Question about Refrigerators
Refrigerator model #PFSS5RKZASS water line frozen and wont dispence water
kweaver1
  • 3 Answers
SOURCE: water line to ice maker frozen
Check to make sure that the damper between the freezer and fridge is not broken or frozen open. Make sure that you shut off the water supply to the fridge until you get this fixed because the line could crack and then you could flood the house.
Posted on Jan 20, 2008
gtaplytmpt
  • 90 Answers
SOURCE: icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Posted on Jan 02, 2009
MNTECH
  • 1543 Answers
SOURCE: GE GSS25LGMF Water dispenser-no water
Order and install a WR49X10173 water tube heater. It may take 24 hours to then thaw, but it has worked for me on numerous refrigerators. Cost for the part will run about $50.
Posted on Feb 08, 2009
aasc
  • 1606 Answers
SOURCE: Side by Side GE Refrigerator wont cool and freezer side frozen
Bad defrost heater in the freezer section .
Posted on Jul 21, 2009
  • 257 Answers
SOURCE: water dispencer from inside fridge
It is very common for the water dispensing tube to become frozen if there is a slow drip coming from the water fill solenoid in the back of the refrigerator.
Posted on May 29, 2011
Testimonial: "figured it out by tearing it apart myself. but thanks "
Water will not dispence in ge refrigerator model number gsl25jfpa bs
Your line is frozen. Frozen water dispenser line is a problem with this model. There are number of solutions.
1. Contact GE 800 386-1215, option 5 and ask for WR49X10173 heater kit. There is a video http://www.youtube.com/watch?v=BdNX3LteJTw to help you install it. Try to get GE to send you the fix free.
2. Get a hair dryer and heat the dispensing box until the water dispenser works. This is not a permanent solution, though, and it takes 15 to 30 minutes. Hang a long beach towel or blanket over the open freezer to save the cold air.
3. Place a long, clean fishing line or weed wacker line up the water dispenser line. When it freezes, pull carefully to dislodge the frozen water.
4. Buy another brand of refrigerator and let GE know they make inferior products.
Jan 10, 2013 | GE GSL25JFPBS Side by Side Refrigerator
Will not dispence water
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Water dispencer from inside fridge isnt dispencing water. makes noise like it wants to but wont. can my water line be frozen? my fridge is usualy pretty bare and the temp is on 6.
May 29, 2011 | Refrigerators
Water has stoped coming out of drinks dispencer
Not an expert, but it could be that your water dispenser line is frozen. Check the temp of your refrigerator. It may be close to freezing. This happened to me on another model of fridge.
Mar 02, 2011 | Samsung RS2630SH Side by Side Refrigerator
I have a whirlpool refrigerator model et1fttxcq08 and the ice maker works fine but the water dispenser will not. You hear the motor when you press on the dispense button but no water comes out.
you will need to check the water line inside the door and make sure there is no frozen water in the line.
To check and make sure the water valve is working you can disconnect the water hose on the bottom of the door make sure to have a glas or small pot handy, when the water line is disconnected you can try and dispence water and if water comes out then you have frozen water in the line in the door.
You can also use a long piece of weed eater line and sticke it through the water line in the door and it should go all the way through.
If no water comes out when you have it disconnected then the water may be frozen in the lines on the inside of the fridge.
If the water line in the door is frozen you can use a blow dryer and blow hot air in the tub alternating between the top and the bottom of the line this can take awhile to do but will clear it up.
Dec 24, 2010 | Whirlpool Refrigerators
It appears that no water is getting to the ice maker in my kitchen aid superba side by side refrigerator. I know it is not a frozen water line because I still get filtered water through the door. Any...
selenoid valve to the icemaker can be malfunctioned.they can be found at the back side.
Generally icemaker water line is seperate then the water dispencer so it is possible that it is frozen.
Jun 30, 2009 | Refrigerators
Water dispencer want work
yes the filter will keep water from dispensing but the best way to see if it is it is take your kickplate off under your doors and you will see a water line coupling unhook it there by putting your fingers on each side the line and pulling back on the coupler then put the line in a glass or bowl and push in on your dispensor paddle if you have water there then call a authorized technician cause it is frozen inside the door
Dec 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Kenmore model 106 9555710 SxS - no wate through door
check inside the bottom of the refrigerator for water, the water line goes thru the back of the refrigerator and it may have cracked and leaking inside instead of going to the dispenser.
if not then water is most likely frozen in the line going thru the back of the refrigerator. look behind the pans in the refrigerator and there should be a coil of clear plastic water line, this is the reservoir that chills the water for the dispenser. sometimes it will freeze up if the refrigerator is very cold.
Jun 28, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water dispencer not working
May 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
