Question about Samsung Televison & Video
I have a Samsung Plasma TV model that has a thin horizontal line along the bottom of the screen. I've replaced the Y-Buffer board and the Y Main Board but the line is still there. Please help!! Thank
It's a 50 inch Plasma.
  • 179 Answers
SOURCE: Samsung 42" Plasma-SPN4235 screen problem
the panel itself has failed
Posted on Dec 01, 2007
  • 41 Answers
SOURCE: thin horizontal line,about 6 inches from bottom,is it fixable?
I am assuming it goes all the way across and is black ?
It sounds like a scan line in one of the chips inside has gone bad or needs to be resoldered. Most likely needs the board replaced by a tech.
Hope this helps
Scott
Posted on Mar 30, 2009
  • 298 Answers
SOURCE: JVC PD-42DX6BJ plasma 42 inch black horizontal lines over the pic
Here's a link to order the original the JVC upper Y-buffer board and lower Y-buffer board for this model from a major parts distributor if needed:
JVC "PD-42DX6" Replacement Part Upper Y - Buffer Board (LJ41-02760A)
JVC "PD-42DX6" Replacement Part Lower Y - Buffer Board (LJ41-02761A)
Based on the symptoms: It is possible that the Y-buffers are faulty, which may require the replacement of the Y-sus board as well. You may want to get a local technician to diagnose the unit and provide a second opinion.
Posted on Apr 01, 2009
  • 231 Answers
SOURCE: Hitachi Plasma very thin bleeding horizontal lines
very possible the YSUS board is going bad .If YSUS is going bad .I would also replace XSUS board since they are same age..Also whenYSUS is replaced make sure you make pot ajdustments as old YSUS and also with XSUS board
Posted on Aug 26, 2009
  • 16 Answers
SOURCE: 2 horizontal blue lines on samsung 50 plasma tv
Possibly could be the Y buffers --if the are next to each other could be a bad connection on a ribbon cable ---you need to call for service
Posted on Feb 06, 2010
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Samsung 60 inch plasma has developed thin vertical lines top to bottom. Changes colors rapidly. Lines are increasing from one to twelve now. Could buffer boards be fault?
Buffer boards could be at fault. Also the connectors to the boards. On more than one occasion I have put a wedge under a buffer board to make a better connection. A good repair man will test the connections as well. Main video board could cause this too.
Nov 05, 2015 | Samsung Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
How to fix my plasma tv
Y-Buffer boards should be checked. You have to check which buffer board should be replaced. It is a semi-skilled work. You have to open the TV. If you wish to get more details about this fault, check this link.http://electronicshelponline.blogspot.com/. It has details about plasma screen faults, along with screen shots. Pull up older posts there. Do not mind about the brand name, because, techniques behind plasma displays are the same, and the difference is with its control circuit, and main system control circuit, which provides many other facilities.
May 31, 2013 | Televison & Video
Hi have a samsung 42 inch plasma, all of a sudden it has a band 20cm wide of dotted lines going across the whole screen, some channels or when playstation in use the band gets wider, does not seem to...
if the band is horizontal your tv has bad y-buffer board. Usually there are 2 buffer boards- top and bottom. if the problem is in the top half of the screen replace the top board, otherwise replace bottom board.
but better to replace both a the same time.
if the tv has a vertical lines from top to bottom it may have bad plasma panel and can be considered as not economical to repair.
Oct 03, 2012 | Samsung SPN4235 42 in. Plasma HDTV
I have a single thin horizontial black line six inches from the bottom of the screen. how can it be fixed.
Hi.
The line is probably in correspondence of the low Y buffer board, located inside the TV and connected to plasma display. In that case the board must be replaced to fix the problem. One of the symptoms of a defective low buffer board is a black line that starts from the bottom of the TV.
Regards.
Ginko
Apr 25, 2011 | Maxent MX-42HPT51 42 in. Plasma TV
Apr 01, 2009 | JVC PD-42DX6 42 in. Plasma Television
My plasma tv has a black bar in the left side goin up and down?
Depending on brand,model etc it could be a bad buffer board-thin board along bottom of set-or bad plasma display panel itself.On some units the buffer bd is not available seperatly and you must replace the plasma panel which will cost much more than the set.
Jan 10, 2009 | Televison & Video
Samsung HPR4252 with red horizontal lines accross the screen
I just had my HP-R4252 repaired on 12.05.09 with a similar problem. The picture is covered in horizonal, broken lines and the color is predominately red. They lines are grouped together in large bands across the screen.
The tech replaced the Y-Buffer boards (Up) and (Low) in about 20 minutes.
Samsung BN96-02034A BOARD, Y BUFFER UPPER ASSY
Samsung BN96-02216A BOARD, Y LOWER BUFFER ASSY
Feb 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Televison & Video Logo
24 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
