How do I make a bootable media for re-installation of Vista?
How to reset windows password
Since you can not get into the computer. insert a Bootable DVD - install DVD or a bootable USB install media. which ever you have.. or used. when you turn the computer on - if you default is either of it will boot to the media... Start to install NEW on the same partition as your current borked OS is.... pay attention at 41% uncompressed - reboot the computer and remove the boot media... what this does on Window 7 is only restore the OS and sets to default....
Jun 19, 2014 | Microsoft Windows 7 Ultimate 32 bit Full...
Gateway zx4951
Try this:
Restore Point:
Try tapping F8 at startup, and from the list of startup selections, select Safe Mode by using UP Arrow Key to go there > then hit Enter.
Try a System Restore once there, to pick a Restore Point before your problem..
Click Start > Programs > Accessories > System Tools > System Restore > pick a different time > Next > etc
If Restore does not work and you do not have a Microsoft Vista DVD, make a Bootable Repair Disk to do a Startup Repair:
Download the ISO file at the supplied link, and make a Bootable Startup Repair Disk from it.
Go into your Bios/Setup, or Boot Menu, at startup, and change the Boot Order to make the DVD/CD drive 1st in the Boot Order, then reboot with the disk in the Drive.
At startup/power on you should see at the bottom of the screen either F2 or DELETE, to go into Bios/Setup, or F12 for the Boot Menu.
When you have changed that, insert that Bootable Disk you have made in the Drive, and reboot.
http://www.bleepingcomputer.com/tutorials/tutorial148.html
Above link shows what the process looks like, and a how-to, as it loads to the Repair Options.
Neosmart contains the contents of the Windows Vista DVD\'s "recovery center," as we\'ve come to refer to it. It cannot be used to install or reinstall Windows Vista, and just serves as a Windows PE interface to recovering your PC. Technically, one could re-create this installation media with freely-downloadable media from Microsoft (namely the Microsoft WAIK kit, a multi-gigabyte download); but it\'s decent of Microsoft to make this available to Windows\' users who might not be capable of creating such a thing on their own.
Read all info at the website about creating and using it:
http://neosmart.net/blog/2008/windows-vista-recovery-disc-download/
ISO Burner: http://www.snapfiles.com/get/active-isoburner.html
It makes a very good Vista Startup Repair Disk.
You can do a Startup Repair, System Restore, etc from it.
Note: It is not a reinstall disc.
Nov 28, 2013 | Computers & Internet
My laptop after a system restore went wrong.. Vista wouldnt boot up and i couldnt get into the recovery partition.. its still there along with my vista program i installed xp... but really wan5t to gegt...
Your laptop normally comes with a 'bootable' recovery media (CD/DVD) for exactly the reason you mentionned of corrupted Operating system.
In addition, original Windows Operating System Installation Disks are also normally bootable and can also be used to recover from corrupted installations.
Please keep in mind that when you switch Operating Systems, you need to have, on hand, the correct O/S Drivers for your specific device.
Hope it helps.
May 15, 2011 | Acer Aspire 7720 Notebook
I bought HP laptop with Windows Vista Home Premuim. After I installed temperary version Windows 7. I do not like Windows 7 and I want to return for Windows Vista ( I have all necessary its numbers)....
Hi Victor, you need a bootable vista disk.
Now insert the disk into your CD Rom and then boot it up and then follow the instructions and install VISTA operating system. If you are not a professional contact me back I will give you instructions step by step.
Regards
Feb 10, 2011 | HP Computers & Internet
I Wanted To Make a BOOT CD For Windows XP But The Problem is That I Have Windows Vista and i Dont Know What To Do So What Can i Do
How to make a bootable Windows Vista ISO DVD media
  1. Put all 3 downloaded files (namely install.wim, boot.wim and an executable X13-49120.exe) in the same folder (for this tutorial, let’s assume the files are put on C:\ else you need to modify the path accordingly).
