My twchwood is not displaying but the DVD is rolling
I can't get closed caption off my dvd player
Some DVD players cannot handle closed captions. Cheaper or older hardware players sometimes strip out the closed caption data. Players that have a progressive scan mode sometimes block captions when in this mode. And anything that's connected with an HDMI cable can't pass through captions.Most software players that you use when you play a DVD on your computer don't have any way to decode the captions. Windows Media Player can display DVD captions, and Apple DVD Player can display pop-on captions but not roll-up style captions. Certain paid versions of WinDVD and PowerDVD have CC capability. Look in your player's preferences to see if there are any closed caption options.
Thank you for using FixYa, have a nice day don't forget to rate me.
Oct 18, 2011 | LG DBRH197H DVD Player/HDD Recorder
"Please wait" keep rolling on the display, the LG refuses to work
you need to replace either the mpeg pcb or the dvd loader assy.
Jul 01, 2009 | LG RH177 DVD Recorder/HDD Recorder
The display screen is rolling and is in black and white.
You switched to PAL mode from NTSC or vice versa. Most DVDs will only output PAL or NTSC, not both. So even if the disc is region ffree, the fact that it's encoded in PAL (50hz) makes it appear like you describe - no vertical hold / black and white.
Some set top players [Apex, Phillips] will convert PAL to NTSC on the fly or vice versa.
Remember, PAL/NTSC is not the same as Region.
Here's some detailed info:
You can convert the DVD to NTSC, and strip the region code by following
[This is very time consuming.]
What DVD
Most players are either NTSC or PAL, however increasingly DVD players from the Far East (Apex, Phillips etc)
, which is 50hz instead of 60hz, hence the lack of vertical hold
Mar 23, 2009 | Televison & Video
Picture on tv rolls when dvd player is on.
Radio Frequency Interference (RFI) being generated by you rDVD Player.
That, or you have the DVDs settings on PAL instead of NTSC.
Mar 13, 2009 | Prosonic PD-007 DVD Player
Coby DVD screen setting wrong
check on the cover of the player the info to reset should be there
Oct 26, 2008 | Coby DVD-514 DVD Player
Vertical roll
I get Vertical roll on my Apex AD1000 DVD player and need a schematic. I don't know where to get a schematic but I have the necessary test equipment to troubleshoot the problem. Do you know where to get a schematic or know what causes the vertical roll problem?
Program the setup menu screen to NTSC instead of "PAL" or "Auto"
Oct 05, 2008 | Apex Digital AD-1110W DVD Player
DVD - S520 Player stuck on initialize
please check you TV color system. you are not using the right color frequency. if your TV has got an auto color region select then set it to auto. otherwise, select the TV color mode until you get the right color frequency
Jun 03, 2008 | Yamaha DVD-S520 DVD Player
Samsung Dvd R130
Mar 24, 2008 | Samsung DVD-R130 DVD Recorder
Picture rolls
Same as sherpi here, player was fine, and all of sudden started rolling and never stops. Rolls with or without a disc in it...seems to play the discs fine, but never quits rolling.
Mar 08, 2008 | Spectroniq PD-1100 DVD Player
Koss KS5190 Display mode stuck
I'm not ranked and I'm not a Guru, but I can solve this picture rolling when the problem is "the video was accidently changed from NTSC to PAL and you can't see what your doing to get it back". You will need the remote control unit. First, remove the disc from the tray. Now, turn the unit off with the power button. The tray will close by itself. After the display on the front of the unit goes out, turn the unit back on using the remote control. This will let you know the remote control unit is working. When the power comes back on and the display on the front of the DVD player says, "NO DISC", with the remote control and (very important) while pointing the remote at the player, (Remember to point the remote before pressing any buttons) press the "Down Arrow" button 3 times. This will take you to the "Display" box. Now, press the "Right Arrow" button 1 time. This will take you to the "TV Image"box. Now, press the "Down Arrow" 1 time, this will take you to the "PAL/NTSC" box. If you have done everything as I have tried to clearly lead you blindly to your destination. Press the "OK" button 1 time and the picture on the screen will stop rolling and change from black & white to color. You will have now changed your video output from PAL to NTSC. If you press "OK" again, it will start to roll again. If this did not take care of your problem, turn the player off and try it again.
The previous problem solvers were on the right track, but the track was rough and they just about derailed the train. Thanks to them, I had a track to follow. I had no other information, except what I found on "". MR. CD
Feb 03, 2007 | Koss KS5190 System
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
