrench about the capacity of the chuck and insert the smaller portion and tighten. if you have a wrench that will fit the spindle that is great, if not make sure tool is in low position and put chuck on work bench at about a 30 degree angle and you will be hitting the allen wrench counter clockwise to loosen. it might take a couple time but it will come off
Posted on Jul 25, 2009
How do i change the sds chuck to the standard chuck on an kango 220k hammer drill
do not think that is an option . get another drill with standard chuck .
Oct 05, 2015 | Hammer Drills
Need anew chuck for a black & decker BD155RT Quattro 550w drill and advice on how to change it
Remove the left hand screw from inside the chuck and then insert the chuck key onto the chuck, place the machine on a suitable work surface and give it a wack so that the chuck will unscrew off the drill anti clockwise.
Jan 22, 2013 | Drills
How to change the chuck on a ryobi EID1000RE
hello, there is a screw you have to remove inside of the chuck once you have done this you should be able to unscrew the chuck,,
Feb 07, 2012 | Garden
Chuck will not hold bits, How to change chuck
down inside the chuck theres a big flat head screw that should do it.
Nov 17, 2010 | Hitachi DS18DVF3 18 volt Cordless Drill...
EVERY TIME I TURN MY MONITOR ON IT SAYS "GOING TO SLEEP" AND THEN THEN SCREEN GOES BLACK! BUT MY COMPUTER IS STILL RUNING. I THOUGHT IF I COULD GET A MANUAL I COULD TROUBLE SHOOT IT AND FIX IT. BUT WHEN...
its a very very old monitor,so old in fact , you PC then had no sleep modes. so its inside the monitor, this old
so push the menu key on front of monitor and turn off
sleep/powersaver. ,
no the manual is only, you do know fixya is not HP right?
nor are we COMPAQ
did you leave off works in front if the 1501, HP made types with just that 4 digits.
Compaq 1501
https://www.manualslib.com/manual/30085/Compaq-Tft-1501.html
L1501 and TFT-1501
read the service tag on the monitor and see the real full name
then post that for 10x better answers even the book.
Nov 06, 2017 | HP Compaq 1501 15" LCD Monitor
How to change drill chuck for makita hp 2040
if its a reversible drill there will be a screw in the bottom of the chuck, open the jaws as far as they will go and you should see a screw head, it is a left hand thread so put the drill in low speed selector this will stop chuck turning as easily, then turn screw clockwise as your looking at the chuck, when its out put an allen key in and tighten up the chuck hit with hammer now in a anti clockwise direction it should unscrew. repeat in the reverse procedure to fit new chuck....
Jul 31, 2010 | Makita & 1/2 Inch Drill
The chuck need change on drill modle hp 1621
you can either go to the tip section or try going to my profile under my user name and there are detailed instructions on how to remove the chuck.
Jan 17, 2010 | Makita Drills
Remove and replace the chuck
Most drill press chucks are held on with a screw. Open the chuck all the way. Look inside the chuck, there should be a screw in the bottom. Some are left hand threads, some are not. Good Luck
May 28, 2009 | Drills
Printer will default to "save as" screen when que to print
In administrator login the default printer is "Microsoft XPS Document Writer", make sure that the default printer is the HP Printer.
OR
You have to change in the Print dialog box, select the HP Printer instead of "Microsoft XPS Document Writer"
Cheers - Parveen
Feb 08, 2008 | Dell Inspiron 1501 Notebook
Drills Logo
87 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
