Question about The Audio Players & Recorders
I have a 7widescreen pyle#plhr70 lcd monitor- I want to connect a zettaguard backup camera-HOW DO I CONNECT THE BACKUP CAMERA TO THE MONITOR- THE MONITOR CABLING has 8 pin cable connection;help!
The monitor wires;1red1black1green&2yellow/rca connectors1male&1female; I also have a wireless ZETTAGUARD RECEIVER&TRANSMITTER I BOUGHT WHEN I BOUGHT THE ZETTAGUARD BACKUP CAMERA; WHAT,S THE BEST WAY TO USE WHAT I HAVE NOW??? THANKS PATRICK
SOURCE: how to connect using a LCD monitor, cable box, DVD player
You won't need the VCR, that's only used for a cable box, and since you have one now there is no need. You'll want to connect everything with the better video plugin possible. Composite (red, white, yellow) is the worst, then s-video, then component (red, blue, green), then DVI, then HDMI. That will square your video. Then send all audio signals to the Denon. These cables are usually the red and white cables. OR Plug everything into the Denon to the appropriate input. Then connect the monitor to the video out of the Denon.
Posted on Jun 28, 2007
oldnovii
  • 667 Answers
SOURCE: Using the device from the cable outlet
Not a stupid question. You should have received all the cables you need with the Leap Frog. To hook up your tv, take your transmitter and one set of a/v cables, usually red, white and yellow. Do one cable at a time. Your tv outputs should be color coded. You should have one set of three jacks completly open on the back or side of your tv, i.e. labeled component 1, component 2, aux 1, etc. First plug select one set of jacks. Plug a yellow plug into the yellow jack on your tv labeled video out. Plug the white plug into the white jack labeled audio L out. Plug the red plug into the red jack labeled audio R out. Now do the same on the transmitter but the jacks should say in. Yellow, white and red to video, audio L and audio R. Now take your receiver into the other room and do the same thing with the other tv. The cables go from the receiver out jacks to one set of jacks labeled Aux, component, etc like before. Pick a set that has all three open. Red to red, white to white, yellow to yellow. Make sure you then have the transmitter and receiver plugged in. Your remote is supposed to work from your other room. If this solved your problem please rate this as fixed. If you need more help with this just add a comment and I'll be glad to help you. Thanks.
Posted on Apr 13, 2008
jemmyrash
  • 180 Answers
SOURCE: Missing VGA Cable for LCD Monitor - Help?
It should be 15 pin connector VGA .It should work.
Posted on Apr 19, 2008
SOURCE: WIRING DIAGRAM
yo have wiring diagram :)
send your e-mail address to southener83@hotmail.com
Posted on May 13, 2008
SOURCE: need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Posted on Jan 07, 2009
How can I get the install instructions for PYLE PL7300BT Rear View camera system?
Pyle PLCM7300BT Mobile Video Navigations Back up Camera Rear View...
Went to this site to find your particular product,it has a downloadable pdf manual whic will by default show you your setup.You may not have the green wire but if you read this manual you may be able to by process of elimination figure out your question.Pyle also has a very good technical support staff,been there done that ,they will also help you out.Good luck hope this helps you.
May 19, 2014 | Pyle PLCM7300BT 7"TFT Mirror Monitor W/...
Install rear backup camera
PYLE, 3.5 MONITOR INSTALLATION INSTRUCTIONS, INSTALLED IN SUV. As others have mentioned ThePyle Instructions are pretty much non-existant. As a formerly ASE Certified mechanic I am posting this to try to help others.THE PYLE KIT: Monitor + Camera Mount + Wiring Harness for hard wiring into vehicle electrical. --- Additional Materials Required to Install: 3ea. coils of automotive 18 ga. wire. One red, one black, and one white. 1/8" non insulated wire but connectors, wire shrink wrap (1/4", 3/16\', 5/16" AND 3/8" best to get assort. pack). Self taping sheet metal screws 1/2" long. Roll of electrical tape, Barbed Butt Connectors (2ea.- see illustration wiring Monitor posted this site). Rubber wire grommet 3/8" outside, 1/8" for wire, 1ea. req. Pull ties. --- Tools Required: Utility Knife, Drill w. phillips bit driver, wire tripper, volt meter, small pry bar. + Misc. ---
Mar 16, 2013 | 2004 Hyundai Santa Fe
Installation instructions for pyle view plcm7200
Where do I hook up the green wire on Pyle 7200 rear view camera
Dec 27, 2012 | Pyle PLCM7200 7'' Tft Mirror Monitor W/...
Pyle PLCM4300WIR
The Green wire is a reverse trigger wire. It should be tied into the reverse light hot wire. This tells the monitor to turn on and switch to Video 2 so that it displays what is seen by the backup camera. When you take the vehicle out of reverse thus removing power from the green wire, the monitor switches back to normal driving mode. ( no video displayed ).
Jan 15, 2012 | Pyle Car Audio & Video
Pyle plcm7300bt what does the green wire reverse car wire connect to + or ground
The green wire connects to the backup lights control. When the gear shift is in "Reverse" this acts as the switch on the "Monitor" and turns the system on so you can see what's behind you to safely "Backup" Hope this helps you.
Jan 09, 2012 | Pyle PLCM7300BT 7"TFT Mirror Monitor W/...
What to do with the second camera wire? Video connection and...? Pyle PLCM 7200
This is not a solution. I have the same question. In addition, my unit shows blue screen and "no signal". Any guesses?
Jun 24, 2011 | Pyle PLCM7200 Car Monitor
The problem is everytime i turn my head lights on the pyle swiches to a blue screen, the radio goes off and it has the words "car" in the top left corner of the blue screen. i own a 2004 ford...
you have your wiring wrong, im guessing you have a rear view camera on there, you need to dissconnect the wire thats for the rear view camera (behind ur dvd) get another wire , connect one end to your backup lights (12v, red) and connect the other one to the wire for the camera behind ur dvd player
Nov 28, 2010 | Pyle PLDN76DB Car Video Player
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
kbrowndo4u
Level 1 Expert
chrisheman
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
