Question about Siemens Cell Phones
My Siemens A 50 won't start. What to do?
My phone Siemens A 50 charges up and when i want to start the phone, i hear the low battery sound. Tomorrow, so. What to do?
SOURCE: Beeping sound
Is the beping like about 1 minute apart?? If so some phones have what is called "Minute Beep" or something like that..... check in your settings and/or check your manual and see if this is set to on... this might be the issue.........
Posted on Feb 07, 2008
  • 45 Answers
SOURCE: Battery problem: P3400i
Sounds like its probaly the battery, they dont last forever, try here for a replacement - HTC P3300 battery
Posted on Jul 16, 2009
SOURCE: siemens sl30 phone wont charge.
I have similar problem with my gigaset 4000 micro, i bought 600mah NiMh bettery and when I start charging it charges cca 3 min and displays that battery is full and it doesnt charge it any more. I can speak max 12 minutes and phone starts beeping that battery is empty. What should i do to make phone to charge this battery properly.
Posted on Jan 27, 2011
  • 339 Answers
SOURCE: I have a Kymco People
have you checked the spark plug? take it out and lay it on the engine touching a metal part and kick the bike you should see it sparking if not then replace the spark plug
if thats not the problem then give the carb a clean and check the air filter that its not blocked
2 stroke bikes need three things to work air spark and fuel as long as you have these it will work
hope this helps
John
Posted on Jul 10, 2011
bdrew1340
  • 448 Answers
SOURCE: Road King 2009 Won't start had battery checked out said it was good had it charged bike still won't start just clicking sound
Check the tightness of the battery cables and the starter relay.
Posted on Jul 11, 2012
2009 Piaggio Zip 50 will not turn over
Hi, Anonymous before testing any electrical component in the Starting Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter motor or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. Faulty ignition relay.
14. The electric starter is working but starter clutch has failed.
15. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
My Piaggio 50 Won start
Scooter Troubleshooting Scooter won start All about Scooters
PIAGGIO TYPHOON 50 2T 4T BIKE WORKSHOP SERVICE REPAIR MANUAL Download... $15
https://www.motorcyclespareparts.eu/piaggio-parts/scooters/zip-50-2t-2009.aspx
PIAGGIO ZIP 50 2T User Manual
Nov 07, 2017 | 2009 Piaggio Fly 50
Bmw gs 1200r adventure won't start with a new battery
Does the motor turn over when you hit the start button?
If you just hear a Click, click, click without the motor turning over, then your battery voltage is low and will need to be charged.
If your motor actually swings but doesn't fire up, chances are good that it is the fuel pump regulator that had blown. R1200GS 08 09 K25
Part number 16 14 7 720 776 is what you will need.
Mar 05, 2013 | 2010 BMW R 1200 GS Adventure
I have had my i phone for three days but will not charge beyond 50..percent...help
If the re-chargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 14, 2012 | Apple iPhone 5
Seimens sx1 start up problem
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Oct 09, 2012 | Siemens SX1 Cellular Phone
Computer shuts off when battery reduces to 92%
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Jun 22, 2012 | Fujitsu Siemens Computers & Internet
Low battre Lg KU250
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 30, 2012 | LG KU250 Cellular Phone
Nokia 2700c battery low problem
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Mar 04, 2012 | Nokia Classic 2700 Cell Phone
Low battery
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 08, 2011 | Nokia 2760 Cellular Phone
Siemens charger for hearing aids starts charging and then after some hours one light goes red
Its a warning sign for a faulty battery, the red light comes on if the battery is faulty or if you are trying to recharge a non rechargeable battery.
May 03, 2011 | RTO 1 Siemens Pure 500 Open Fit Hearing...
Siemens sl30 phone wont charge. Just blinks the last part of the battery. When I turn on the speakerphone to dial the phone dies and shuts off. when regular dialing can hear crackling static
Aug 08, 2008 | Siemens Lands Phones
Cell Phones Logo
35 people viewed this question
Top Siemens Cell Phones Experts
Computer Repairing
Computer Repairing
michael galang
Yoav Shilon
Yoav Shilon
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
