Question about Miscellaneous
Check id number
T.izalia mabodla
Number JC9043011 did my spin id number win?
Wheel of Fortune ' Wheel Watchers Club ' What is SPIN ID?
www.wheeloffortune.com/spinid/
  1. Cached
  2. Similar
Watching Wheel at home is more rewarding than ever with the Wheel Watchers Club! Watch Wheel for a chance to win with your Wheel Watchers Club SPIN ID number starting January 16th! Short for "Special Prize Identification Number," your personal SPIN ID number can give you the chance to win $5,000 each weeknight. 2.
Wheel of Fortune ' $5K Every Day Sweepstakes
https://www.wheeloffortune.com/fivek-every-day/
  1. Cached
Fri.) to see if your SPIN ID is announced during the $5K Every Day reveal. ... If your SPIN ID is verified as the winning number, we'll call you to confirm you as the ...
Wheel of Fortune ' America's GameĀ® ' Wheel Watchers Club
  1. Cached
  2. Similar
Find Your Station. FPO. Wheel Watchers Club. Login OR Join. FPO. Did My. SPIN ID Win? Let's See. Filter Content as: All Photos Video Text. #WheelOfFortune ...
Wheel of Fortune Solutions - Winning Spin ID
www.wheeloffortunesolutions.com/spinid.html
  1. Cached
  2. Similar
Daily Wheel of Fortune winning Spin I.D. numbers, prizes and names of winners.
My Spin ID number came up last night -... - Patricia A McLeod ' Facebook
https://www.facebook.com/wheeloffortune/posts/499915046718810
  1. Cached
  2. Similar
My Spin ID number came up last night - and guess what - I did not win. I found out that you have to login into your Spin ID account every 6 months so its...
Member TIP: To keep your SPIN ID and... - Wheel of Fortune ' Facebook
https://www.facebook.com/wheeloffortune/posts/131867833547568
  1. Cached
  2. Similar
The Wheel Watchers Club is the only way to win big, just like the contestants on Wheel of Fortune. Join today to receive your SPIN ID number. Short for "Special ...
Jan 25, 2017 | Computers & Internet
I cannot see incoming call number - Blackberry Curve 9300 model. Please assist. Thanks!
it include two solutions first take a anothe network sim card then check still the same problem occur if now the caller id is visible ask your service provider that whether they acivate the caller id service for your mobile number then check in your mobile that you disable the id . This is on the option like show my caller id (see is this this enabled or disabled if you disable this enable it) i suggest you better you try the mobile restore option
Jun 12, 2011 | RIM BlackBerry Curve 3G 9300 Cell Phone
How can I found out the stats on a Canon NP 6551 (ie total pages, etc...)?
NP6560 Main Specifications
Main Unit
Type: Console
Platen: Stationary
Photoconductive material: Amorphous Silicon
Copying system: Electrostatic transfer system
Developing system: Toner projection system
Fixing system: Heat roller system
Acceptable copy stock: Paper drawer:17 to 24-lb bond (64 to 90 g/m2); plain paper
Stack bypass:17-lb bond to 110-lb index (64 to 200 g/m2); plain paper
(However, Keep in mind that the paper weight that can be used varies
depending on the type of the Sorter being used.
SADF tray : transparencies and labels
Acceptable originals: Sheets, books, and three-dimensional objects (up to 4.4-lb or 2 kg)
Maximum original size: 11" x 17"
Copy sizes: Paper drawer: STMT, STMTR, LTR, LTRR, LGL, and 11" x 17"
Stack bypass: 4 1/8" x 5 7/8" (horizontal placement) to 11" x 17"
Non-image areas: Leading edge: 1/4" (4.5 mm)
Left and right side: 1/16" (3 mm)
Trailing edge: 1/16" (2 mm)
Warm-up time: Approx. 6 minutes (at temp. of 68°F)
First copy time: Max. 2.8 seconds
[LTR size, direct copying, Manual Exposure Control, Drawer 1 (top
drawer) selected 1→1-sided mode]
Copy speed: Direct (100%) LTR 60 cpm
65 cpm (Accelerated mode)
LTRR 49 cpm
11"X 17" 30 cpm
LGL 40 cpm
STMT 60 cpm
STMTR 60 cpm
Reduction 11"x 17" → STMT 56 cpm (50%)
11"x 17" → LTR 48 cpm (64%)
11"x 17" → LGL 40 cpm (73%)
11"x 15" → LTR 48 cpm (73%)
LGL → LTR 49 cpm (78%)
Enlargement LGL → 11"x 17" 30 cpm (121%)
LTR → 11"x 17" 30 cpm (129%)
STMT → 11"x 17" 29 cpm (200%)
Magnification: Direct 1:1.000
Reduction 1:0.500 (11" x 17"→STMT)
1:0.647 (11" x 17"→LTR)
1:0.733 (11" x 17"→LGL/11" x 15"→LTR)
1:0.786 (LGL→LTR)
Enlargement 1:1.214 (LGL→11" x 17")
1:1.294 (LTR→11" x 17")
1:2.000 (STMT→11" x 17")
Zoom 1:0.490-1:2.040
7-8
Paper feeding system: Drawer 1, 2 (1,500 sheets x 2)
Drawer 3, 4 (550 sheets x 2)
Stack bypass (50 sheets; stack approx. 1/4" high)
Multiple copies: 1-999
Power source: 120 V, 60 Hz
Max. power consumption: Less than 2.0 kW
Dimensions (H x W x D): 46" x 25 3/8" x 28 1/2"
(1169 x 643 x 725 mm)
Installation Space (W x D): 40 5/8" x 28 1/2"
(1030 x 725 mm)
50 3/8" x 28 1/2" (1280 x 725 mm)
[With copy tray (option) attached and stack bypass auxiliary tray extended]
Weight: Approx. 462 lb (210 kg)
RDF (Standard equipment)
Originals: STMT to 11" x 17" size (STMT-size cannot be placed horizontally.)
