Question about Car Audio & Video
Horizandal bands in equal distance - Car Audio & Video
How do you set a 10 band equalizer so the sound is nice
The equalizer selectively amplifies certain frequency bands. If you know the frequency band the band can be adjusted. I took a song and boosted the bass singer's voice by jacking up that band.
Oct 06, 2014 | Audio Players & Recorders
My HDD Dell 300GB 15K 3.5" SAS, i used with Windows Server 2008 Enterprise. The problem after installing the hdd total capacity its 279 How can manage this? Thank you
Hard drive manufacturers market drives in terms of decimal (base 10) capacity. In decimal notation, one megabyte (MB) is equal to 1,000,000 bytes, one gigabyte (GB) is equal to 1,000,000,000 bytes, and one terabyte (TB) is equal to 1,000,000,000,000 bytes.
Programs such as FDISK, system BIOS, Windows, and MacOS use the binary (base 2) numbering system. In the binary numbering system, one megabyte is equal to 1,048,576 bytes, one gigabyte is equal to 1,073,741,824 bytes, and one terabyte is equal to 1,099,511,627,776 bytes.
Simply put, decimal and binary translates to the same amount of storage capacity. Let's say you wanted to measure the distance from point A to point B. The distance from A to B is 1 kilometer or .621 miles. It is the same distance, but it is reported differently due to the measurement.
Capacity Calculation Formula
Decimal capacity / 1,048,576 = Binary MB capacity
Decimal capacity / 1,073,741,824 = Binary GB capacity
Decimal capacity / 1,099,511,627,776 = Decimal TB capacity
Example:
A 500 GB hard drive is approximately 500,000,000,000 bytes (500 x 1,000,000,000).
500,000,000,000 / 1,048,576 = 476,837 megabytes (MB) = 465 gigabytes (GB)
Mar 07, 2011 | Dell 300GB 15K RPM SAS 3.5-HPLUG HD R710...
Need wire diagram for pioneer eq-6500
Pioneer EQ-6500 9-Band Car Equalizer .i want to buy this equaliser.i need 10 pieces ,please send me through my email febiano22@yahoo.com
Nov 24, 2010 | Pioneer EQ-6500 9-Band Car Equalizer
I need a wiring diagram for the pyramid 10 band graphic equalizer. Where can I find this diagram?
Click on MANUAL DOWNLOAD
LOOK PAGE 4 INTO THE PDF FILE!!!!
http://www.pyramidcaraudio.com/sku/903G/10-Band-Half-Din-Power-Booster-Graphic-Equalizer-Amplifier-200-Watts#
Oct 10, 2010 | Pyramid 903G 10-Band Car Equalizer
I need a wire diagram for equalizer 903g
Jan 29, 2010 | Pyramid 903G 10-Band Car Equalizer
How do i connect graphic equalizer to reciever
A graphic Equalizer (GE) is acomprehensive tone controller which enables cut and boost over wide range of frequencies a Klark Technik DN27 was a mon unit and had 27 bands) And a DN22 was stereo with 11 bands /ch
They are called as named because when viewed from a distance they look like a graph of the sound.
Normally a GE is inserted into the signal chain between the pre amp outputs and the power amp inputs.
So look on your equipment for these rca /jacks. (pre out) (amp in)
It is possible to do the in /out fubctions on one connector (stereo jacks) so look for jacks marked insert point.
This will be a very suitable place for the GE connection.
Hopw this helps. thanks for using Fixya
Sep 27, 2009 | Yamaha Audio Players & Recorders
Physics
When a body covers equal distances in equal intervals of time then the body is said to describe uniform motion.When a body moves unequal distances in equal intervals of time or vice-versa, then the body is said to describe non-uniform motion.
Apr 27, 2009 | Edu-Science Edu Science Microscope Set
Optimus 7 band equalizer model # 12-1969
I need to know what the wire are coming out the back of the optimus seven band stereo frequency equalizer/booster
Jul 07, 2008 | Car Audio & Video
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
