Question about Brady ID PAL Thermal Label Printer
Printer labels do not advance when print is hit
When print is press makes a sound as if advancing tape but nothing comes out
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
I have the same problem too. I opened up the printer to see that the small drive gear was broken. I had to send the printer out for repair
Posted on Nov 20, 2010
  • 3 Answers
I had the same problem. I opened up the unit and found that the small drive gear had lifted up on the shaft and was no longer engaging the other gear. I could have probably noticed this from the battery compartment. I pushed it back down and now the unit works.
Posted on May 26, 2010
    Problem Solver:
  • 10 Answers
CAUSE: my guess would be a stripped gear or a lack of prssure on the "pinch wheel" which would cause a loss of traction on the paper feeder.
SOLUTION: 1- change the stripped gear (if it's stripped)
2- add a layer of adhesive tape on the loose pinch wheel (if it's loose)
both solutions require to open case (to access loose wheel or stripped gear). To determin what the probleme is, try to run a print and try to move or pull gently on the lable ribon while in function. Two possible outcomes are that the gear will only "hook" in some areas if it's stripped. If it's loose the paper will only move while pulling on it.
Posted on Jul 24, 2009
IT WONT PRINT ANYTHING ALL OF A SUDDEN?
Your manual for the label printer should show you how to print a test label using controls on the front panel. Will it print such a label for you? If so, you more likely have a communication problem between your label printer and your computer(s). You should also be able to push a button to get a blank label to advance and come out of the machine. If you can't get a test label or get it to advance a label the problem is more likely with the printer itself. Make sure your paper sensor inside the machine is not clogged with paper fuzz, etc. Beyond checking your paper and ribbon paths, if you find nothing, you may need to call for a tech to see what is broken. Turning the printer off and back on again sometimes helps.
Jul 02, 2015 | SATO GL408e Label Printer
What in the world!! I have the Smart Label Printer 450, it is not advancing the label, and the power button is flashing. It will not print a label at all at this point, and when it will end up printing a...
Unfortunately, this is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. This means your Smart Label doesn't think its wasting labels, it's just trying to run through what it considers to be unsuitable labels as fast as it can. If you're only printing one label at a time you can recover some labels by correctly the label's line up after each label you print but there's nothing you can do so that your printer will properly advance its current labels.
Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
May 08, 2014 | Seiko Smart Label 240 Thermal Printer
Issue with my TLP 2844
Check that your ribbon core is installed tightly onto sprocket guides. Push on firmly.
Jul 09, 2009 | Zebra TLP 2844-Z Thermal Label Printer
I get 2 labels(1 with data and 1 blank)for every label printed
THE LABEL SENSOR IS NOT SENSING THE BEGINNING OF THE NEXT LABEL
Clean the photo eye that senses the label gap with a q tip and alchol
Open side door release print head and remove label stock you will see small photo eye clean
put printer in manual mode( switch 1 on to and 1 on botom on
turn printer on it should advance one label and hit skip it should advance another
put back in computer mode
should work now if it still skips check yur label desigh=n software and label mode (continuous or sense label)
Best of luck to you
Dec 29, 2008 | Intermec EasyCoder 3400 Thermal Label...
TLP2848Z blinking red, will not print
1: Is it a TLP2844 or a TLP2844Z.
Operationally they are completely different printers. TLP2844 uses ELP (Eltron Programming Language. but TLP2844Z uses ZPL (Zebra Programming Language). You need to calibrate the printer to the labels.
Calibration:
If its a TLP2844. Load media. Connect power.
Hold down feed key, power on, count one, two, release feed key. The printer will go through a calibtation routine and print config label. IMPORTANT - When it prints this label you must press the feed key and see the message OUT OF DUMP. Your printer will now be calibrated. Check this by hitting the feed key a few times and printer will feed one label each time feed is hit.
Calibration:
If its a TLP2844z.
Load media. Turn printer on and wait for green light (Approx 1 minute)
Press feed key and keep it pressed until green light blinks once, then twice, now release feed key.
Dec 22, 2008 | Zebra TLP 2844-Z Thermal Label Printer
How can I print the label from tray 2?
Go to the control panel.  Select printers.  Move the mouse to your printer.  Press the right mouse button and select properties.  press the advance properties button.  Select the tray you wish to print from.  press when finished.
Sep 11, 2008 | HP Color LaserJet 3500 Printer
Label not advancing to tear-off perforation
Try this to have the printer auto-sense the size of the labels:
1. Make sure that printer power is off.
2. Press and hold the feed button.
3. Turn printer power on.
4. When the status light blinks, release
the feed button.
5. The printer advances the media to
measure and verify the length of
individual labels or tags. The printer
then prints a status summary and
remains in diagnostic dump mode.
6. To begin normal operation, tap the
feed button. The printer prints "out of
DUMP" and advances a label.
May 14, 2008 | Zebra LP 2844 Thermal Printer
Zebra lp 2844 thermal printer
It sounds like it needs to be re gapped. Try this:
the feed button.
Nov 30, 2007 | Zebra LP 2844 Thermal Printer
Advances ticket too far after printing.
your label length is set incorrectly, there are 2 things it could be
1) your software is telling the printer the label length is longer then the current labels, even if the label size is out my a single millimeter the printer will give you this issue of feed an extra label. you need to change this in your software. you can set a label size smaller then the current label size and it will work correctly
2) you software is not setting a label length and so the printer is going off its internal setting, to recalibrate hold feed and power up the printer letting go after the light starts flashing
it is important to note that label roll will change slightly over time so even though you are ordering the same labels as a year ago the manufacturer will have slight changes from batch to batch
Nov 05, 2007 | Zebra Eltron TLP 2742 Thermal Label...
Brady ID PAL Thermal Label Printer Logo
485 people viewed this question
Top Brady Office Equipment & Supplies Experts
pkwc
Bob Rambo
Level 1 Expert
The Vanguardian
The Vanguardian
Are you a Brady Office Equipment and Supply Expert? Answer questions, earn points and help others
