Question about The Audio Players & Recorders
How do you get to the equalizer on the jp5 mini .are do any body got a manual for this jp5
How to unlock jp5 mini
then you took junk out of prison with you .
Jan 25, 2017 | The Computers & Internet
How to unlock jp5
how do i unlock my jp5 mini tablet
Sep 28, 2016 | Tablets & eReaders
How do I reset bios on Tyan S2925 motherboard
You just need to use the JP5 jumper to reset it. The manual below will show you where it's located and exactly how to do it.
http://www.tyan.com/manuals/S2925-E_Manual_v1.1.pdf
Jun 30, 2012 | MSI Computers & Internet
Reset bios on TYAN s2925
You just need to use the JP5 jumper to reset it. The manual below will show you where it's located and exactly how to do it..
Manual reset motherboard: Soyo SY-K7VME
Bios settings are retained by the Motherboard Battery in the CMOS. Disconnecting the battery clears CMOS and returns the settings to their original state. Typically this can be done by simply removing the CMOS battery and waiting about 15 seconds before reinserting and booting PC. Nowadays most Motherboard manufacturers supply a jumper to not only disconnect the battery but also ground the CMOS to effectively drain any residual power.
The instructions for your MB are found below. JP5 is located to the left of the battery and next to the PCI 2 slot on your MB. There is a Manual for your MB on this site and the MB layout can be found at
http://www.fixya.com/support/p281070-soyo_sy_k7vme_motherboard/manual-35533/page-5
Follow the steps below to clear the CMOS memory.
1. Clear the CMOS memory by momentarily shorting pin 2-3 on jumper JP5. Its white cap can easily identify this jumper.
2. Put the jumper back to 1-2 to allow writing of new data into the CMOS memory.
Jan 07, 2010 | Soyo SY-K7VME Motherboard
Physics
When a body covers equal distances in equal intervals of time then the body is said to describe uniform motion.When a body moves unequal distances in equal intervals of time or vice-versa, then the body is said to describe non-uniform motion.
Apr 27, 2009 | Edu-Science Edu Science Microscope Set
Password
If you forget or lose the password, the only way to
access the system is to set jumper JP5 to clear the CMOS RAM.
All setup information is lost and you must run the BIOS setup
program again. You can go to this web site for the manual.
http://www.soyo.com.tw/dl/manuals/p4/mp4is210.pdf
Nov 02, 2007 | Soyo SY-P4IS2 Motherboard
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
kbrowndo4u
Level 1 Expert
chrisheman
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