  2. Run the X13-49120.exe executable. Windows Vista Setup Preparation will create a new folder “Vista” inside the folder and will populate the folder with all necessary Vista setup files which takes up about 2.52 GB disk space.
  3. Exit from the Install Windows screen.
  4. Download CDimage 2.52.
  5. Extract CDimage from CDimage.zip to the C:\ root directory.
  6. Open a command prompt shell, and run the following command: cdimage.exe -lVISTA_EN_DVD -m -u2 -bC:\Vista\boot\etfsboot.com C:\Vista\ C:\Vistax86.iso
    Bootable Windows Vista x86 DVD ISO image in UDF format will be created as vistax86.iso in C:\ or any folder you specified above.
  7. Burn the newly create ISO with a CD/DVD burning software such as Nero or Alcohol 120%. Try to burn at low speed (i.e. 4X) and turn on verification to ensure that the DVD creation is fine.
Visit here for illustrative guide on using CDImage GUI version to make the bootable DVD ISO.
Create a Windows Vista ISO image and DVD with Oscdimg
Another possible way to create a bootable Vista ISO and DVD is by using Oscdimg CD-ROM and DVD-ROM Premastering Utility, available via WinPE (Windows Preinstallation Environment) via Business Desktop Deployment 2007 or Windows Automated Installation Kit (AIK).
  1. Complete step 1 – 3 as above.
  2. In the command prompt window, run the following command: oscdimg -bC:\Vista\boot\etfsboot.com -h -u2 -m -lVISTA_EN_DVD C:\Vista\ C:\VistaDVD.iso
    A VistaDVD.iso UDF DVD image will be created and can be used to boot the computer from DVD to install Vista.
  3. Burn the ISO image file by using last step above.
Visit the guide to create Vista bootable DVD using vLite.
Note: For 64-bit Windows Vista, download etfsboot.com and put it into “\Vista\boot” folder. Or users using WAIK (WinPE), the etfsboot.com can be found at %Programfiles%\Windows AIK\Tools\PETools\amd64\boot\ folder. So simply replace -bC:\Vista\boot\etfsboot.com with -bC:\Program Files\Windows AIK\Tools\PETools\amd64\boot\etfsboot.com when making 64-bit Vista DVD image.
Aug 02, 2009 | Computers & Internet
Acer aspire 3000
The bootable XP cd you have will work - You need to first reinstall the Operating System(XP), then download and install drivers for the devices(Such as touchpad, wireless, etc.)
The device drivers are all available from Acer's support site; If the Network Card driver isn't installed after the windows XP installation, you will need to use a different computer to download the drivers, and transfer them to your laptop using some sort of removable media - USB Flash drive, portable hard drive, memory card, etc.
Feb 13, 2009 | Acer Aspire 3000 Notebook
Unable to boot Vista install DVD on FreeDOS
Your DVD should be bootable -- that is, restart and it should boot off DVD. If in fact you have an installable copy of Vista, and you have a working DVD drive.
If those two answers are correct, restart your computer and immediately figure out how to get into the BIOS -- Normally delete, F1, F2 or F10. Hit 'em all real quick and keep trying, looking also for something like "To enter into system configuration, hit ..."
There should be an entry for boot preference. Just make sure CD/DVD/removable media/ATAPI drives are listed before your hard drive.
Dec 07, 2008 | Microsoft Windows Vista Ultimate Edition
Windows vista
How To Make Vista Bootable DVD with WIM Downloaded Files If you have purchased Windows Vista online and taken the delivery of the latest operating system via web download from Windows Marketplace, you would ends up with a few downloads with .wim and .exe file extensions. Rather than paying additional shipping and handling charges, you can burn or create a bootable ISO DVD image from downloaded Vista files with the following trick, where the .iso image can subsequently write to a DVD. The DVD created will be the typical 32-bit Windows Vista DVD that available in retail channel, and can be used to clean install.
1. Complete step 1 - 3 as above.
Mar 24, 2008 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
