Question about Maytag Washing Machines
How do you bench test discharge pump for Maytag Bravos top loading washer?
SOURCE: maytag Bravos top load gives LF code..not working
Have same problem. Service tech said LF code is caused by low water pressure coming into machine. Tech verified water flow looked fine, getting new controller installed tomorrow.
Posted on Sep 23, 2009
  • 3 Answers
SOURCE: maytag bravos top load washer error code F1
Well, you're not gonna like this, but here's the deal.
Remove the three screws on the rear of the control panel and lift it up. Disconnect the rubber hose on the right side of the gray control module and blow through it to make sure it is clear and not kinked. If this check is fine then your control module needs replaced.
Note that Maytag knows this is a fairly common problem. My washer failed 9 months out of warranty with this problem.
The only good news is that it is an easy, though expensive, replacement.
Posted on Sep 25, 2009
  • 50 Answers
SOURCE: My Maytoag Bravos Top load washer drains really
Is the drain hose kinked or clogged? Is the drain hose installed properly? look in the installation Instructions, Press POWER/CANCEL to clear display........ hope this helps.....
Posted on Jan 08, 2010
  • 4 Answers
SOURCE: How reset clean washer reminder on Bravos washer
This is just a factory setting that reminds you to clean the washer to avoid that musty smell. You can buy tablets called Affresh or other similar cleaners for washing machines. They sell these items at Target, Walmart, Lowes and Home Depot. You can also substitue 1 Cup of Bleach in the washer. Then once you add whatever solution you have decided to clean it with you simply select the wash cycle on the machine called "Clean Washer with Affresh" Once you have done this the light should go out. You can also reset this indicator light by pushing the button next to the light that says Reset clean washer reminder. Hope this helps!! :)
Posted on Aug 11, 2010
SOURCE: The f1 code on the Maytag Bravos top loading
Please contact Maytag to inquire about the code F1. They should check the system and that that code is a courtesy repair and should be scheduled for a someone to come out to fix it. FREE
It is possible that the F1 code was caused by your laundry habits (detergent), but I think that is unlikely. Too many of these machines have problems with the F1 error code. There is a known problem with the Oasis / Cabrio / Bravos machines.
Posted on Aug 19, 2010
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
Water leaking from the bottom of my maytag bravos washer
Depending upon the age of your washer, the pump may have begun leaking
Apr 21, 2013 | Maytag Bravos MTW6600T Top Load Washer
I have pocket change in the bottom of my maytag Bravo washing machine. when the discharge pump runs it makes alot of noise and i have already ruined one pump. I can't see how to get the rest of the...
do a Google search on your model number and type in on how to take it apart. I bet you your change somehow got in between the two tubs. The inner tub and the outer tub.
May 07, 2011 | Maytag Bravos MTW6600T Top Load Washer
Washer pouring water out the bottom of the bottom of the washer.
sounds like the discharge pump got some coins in it and wore a hole in the pump housing. you can either buy a new pump or try to repair the pump you have. i repaired my pump by dismantling it and then i bought a flat head nylon bolt and a nut and some epoxy putty and i plugged the hole with the putty and the bolt. but you will need to get all of the coins out of the tub. it takes a while.
Feb 08, 2011 | Maytag Bravos MTW6600T Top Load Washer
Coins rattling
take all of the coins out of the pockets before putting the clothes in the washer because the coins will get into the discharge pump and eventually cause a hole in the pump. i was able to repair my pump using some epoxy putty and a nylon bolt and nut.
Feb 05, 2011 | Maytag Bravos MTW6600T Top Load Washer
My Maytag bravos wont spin out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 23, 2010 | Maytag Bravos MTW6600T Top Load Washer
How do you select the load size on the Maytag Bravos Top load washer?
This machine is equipped with technology that allows it to sense the load size and will use the appropriate amount of water for that load. Takes the guesswork out!
Apr 21, 2010 | Maytag Bravos MTW6600T Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
