Our Ultima 65 will NOT stop running film thru. Have hit Reset button and unplugged but had to turn machine off
2 Suggested Answers
  • 44 Answers
SOURCE: Camera keeps rewinding film
Check the manual rewind button on the bottom plate of the camera. Make sure the button is not jammed under the edge of the button opening. If it is you might be able to carefully pry it out with a sharp pin or tooth pick (be careful not to pierce the button or you could damage the circuit board underneath) Or you could remove the bottom plate and reseat the button (be careful of a loose spring to the film door latch)
Posted on Dec 12, 2008
On GBC Ultima 65, I am having trouble with new film both top and bottom threading through cold heat rollers
I'd try listing this question under Office equipment, as this category is only for sewing machines.
Oct 27, 2016 | Sewing Machines
Why doesn't our laminator always roll?
It sounds like the control panel switch membrane( under the panel buttons) needs to be replaced. The bad sound may be your heat roller bearings failing. They dry out and start squealing. They also can cause your machine too slow down or stop. There are 2 bearings on either side of the laminator, 4 total.
Sep 08, 2015 | Gbc Heat Seal Ultima 65 Laminator 1710740
How do I unjam it?
first, remove both rollers with the film on them, then I usually cut the film between the red/orange rollers and the rear gray rollers, this allows you to run the laminator in either forward or reverse to unwrap the laminator, there is not exact science here, just use common sense and don't use anything sharp up against the rollers. West Laminating Svcs 405-324-6092
Aug 05, 2015 | Gbc HeatSeal Ultima 65 Laminating System
Does the GBC Ultima 65 have an adjustable pot to increase heat of rollers? If so, where is it located?
Ordinarily, laminators have speed controls to allow the laminated substrate to get hotter.
Feb 12, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
Rollers will not turn
Read page 8 of your manual (http://accoblobstorageus.blob.core.windows.net/literature/5edb3f90-058f-49a6-a41d-ccfd96850992.pdf).
Are C, D and E in place(page 14 of the manual)? Interlocks prevent anything from operating if these parts are not properly in position.
Are you sure the screwed up film is all out and new film installed correctly(page 34 of the manual)? Use a flashlight to peek in the corners!
Are the rollers sticky or sticking to each other? If so, you're done.
Are the supply rolls (page 22) turning freely? If not, replace them.
Do the rollers run in reverse when you hold down that button (page 12)? If not, something is really out of whack.
If still in trouble, call for service.
This is one of the most complicated laminators I've ever seen ... must be a good one ... but personally I wouldn't let any one touch it until they've read the manual cover to cover and promise on pain of separation from service to follow ALL the rules in regard to setup, operation and maintenance. ^_^
Mar 28, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Film is wrapping around bottom roller instead of going out. how do I get it unwrapped?
Get a scotch brite general purpose pad, be sure to let machine cool down before you start to cleaned roller. And you can thread your laminate film.
Sep 03, 2013 | Gbc HeatSeal Ultima 65 Laminating System
Gbc heatseal ultima 65 won't turn on. It shut off while laminating a poster. It was getting close to the end of the rolls, but it just shut off and wouldn't turn back on at all. 4 Days later it...
GBC appear to just be a crappy company. I have a Heatseal H212, same problem. Worked fine then one day when I turned it on it never became "ready". I waited a while longer then turned it off.. except it wouldn't let me turn it off. I had to unplug it from the mains to get it off. After that, it would never turn on. Checked the fuse, it was fine.
Sep 26, 2011 | Gbc HeatSeal Ultima 65 Laminating System
22 people viewed this question
jasbo
jasbo