Original tray: LTR 15-lb to 110-lb bond (52 to 200 g/m2)
11" x 17", LGL, LTRR, or STMT
15-lb to 32-lb bond (52 to 128 g/m2)
SADF tray: 11" x 17" to STMT
11-lb to 110-lb bond (38 to 200 g/m2)
Max. power consumption: 120 W
Original tray capacity: Original tray: 11" x 17" or LGL
50 sheets (20-lb bond or 80g/m2)
LTR, LTRR, or STMT
100 sheets (20-lb bond or 80g/m2)
1 sheet
Original replacement speed: 60 sheets/minute (LTR, horizontally placed)
Power supply: 24 V (supplied from main unit)
Dimensions (H x W x D): 6 7/8" x 25 3/8" x 21 1/4"
(174 x 643 x 539 mm)
Weight: Approx. 56.3 lb (25.5 kg)
These specifications are subject to change without notice.
8-1
ar
Energy Saver
Stop
Guide
Additional Functions
Start
Display Contrast
ii
Enter a ID number with the Number ( 1 - 0 )
keys.
MEMO: ? If you make a mistake entering an ID number, press
the C
Clear
key. Then, enter the ID number again.
? You cannot enter two identical ID numbers.
? If you enter and store "000000" in place of a current
ID number, that ID number is canceled.
? You can store up to 1,000 ID numbers.
Press the [OK] key.
If you want to store another ID number, repeat
steps 3 to 5.
5
After entering all the ID numbers to be stored,
press the ID key. The display returns to the ID
entry screen.
6
Canceling the ID Mode: Clearing All ID Numbers
If you clear all the ID numbers then you can make copies without having to enter an ID
number.
Press the Additional Functions , ID , Stop , and Additional Functions keys in that
1 order.
Clear
Guide
Interrupt
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
iii
Press the [OK] key.
MEMO: ? If you want to stop all the ID#s from being cleared,
press the [C] key.
Press the [CLEAR ALL ID#s] key.
Press the [STORE USER ID#] key, then press
the [OK] key.
All the ID#s are cleared.
If you press the [OK] key, you will return to the
Standard mode.
MEMO: ? Storing all the ID#s under "000000" will also clear all
the ID#s.
iv
In the ID mode, the copier keeps track of the copy quantity made under each ID number (up to
999,999). You can view the copy total for each ID number in the touch panel display.
1 order.
After pressing the [COPY TOTALS] key, press
2 the [OK] key.
Press the [?] or [?] key to check the copy totals
for a department. The copy totals can also be
displayed by entering the department number.
Press the Number keys ( 1 - 0 ) for a four digit
department number and it appears at the top of
the display. When you finish checking the copy
totals, press the [OK] key.
Copy Totals (Check Totals)
The following procedure describes how to clear the copy totals for all ID numbers to zero.
Copy Totals (Clear All Totals)
1 order.
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
v
2 the [OK] key.
Press the [CLEAR ALL TOTALS] key. 3
Press the [OK] key.
MEMO: ? To cancel clearing all totals, press the [C] key. 4
The copy totals for all ID numbers are cleared to
zero. If you press the [OK] key the display
requesting the entry of an ID number appears.
MEMO: ? You cannot clear the copy totals for ID numbers
individually.
Dec 21, 2010 | Canon NP 6551 Black and White Copier
Caller id wont work on the phone. All Calls come up as unknown
You must have the phone number in your contacts exactly like the number calling you or you won't see it. If that doesn't work, check your settings to see if you allow caller id. If that doesn't work make sure your telephone company has caller id turned on for your phone. Good Luck
Oct 07, 2010 | Cell Phones
Phone doesn't show caller id numbers anymore.
You need to make sure you have programmed your area code...check the manual for setting up caller ID. You can search for the manual on line...go to Retrevo.com
http://www.retrevo.com/support/Sony-IT-M602-Telephones-manual/id/751bh629/t/2/
Mar 10, 2010 | Sony IT M602 Corded Phone
Motorola dsr922 lockup on startup
ATS electronics can repair the board that died. running out of boards is not a problem. the dsr-920 receiver is junk if the battery dies..the chip that stores the unit ID number is no longer manufactured....
Oct 18, 2008 | Arris DSR922
Power outages cause receiver to lose unit ID numbers.
When the backup battery goes dead you loose the ID number.
http://www.pacificsites.com/~alanjudd/922.htm
If you have lost your receiver ID number you will need a new main board.
Check the receiver number in the status screen. If it matches the UA number on the back sticker you are ok, if not the only solution is replacing the main board. ATSelectronics.com still had some boards when I last checked. But when they run out were all screwed.
Motorola didn't make any provisions for renewing the ID number.
That really sucks motorola ;-(
Sep 05, 2008 | Arris DSR922
DAEWOO RADIO CODE
i have a daewoo radio cassete i don't see any serial number,all i see is part # 96334689 AND ID CODE WZ
CAN SOMEONE TELL ME HOW TO GET THE CODE
I TRY TO LOCATE DAEWOO DEALER IN SAN DIEGO CA
BUT CAN'T FIND ONE.
my email 2000auto@att.net
thanks
Jan 17, 2008 | Car Audio & Video
Miscellaneous Logo
24 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
