Question about Aiwa Televison & Video
Aiwa v59 led tv software update - Aiwa Televison & Video
2 Suggested Answers
shemeer_moha
SOURCE: how can i update the software of videocon led tv 32 inch
where i download the files?
Posted on Jul 01, 2015
COBY LED TV Model 3960
https://www.solvusoft.com/en/update/drivers
Try this website it has all of the coby updated drivers and software downloads and it’s all free!! Your welcome
Jan 04, 2018 | Coby Televison & Video
Tip
Hitachi 22HXJ06U stanby LED flashing red and blue.
Recently first thing in the morning I've found my tv power on / standby LED is flashing red and blue. The tv does not seem to respond to the remote...but after pressing remote on key the tv will eventually come on about 3 to 5 minutes afterwards. It would seem that the tv does an auto update during the early hours and then on next switch on it completes the update...during which time it seems that it has not turned on. To prevent this annoying behaviour you can disable the automatic software updates in the settings menu... see pdf user manual at https//estadoc.hitachi.eu/servlet/FileViewer?DocumentName=22%20IB.pdf see page 23 about software upgrade. In the settings options you can disable the auto upgrade. Occasoinally I expect it would be advisable to either enable the auto update for a day or two or do manual update.
on May 02, 2015 | Televison & Video
My Sony Bravia TV will not turn on. the power light flashes red 7 times then stops for 4 seconds then repeats
System Error:
  • If a Red LED is blinking and the TV is not working properly it means that the TV has detected an issue or problem. Most Red LED blink conditions require service. The meaning of the blink codes differs between TV models, but the following steps may resolve user serviceable errors related to heat, temporary conditions, or software updates:
    NOTE: 8 Times Blink - For certain models, a special reset procedure is needed if the Red LED on the front of the TV is blinking 8 times and then repeats. This is a model-specific issue that may be resolved by following these steps (please check the answer to be sure your model is included).
    For other TV models or other Red LED blink codes:
    1. Turn the TV off and back on. If the TV will not respond to the remote or the power button, or if that does not fix the issue, unplug the TV. For a Projection TV or Projector , leave it off for 3 minutes. For other TVs leave it off for 1 minute. Plug the TV it back in and turn it on.
      NOTES:
        • If the TV is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
        • Projection TVs and projectors need to cool down before they will turn on again. You may need to wait several minutes before these will turn back on.
    2. Clean any vents/slots in the TV cabinet and make sure there is room for air to circulate around the cabinet of the TV.
    3. Some Sony TVs have a media box (tuner) and separate display. If you have one of these TVs, check to make sure the cable between the media box and the display is securely connected.
    4. For Projection TVs and Projectors, make sure that the cover/door for the lamp is closed and secure.
    5. If the TV can be operated at all, check to see if a software update is available.
      • If your TV is connected to the Internet, press the Home or Menu button on the remote to get into the setting menus. The Software Update option is usually found under theProduct Support or Contact Sony menu.
      • NOTE: For a limited number of Internet-capable models, the only option is to turn onAutomatic Software Updates and allow the TV to update on its own. If you only have this option, make sure it is set to On. Automatic updates are only downloaded when the TV is in standby mode (turned off with the remote but not unplugged). Normally this download will happen overnight but may take up to 24 hours.
      • Software and driver updates for your Sony product are available online. You can check to see if a software (firmware) update is available for your television. Steps to install will be included if an update is available.
      • Older CRT TV's and TV's that cannot be connected to the Internet do not have an option to check for a software update or may not capable of being updated.
  • If these options do not resolve the issue, the problem is most likely related to an internal component that must be replaced and service will be required.RF
Mar 04, 2015 | Sony BRAVIA Televison & Video
How to update (firmware) software in Videocon LED 32" DDB tv
how can i update the software of videocon led tv 32''
Sep 05, 2013 | Televison & Video
I cant control my AIWA TV WITH A jumbo universal control.THE CONTROL NUMBER DOES NOT WORK that is given with the instructions
Have you tried the auto-code search?
Unfortunately, you can't teach this remote new codes, so if none of the AIWA codes from the manual work, and you run through this auto-program sequence and it doesn't work, there is no other solution for your TV.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Nov 19, 2009 | Innovage Jumbo Remote Control
Hooking Components
You can download the manual from the link below: http://www.us.aiwa.com/default.asp?page=ownerManual&action=browse&model=244 There are good diagrams to help you. When you have followed this guide then come back with any items you can get working. Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 02, 2007 | Aiwa AV-D58 Receiver
Televison & Video Logo
Top Aiwa Televison & Video Experts
romy sibug
romy sibug
 Grubhead
Grubhead
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
