What happened when the blu light flash is on - Televison & Video
Back panel removal for hi sense tv 46k360m
Do you have sound?
When blue light on press power on remote.What happens?
Try reset. Unplug tv hold power button on tv for 60 seconds, let tv sit for 10 minuets, then plug in and turn on. What happens?
With replacement of both boards you should atleast have sound.The blu flashing is booting for a tv before it turns on steady.
What was the inital problem you had for you to replace both boards?
Sep 29, 2016 | Hisense Televison & Video
Flashing Power Light
your surround sound system seem like having dry solder joint at PCB . one thing you can do is to open up the back cover first looks for dry solder joint ( if you can find ).if not just re-solder those solder looks very thin.it may help.
Aug 02, 2007 | Teac Legacy DR-L700 DVD Player
What is flashing yellow light on back?
does it have a wired ethernet port in the back? If it does that is the light that is flashing.The digital sound should have a small cover over it that prevents you from seeing the light it emits.
Jun 05, 2014 | Vizio VBR220 Blu-Ray Player
Unit shows 'loading' continuously
This player is equipped to do a self power on test to all pain parts of the player to assertain everything is ok. The blue light will keep flasing until it completes its task and then the blue light will stop flashing and you you can start reusing it.....................sodeep
Jul 30, 2009 | JVC DR-MH30 DVD Recorder
Power light is flashing red and nothing happening
Most of the people having this problem had to replace a blown capacitor C316 (1000uF/10V) on the power supply module. You can read step by step instructions at:
http://club.cdfreaks.com/f114/philips-dvp-642-37-power-problem-180909/
Hope this helps
Jul 15, 2009 | Philips DVP642 DVD Player
The dvd player doesn't play the dvd's
when i load the disc it spins for 5-7 seconds then quits and the poer light, play light and loading light flash continously. model p421
Apr 18, 2009 | Televison & Video
Blu light flashing
This is most probably a faulty power cable, a common fault on La Cie apparently. Another cable got my disk working fine!
Nov 12, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
The power just flashes won't turn on completely.
sounds like there might be a damaged component, power supply maybe that may explain why the light flashes on and off and it wont start up.
Oct 12, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
