Back to:
Tags:
Philips DVD935
Philips DVD935
By Ross - usenet poster
Hi
I,ve got a customer with aPhilips DVD935 ,originally a region 2 player.A
little more than 2 years ago we made a chip-upgrade to gain all regions
possible.It worked properly until new yearsday 2001...then it didn't accept
any disc,just telling "wrong region"..we made a reset...don't remember
how...it was running again.
This new year 2001/2002...the problem came back again...but didn't manage to
make it work again.
Tried to remove the "modification chip",back to original.No difference
still.
Is there any known solution for this problem?
Greatful for tips
/Max
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Feb 15, 2006
Not Rated (0)
MadhaT
Rank:Master Master
Rating: 79%, 75 votes
found these 2 solutions try them out :
Philips DV-935
- Make sure there is no disc inserted and then turn the DVD player on
- Press the buttons '2', '7', '4' on your remote control.
- An entry field will appear
- Enter the following codes with the remote control:
* For regional code 1: 0060001 281 56
* For regional code 2: 0010001 281 56
* For regional code 3: 0090001 281 56
* For regional code 4: 0110001 281 56
- Press any other button on the remote control.
- The display should now turn red, the code has been changed?
- Unfortunately, this only works 25 times.
An alternative method:
- A field similar to an entry field appears
- For regional code 1: 00500128156
- For regional code 2: 00200128156
- The display should now turn red, the code has been changed.
Caution, this method only works 25 times!
and check this site for a lil bit do it your own :
http://www.regionfreedvd.net/player/phil...
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Philips DVD935:
I don't want to Accept this solution
Can you Help with these DVD Players problems?
DVD Players
The Audiovox VOH681A unit has been discontinued, but I...
DVD Players
Our Philips fwd576 3 in one system gets stuck on any dvd...
DVD Players
PhillipsDVD580m and when i put on a DVD the picture...
DVD Players
lost my manual have only quick start quide dvd...
DVD Players
My LG dvd recorder won't recognize rented dvd movies
Loading problems.
Repair Service
Find DVD Player Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
